Author Topic: Best way to make pushbutton holes larger?  (Read 2890 times)
dailygeek
  • Last login:October 27, 2008, 05:50:50 pm
« on: October 25, 2008, 03:41:12 pm »
Hi folks
Just converting my first JAMMA cab and so far so good.  Except that I ordered some new Happ pushbuttons from ultimarc, fully expecting my current buttons to be a standard size but when trying to replace my first one, realised that the diameter of the existing buttons is a couple of mm smaller than Happs.
What is the easiest way of making these holes big enough?  Hole drill bit through lexan and board or perhaps sanding around the edges.  Useless with woodwork which is why i'm converting rather than scratch building ....  ???
clickhea
  • Last login:August 09, 2019, 07:33:40 am
Re: Best way to make pushbutton holes larger?
« Reply #1 on: October 25, 2008, 03:42:57 pm »
iam gonna have to nominate the router for this job.
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
« Reply #2 on: October 25, 2008, 04:12:45 pm »
drill with a sanding drum.
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #3 on: October 25, 2008, 04:45:21 pm »
Or file it with a rounded wood file.
« Reply #4 on: October 25, 2008, 06:04:37 pm »
Dremmel.
Kevin Mullins
    • Me on Myspace
« Reply #5 on: October 25, 2008, 06:19:06 pm »
Hammer.
fatfingers
  • Got UltraStiks?™
« Reply #6 on: October 25, 2008, 06:31:54 pm »
Router.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
um3k
  • Last login:February 21, 2026, 08:43:04 am
« Reply #7 on: October 25, 2008, 06:42:33 pm »
Clamp another piece of scrap over the hole.   Mark the center of the hole on the scrap and use your favorite forstner/spade bit.
« Reply #8 on: October 25, 2008, 08:31:45 pm »
wood or metal?
dremel either way, just use either a grinder bit or a sander bit
Xiaou2
  • Last login:Yesterday at 10:53:07 am
  • NOM NOM NOM
« Reply #9 on: October 25, 2008, 08:47:40 pm »
 Dremels stink.   Dont even bother with them.   You would use like 10 little sanding
drums, and it would take about 4hrs to do.
 I 2nd the drill + sanding drum.
 Of course, if you really want fast results,  they sell a special type of drum
made of metal.  It shaves wood like hot butter... and outlast sandpaper drums
by miles.
Xiaou2
  • NOM NOM NOM
« Reply #10 on: October 25, 2008, 08:55:46 pm »
 Microplane drums.  1" diameter is $10.99 at woodcraft.
Blanka
« Reply #11 on: October 26, 2008, 03:07:37 am »
Is it metal or wood. If wood, you might have succes with a regular spade bit if you put a dummy sheet underneath to put the center pin in.
dailygeek
« Reply #12 on: October 26, 2008, 05:12:12 am »
wood with lexan on top.
« Reply #13 on: October 26, 2008, 09:15:56 am »
10 sanding drums and 4 hours for a couple of millimeters?  perhaps your technique differs from mine but I made 16 button holes and 2 joystick holes a couple millimeters bigger in about 20 minutes using 1 sanding drum.
mountain
  • Trade Count: (+9)
  • Last login:March 06, 2026, 07:42:38 am
    • Mountain Jukeboxes
« Reply #14 on: October 26, 2008, 11:00:33 am »
I would probably cut the correct hole size in a piece of scrap MDF and center it over the existing hole using carpet tape. Then whip out the router with a flush cutting bit and open it up that way.
Or use a 1/2 round file.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:April 05, 2026, 08:28:15 am
« Reply #15 on: October 26, 2008, 11:36:07 am »
I would put a proper size hole in a piece of scrap wood, then clamp the scrap wood over the control panel with the holes properly lined up, then use a Fostner's bit. I would think that would work perfectly.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Franco B
« Reply #16 on: October 26, 2008, 12:29:15 pm »
2nd'd
Jack Burton
« Reply #17 on: October 26, 2008, 05:12:12 pm »
Hi folks
How many buttons are we talking about?  If it's less than 8 and only a couple of millimeters I would just get out a file.  I filed out the holes on a wooden panel with 14 buttons in less than an hour.  If you take you time and watch carefully the holes will still be "perfectly" circular, and the lip on the button will hide any mistakes you made.
pmilnes
  • Last login:November 09, 2008, 03:15:26 pm
« Reply #18 on: October 29, 2008, 12:43:54 pm »
Hell, you should do it the American way:
Step one - try to use the existing hole, since most people won't notice the difference.
Submit it for an RFQ, get bids from a MINIMUM of three vendors, then compare quotes.  Once you get the quotes, beat up your prospective vendors for a lower price.  Threaten to outsource to Mexico.  Then, outsource to Mexico.  When Mexico proves over time to be too expensive, outsource to China.  You are compromising on quality with China, but it looks good on paper.  Tell anyone that notices drop in quality that your specifications were clear, and any quality drop is justified by the additional savings.  Get a promotion based on the cost savings before your bad business decisions are noticed and catch up to you.
ahofle
    • Arcade Ambience Project
« Reply #19 on: October 29, 2008, 12:57:43 pm »
Ding ding ding ding!
This should also work with a hole saw bit, and maybe even a spade?
_Iz-
  • Last login:Yesterday at 10:23:42 pm
  • Time to coin up!
« Reply #20 on: October 29, 2008, 03:20:58 pm »
I like the router + template idea the best. It might work with a holesaw but it's an invitation to disaster to try it with a spade bit.
