Poll
What do you (or will you) use for the display in your cab?
Actual arcade monitor
24 (25%)
TV
25 (26%)
CRT Monitor
28 (29.2%)
LCD Monitor
14 (14.6%)
Something else
2 (2.1%)
I don't have a cab...
3 (3.1%)
Total Members Voted: 94
Author Topic: [POLL] - What do you use for your display?  (Read 3875 times)
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« on: October 15, 2007, 11:20:44 pm »
This post isn't to discuss monitor or displays, I just want to see what everyone is using so hopefully it's OK in the Main forum.
If you have more than one cab, pick your favorite or the one you use most or whatever criteria you want.  :)
Personally, I haven't decided yet.. I have a 20" LCD to use but if I get a full-size cabinet from an arcade place, I may throw a bigger TV in there since it'd be designed for something larger...
metahacker
  • Last login:January 17, 2024, 03:09:39 am
Re: [POLL] - What do you use for your display?
« Reply #1 on: October 16, 2007, 03:21:30 am »
might i suggest splitting up TV into S-Video, Composite and Component?
tikbalang
  • Last login:May 07, 2013, 05:04:54 pm
    • MAME BootCD's for DOS
« Reply #2 on: October 16, 2007, 09:00:41 am »
is this only for cab owners?
  • Last login:Yesterday at 05:46:43 pm
« Reply #3 on: October 16, 2007, 09:14:02 am »
I like the look of an actual arcade monitor but I used an LCD in my last one and it looks OK.  I'm the only one who actually notices a difference.
Neilyboy
  • Last login:October 08, 2025, 08:19:14 am
  • what day is it...
« Reply #4 on: October 16, 2007, 09:45:43 am »
I am going to be using a 27" flat tube crt tv in my mame machine. I picked it up for 50 bucks last night. good find off craigslist.
Neil
« Reply #5 on: October 16, 2007, 09:48:10 am »
Can we assume this is MAME cabs only?
kelemvor
« Reply #6 on: October 16, 2007, 08:09:57 pm »
Well, don't vote for someone else's cab if they post here but I guess it doesn't matter.  Not like this is official or anything.
And as for other cabs?  Doesn't matter to me.  If you built it, what'd you use?  Just post the details in a post if it's something other than Mame.
« Reply #7 on: October 16, 2007, 08:11:10 pm »
what if I'm using two types in a jukebox?
« Reply #8 on: October 16, 2007, 08:51:28 pm »
arent TVs technically CRTs?
anyways, Im using a 27" VGA CRT based monitor. the kind you find in bowling alleys above the lanes that display the frame and score........
I know this because some of the other ones for sale had bowling score burnin. I bought it 5 years ago for like $125 and I still <3 it.
kelemvor
« Reply #9 on: October 16, 2007, 09:22:32 pm »
TVs are CRTs but they aren't Monitor.  TVs have tuners in them and monitors don't.  However in this post I was referring to a CRT computer monitor.
gonzo90017
« Reply #10 on: October 17, 2007, 12:27:19 am »
!7" Lcd WideScreen Monitor.
danny_galaga
  • Last login:April 17, 2026, 10:06:35 pm
    • dans cocktail lounge
« Reply #11 on: October 17, 2007, 02:51:06 am »
15" pc monitor in my cocktail. would like to build an upright some time and ill go 21" but not sure what ill use. 21" pc monitor is dirt cheap. until i do anything new, ill just run a 10M AV cable from my pc to my bedroom tv so i can play mame in bed (",)
Anubis_au
  • Last login:January 15, 2023, 10:12:32 pm
  • Ever danced with the Devil in the pale moonlight?
« Reply #12 on: October 17, 2007, 07:28:44 am »
20" gen-you-ine arcade monitor.
Purist all the way, baby!
Havok
  • Trade Count: (+17)
« Reply #13 on: October 17, 2007, 07:36:32 am »
20" 4:3 LCD. Next cab just might go widescreen!
Less weight, less heat, less energy and I don't get a irradiated when I play arcade games...
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #14 on: October 17, 2007, 12:46:57 pm »
s-video to tv in one and a 21in crt nec in another.  overall I prefer the pc monitor as things are much clearer espeically vertical games.  On the other hand, the tv is huge and things don't look blocky.
Next cab will probably be lcd, woody style.
Herk
  • Last login:December 30, 2024, 06:58:17 pm
« Reply #15 on: October 17, 2007, 02:31:18 pm »
Hey,
I use a 22" widescreen 16:10 LCD
Herk
bigh4th
  • Last login:March 02, 2009, 11:05:35 pm
« Reply #16 on: October 18, 2007, 08:49:50 am »
I'm rockin a 19" curved CRT monitor in my cocktail.  Main reasons for this is because i got the monitor for free, it was less than 5 years old, it was free,  I didn't have to buy a special adapter to use it, and it was free.
I removed it from its case and mounted it to the top of my cabinet so I can open it and get to stuff that I need to, so I could easily move the cabinet without needing to re-position the monitor afterwards, and so I could use a bezel.
Just an FYI, Even after you properly discharge a CRT, you may need to do it again if you leave it laying around for a few days.  I had mine apart for a week or two (tube sitting on a towel) and had a couple of thunderstorms roll through.  I dont know if it was static from handling or from the t-storms, but that thing nipped me twice.  It wasn't anywhere near full blast, but it didn't feel good either.
-Harry
« Reply #17 on: October 18, 2007, 09:18:55 am »
It happens because the first discharge wasn't 100% of the buildup, it was only most of it.  Over time the remaining charge gathers itself and looks for a way out as well.  That is the second zzzzzap.  Think of it like water.  You can dump out the bucket by throwing all the water out... but if you don't let it drip for a minute afterwards, you'll still have a little water in it.
bigh4th
« Reply #18 on: October 18, 2007, 10:42:01 am »
I dunno.  I understand what you're saying and you're right.  However, I discharged it 3 times in 20 minutes before I removed the lead from the tube.  Monitor had been unplugged from the wall for a few days before I did it as well.  It still could've held a charge I guess.  Stranger things have happened.
Either way, you gotta be carefull.  I'm just lucky the tube was secured before it happened, because I flinched both times and very possibly could've dropped it.
-Harry
severdhed
  • RIP Dinosaur Hippo
« Reply #19 on: October 18, 2007, 03:09:09 pm »
Im using a 19" LCD monitor in my cabinet.  it originally had a 20" arcade monitor, but it was really burnt when i got it, i wanted to change the monitor angle and fitting a CRT at the angle i wanted just wasnt going to work...so an LCD seemed like the perfect choice.  i am very happy with the way it looks.
« Reply #20 on: October 18, 2007, 03:20:16 pm »
It takes far longer than 20 minutes for that leftover charge to gather itself.  Always discharge the monitor before you touch anything to that anode.  Even if the thing has been unplugged for months you still pretty much have to discharge it... for every 50 that don't shock you the one that does is the problem.
Anubis_au
« Reply #21 on: October 18, 2007, 09:20:11 pm »
Bit of a thread highjack, but could you post a pic of your cab, Herk. I've haven't yet seen a cab with a widescreen monitor... wouldn't mind seeing how it looks...
