Author Topic: Do you use glue on your balltops?  (Read 3512 times)
  • Last login:Yesterday at 05:46:43 pm
« on: October 07, 2007, 05:01:47 pm »
It keeps coming unscrewed while playing - would a dab of glue permanently attach it?  What if you wanted to make a switch?  I don't know how else to put this but how do you guys keep your balls in place?
Cornchip
  • Last login:December 27, 2023, 10:23:11 am
  • Thinking up more crap....
Re: Do you use glue on your balltops?
« Reply #1 on: October 07, 2007, 05:08:09 pm »
  This post sounds a little funny. I could suggest a way to keep your balls where they belong. Try a little 'clear nail polish' on the threads. It will be removable should you ever feel the need to take your balls some place better.
 Cornchip.
fjl
  • Pixels Rule!
« Reply #2 on: October 07, 2007, 05:17:07 pm »
Have you tried tightening them with tools like pliers? Just be sure to add some kind of medium to hold it so they don't get all scratched up while you tighten it.
PsychoAU
  • Last login:October 04, 2020, 12:27:19 am
« Reply #3 on: October 07, 2007, 08:00:00 pm »
Use a strip of Teflon tape that you would find in the plumbing section of a building supply store.  That worked wonders and it is not permanent.  Wrap it around the teeth and your top will stay on (unless it is ladies night at the bar).
Kevin Mullins
    • Me on Myspace
« Reply #4 on: October 07, 2007, 09:48:57 pm »
Having come from an automotive background... I'd use a couple drops of Medium Strength Loctite.
Loctite
  • Last login:April 08, 2026, 06:31:20 pm
« Reply #5 on: October 08, 2007, 11:53:17 am »
The title of this thread reminds me of the joke about the golfer taking his wife to play golf.
While they were playing, snow starting falling and the ground got white.
Wife asked hubby how will they find the white balls in the snow.
He said ordinarily they play with blue balls, but he didnt bring any.
They got up to the next tee, snow was falling heavy by then. She asked a man waiting to tee off, "Pardon me sir, but do you have blue balls?"
The man answered, "No ma'am, Ive wearing thermal undies."
brian_hoffman
  • Last login:July 02, 2011, 09:02:20 pm
« Reply #6 on: October 08, 2007, 12:13:36 pm »
Id agree Loctite
The blue not the red.
Pliers will just scratch the ball.
shardian
« Reply #7 on: October 08, 2007, 12:44:55 pm »
Use channel lock pliers, and wrap the ball in a sock or something thick like that.
superbigjay
  • Last login:October 22, 2023, 02:50:03 pm
  • I'll always be a kid...
    • superbigjay website
« Reply #8 on: October 08, 2007, 08:24:04 pm »
Id agree Loctite
Loctite here too Javeryh.
As Brian said, use the blue one.
(blue is removable, red is more permanent)
the blue will be strong enough to keep your balls at their proper place   :laugh2:
but you'll still be able to remove it if you ever need too.
Jay  :cheers:
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #9 on: October 08, 2007, 08:46:01 pm »
That's what I use on my Ultrastiks, haven't come loose once.
bigh4th
  • Last login:March 02, 2009, 11:05:35 pm
« Reply #10 on: October 08, 2007, 09:20:53 pm »
as the "leet speek" kiddies would say,
lok tyt FTW!!!111!onetwobucklemyshoe
Seriously though, weak lock-tite will do the trick.  A dab of elmers school glue on the shaft threads may work as well.
-Harry
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #11 on: October 09, 2007, 12:38:24 am »
The way I always understood it, you use blue if you want the option to break the bond with physical pressure (e.g., wrench, screwdriver, etc.). Red provides a higher strength bond that can be broken with heat but not pressure. Both are removable. For this application, red is definitely not the way to go.
I secured mine with a vicious physical twist and they are fine. But I'd be interested to see how well Teflon tape works. I bet a dab of hot glue would work OK too.
-pmc
Jouster
  • Flap, Flap...Crash
« Reply #12 on: October 09, 2007, 12:57:41 pm »
I've been using hot glue...it holds for a little while, but doesn't seem to last more than a day or so.
Maybe I'm just rougher on my balls than others...I don't know.
I'm gonna try the Teflon tape thing, I've got some of that around here somewhere.
Jouster
knave
  • Last login:March 24, 2026, 03:52:12 pm
« Reply #13 on: October 09, 2007, 01:05:08 pm »
Can't...ressist...smirk.    :-X
 :laugh2:
(sigh)
shardian
« Reply #14 on: October 09, 2007, 02:44:13 pm »
-Harry
What does FTW stand for? That  is an acronym I have never understood.
« Reply #15 on: October 09, 2007, 02:49:04 pm »
Eff The World
EDIT:  for the hell of it, I looked it up... we always said it as eff the world... apparently it has evolved into For The Win.
Odd.
« Last Edit: October 09, 2007, 02:53:45 pm by ChadTower »
shardian
« Reply #16 on: October 09, 2007, 03:00:29 pm »
That is what I thought it stood for. However, some people use it in very unorthodox ways if that is the case. Always made me think it meant something else in "internet lingo".
bigh4th
« Reply #17 on: October 09, 2007, 06:27:33 pm »
My understand is "FTW" stands for "For The Win".
I just found that out a few days ago.
-Harry
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #18 on: October 09, 2007, 11:28:38 pm »
I've *ALWAYS* heard it as [blank] the world.  Only hear the win thing here.
dstone
  • Last login:January 14, 2021, 01:03:52 pm
    • Vectorcade
« Reply #19 on: October 10, 2007, 12:22:56 am »
I was always under the impression that the Teflon tape was used to form a water-tight seal between the threads, not to hold the parts together. I think it packs the tape into the gaps in the threads to prevent leakage, so I'm not sure how that would work out. I'd say just use the Loctite, that would be the safest bet.
« Reply #20 on: October 10, 2007, 09:21:06 am »
You're right, but it also sort of wedges the part stuck, and does hold it pretty well.
