Poll
What version of Mame do you run in your Cab?
The latest version (usually)
.9x
.8x
.7x
.55 or close
..36 or close or Lower than
Author Topic: Poll: What version do you use in your Cab?  (Read 2480 times)
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« on: December 24, 2005, 03:01:46 am »
I use .79
It was the last version to recognise a Bogus version of Galaga that gives you fast fire without enabling a cheat.
« Last Edit: December 24, 2005, 06:10:52 am by loadman »
daywane
  • GRRRR!
Re: Poll: What version do you use?
« Reply #1 on: December 24, 2005, 05:39:09 am »
56,most of time
79 on other pc
36 on ms pac
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #2 on: December 24, 2005, 06:02:16 am »
.82 for almost everything.
.9something for robotron :)
danny_galaga
  • Last login:April 17, 2026, 10:06:35 pm
    • dans cocktail lounge
Re: Poll: What version do you use in your Cab?
« Reply #3 on: December 24, 2005, 07:05:00 am »
im a 78 man. first version i downloaded. tried a later one and it took forever to load roms. im happy with whatever roms i can play on 78 so ill stick to it. for any project i might have that requires specific games i might try earlier...
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« Reply #4 on: December 24, 2005, 09:50:47 am »
.79 is the first / only version I have ever downloaded, and have the full pack of roms to go with it.  I don't see any reason why I would need to switch.  If it works, don't break it. (unless your doing a mod to your cabinet.   ;D )
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
jhanson
« Reply #5 on: December 24, 2005, 09:53:03 am »
I've used .78 in two cabinets, .36 in another, and .86 in the latest one.  I chose the .7x option though, as .78 is what is in my personal cabinet (as opposed to the ones I built for other people).
subcriminal
  • Last login:November 20, 2019, 12:58:00 pm
« Reply #6 on: December 24, 2005, 01:12:59 pm »
I run 089 because that's the romset I have. I only play up to about 1980's to 1992ish games.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #7 on: December 26, 2005, 01:36:16 pm »
I use MAME .73 for the romset I have.
Q*Bert_OP
  • Oh yes, we did!
« Reply #8 on: December 27, 2005, 12:31:18 pm »
.98 for me...It allows me to run those newer as well as classic games quickly
brian23
  • Last login:September 07, 2011, 03:52:01 pm
« Reply #9 on: December 28, 2005, 10:32:34 am »
.102 is the romset I have
toasty
  • Last login:October 10, 2019, 11:48:47 am
  • Purveyor of Fine Latex Products
« Reply #10 on: December 28, 2005, 04:03:31 pm »
I had assumed it was best to always use the most current version available.  Looking at the poll and the replies, I gather that isn't necessarily the case.  What is the benefit of using the older versions?  Is it the case that some older versions support roms that the newest version does not?
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #11 on: December 28, 2005, 04:07:49 pm »
Not necessarily an advantage/disadvantage. Mostly, there isn't a real reason to go through the hassle of updating.
toasty
« Reply #12 on: December 28, 2005, 04:25:52 pm »
^^gotcha, that makes sense.  So if I'm looking to do a fresh install on a new computer, there's no real reason to consider anything other than the most current version?
brophog
« Reply #13 on: December 28, 2005, 04:37:03 pm »
Assuming your computer is relatively new (last couple of years), then go ahead with the newest release.
toasty
« Reply #14 on: December 28, 2005, 04:59:41 pm »
yeah, it's got plenty of juice by MAME standards...
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #15 on: December 28, 2005, 05:07:02 pm »
.55 on the bartop
.69 on the cab I had and sold.
.69 on my PC with a new version (.9x I think) for Golden Tees and a few newer games)
first off your and idiot
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #16 on: December 28, 2005, 06:51:22 pm »
I think I'm still using .9x. I upgraded sometime either just before or after the .100 release
Signature tags are dumb.
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #17 on: December 29, 2005, 02:36:24 pm »
i just recently upgraded from .71 to .78...
I tried a newwer version but I didn't like tghe way some of the games came out....
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
« Reply #18 on: December 31, 2005, 11:30:27 pm »
We're running v. 94 on ours - like most here, it's the one for the set I have.  Also, any version past 94 tends to cause Jurassic Park not to run properly, and to my wife, that's just not acceptable.
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
« Reply #19 on: January 01, 2006, 06:12:34 am »
Sadly the latest, I haven't figured out how to properly make .71b work properly with my EasyMAMECab setup, because it is hell getting the modelines to work properly, and unfortunately .71b uses a different command format in the advmame.rc file...
sportswizdan
  • Last login:April 05, 2012, 02:13:39 am
« Reply #20 on: January 01, 2006, 09:04:56 pm »
Will the Golden Tee Golf stuff run 100% on a .74 rom set? Thanks in advance
Dan
pointdablame
« Reply #21 on: January 02, 2006, 01:26:48 am »
Dan
Except for the oldest versions (GTG and GTG2), Golden Tee wasn't put into mame until very recently.   .9x or .1xx I think.
So no, you won't play them on .74, and the newer games won't even be included in a .74 rom set. (except for the two I mention of course, which work fine in my .69 install)
« Last Edit: January 02, 2006, 01:28:25 am by pointdablame »
spriggy
  • Last login:October 07, 2025, 01:33:26 am
« Reply #22 on: January 02, 2006, 02:17:43 pm »
Still like my 0.71b,  since it's inception.
"Once a Knight, always a Knight.   Twice a night.. and your doing alright!!" ::)
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
« Reply #23 on: January 02, 2006, 09:12:40 pm »
I used to run .74 for the longest time,  but since I got a new PC I now run 9.x.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #24 on: January 02, 2006, 10:51:37 pm »
I believe the newer GT's were introduced in .94u2 maybe?  I built my whole cab with that in mind and .94 came out the same week I finished.  Pure luck. :)
loadman
    • MaLa
« Reply #25 on: January 04, 2006, 03:17:29 am »
I have locked the Vote:
I guess the answer is whatever works for you with the romset you hold in most cases.
Thanks!  ;D
Good to know I'm not the only one intending to stay with a two digit mame version for the foreseeable future.
