Author Topic: How good are the 49 ways for fighting games?  (Read 2294 times)
KungFuJoe
  • Last login:February 05, 2006, 05:10:10 am
« on: August 24, 2005, 04:28:05 am »
Seems like those 49 way sticks can do it all, but I'm assuming they have some type of resistance (like Road Runner).  Being a huge Street Fighter 2 fan, I'm curious to see if anyone has tried those capcom side to side fighters with the 49 way.
Also, how much of a hassle is it to switch modes?  Is it just a matter of flipping open your cp (assuming you have it on a hinge) and flipping a switch.  Realistically, if switching takes more than 20 seconds (including the time it takes to open and close your cp) it WILL become a nuisance.
Re: How good are the 49 ways for fighting games?
« Reply #1 on: August 24, 2005, 05:36:11 am »
They will work but you say you are a big SF2 fan so I doubt very much you would want to use them for fighters.
You can put a switch on your CP or use software switching.  Either way you wouldn't need to open your CP.  Personally I would use software switching to avoid having an extra switch.
KungFuJoe
« Reply #2 on: August 24, 2005, 01:19:11 pm »
Thanks for your reply.   Looks like I'll be going with a couple P360s for my fighting games...I would have considered 49 ways for player 3 and 4, but I already have a couple firesticks laying around that I'm going to gut for that.
« Reply #3 on: August 24, 2005, 04:23:15 pm »
Don't get me wrong they are great sticks...just P360's/Supers/etc. are generally preferred for fighters imo.
ahofle
    • Arcade Ambience Project
« Reply #4 on: August 24, 2005, 05:38:49 pm »
Can anyone with the Happ 49 ways comment on the problem with not returning to center quick enough?  The retroblast reviewer mentioned that was one of his biggest beefs with it (letting go of the joystick would take a split second too long to return to center, making games like bomberman difficult).  He mentioned that they were supposed to 'break in' and work better over time.  Has anyone found that to be true?
KenToad
  • Last login:Yesterday at 02:16:07 pm
  • Flap Flap Flap
« Reply #5 on: August 25, 2005, 10:08:05 am »
Ahofle,
Yeah, they have definitely broken in over time.  They are near perfect for me now.  I love them, actually, although definitely not the best feel for fighting games IMO (I have a modular panel with supers).  Also, I think also that RandyT's suggestion to grease every 49 way with white lithium grease is also definitely the way to go.  That way, they are a little better centering and don't creak.
Hope that helps.
Cheers,
KenToad (aka Retroblast 49 way reviewer)
ahofle
« Reply #6 on: August 25, 2005, 06:21:46 pm »
Thx for the info KenToad! :)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #7 on: August 25, 2005, 06:52:58 pm »
but wait, what if I used BLACK lithium grease instead of white?  Will I be in any kind of trouble?
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #8 on: August 25, 2005, 11:49:04 pm »
No trouble at all... in fact, the Rev. Jesse Jackson will give you a big pat on the back.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #9 on: August 26, 2005, 10:54:41 am »
but seriously tho, it wont damage my joystick or anything right?
Kremmit
  • - AHOTW -
« Reply #10 on: August 26, 2005, 10:46:41 pm »
I *think* that lithium grease is pretty much lithium grease.  I have no experience with the black stuff (didn't even know it existed), so I can't say for sure.  If the package says it's ok to use with plastic, then you ought to be fine.
NoOne=NBA=
« Reply #11 on: August 26, 2005, 11:05:23 pm »
I *think* white lith is lighter than ordinary lithium grease.
No pun intended.
I have a can of "lithium general purpose" grease that is lighter than bearing grease, but heavier than white lith.
I also *think* that using the heavier grease will make the joystick sluggish on return-to-center, rather than helping it.
I've had really good luck using silicone spray on my joysticks.
