Author Topic: X-Arcade Buttons Compatible With I-PAC?  (Read 1914 times)
smokdya
  • Last login:June 17, 2005, 02:53:54 am
« on: June 01, 2005, 03:49:31 pm »
Hey guys, I searched for this question but could not find an answer.  I was curious if the X-Arcade Buttons will work fine with an Ultimarc I-PAC?  From what I have read, I assume they will but wanted to make sure before I order.
Also, is there a big difference between the X-Arcade buttons and the Ultimarc buttons?  Im ordering my joysticks from Ultimarc as i understand they are better then X-Arcades.  However I would like to save a little money on the buttons if possible.
« Last Edit: June 01, 2005, 03:52:41 pm by smokdya »
Stingray
Re: X-Arcade Buttons Compatible With I-PAC?
« Reply #1 on: June 01, 2005, 03:59:36 pm »
A button's a button. It's just a switch.
-S
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: June 01, 2005, 04:02:12 pm »
I'm plannin on guttin an xarcade for all those black buttons.   ;D
I'm gonna hook it up to a GP-Wiz49 from www.groovygamegear.com  though the hook up is no different from an ipac.
Tiger-Heli
    • Tiger-Heli
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #4 on: June 01, 2005, 05:34:04 pm »
An expensive 49-way setup ruined by x-arcade buttons makes me sad.  :'(
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #5 on: June 01, 2005, 05:43:42 pm »
I should go buy 8 happs black buttons, huh.  ;D
monkeybomb
« Reply #6 on: June 01, 2005, 05:46:50 pm »
Not sure if your serious, but the buttons are realy different.  I would deffinately buy happs buttons from ponyboy.
KenToad
  • Last login:Yesterday at 10:47:51 pm
  • Flap Flap Flap
« Reply #7 on: June 01, 2005, 05:54:41 pm »
Yup, X-Arcade buttons are twangy because the springs tend to be loose and really clicky because they don't use cherry switches.  At least that's my non-technical way of describing it.  I used them on my first CP and then ordered some Happ buttons, which proved much better in the opinions of myself and my guests.  Now I'm still using the leftover X-Arcade buttons for administration purposes on that original CP and on my huge Multi-Williams bartop that I just built and posted over in Project Announcements--a dual 49-Way joystick setup with dual Rotary interfaces wired through Druin's that makes me happier and happier every day.  Now I must find more time for testing ;D.
Cheers,
KenToad
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #8 on: June 01, 2005, 06:04:03 pm »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #9 on: June 01, 2005, 06:16:28 pm »
Well ya sold me!  ;D
I sent Ponyboy a PM.  How is it he gets that good deals?  Bulk?
smokdya
« Reply #10 on: June 01, 2005, 08:22:37 pm »
Thanks for the comments guys, I decided to just go ahead and order the buttons from Ultimarc.  They cost a little more, but I have put alot of work into this cab and dont want to skimp on the controls.  ;D  I just ordered all of player one controls and will order the rest when I get paid.
