Author Topic: Best way to mount joysticks?  (Read 6051 times)
Sinner
  • Last login:September 17, 2024, 11:27:45 am
  • Half the lies they tell about me, aren't true...
    • Geek My Gadget
« on: May 26, 2005, 03:01:44 pm »
I have HAPP Supers, and T-Stik plus joysticks...what is the best way to mount hem?
The CP is made of wood.
Is it better to route the top and bolt through, or route the bottom and mount from underneath?
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: Best way to mount joysticks?
« Reply #1 on: May 26, 2005, 03:13:44 pm »
For my tsticks I routed out the top, used flat screws and wood putty to fill in.
I like the height and it looks good under a overlay.
Later,
dabone
ethous
  • Last login:June 11, 2025, 09:33:36 am
  • Life is prescious enjoy every minute
« Reply #2 on: May 26, 2005, 03:17:24 pm »
I would routed out the hole counter sink the holes then putty the holes and add a cpo on it.
Would be a really nice finish.
Sinner
    • Geek My Gadget
« Reply #3 on: May 26, 2005, 03:18:31 pm »
Later,
dabone
You haven't run into any problems doing this?
Do you think the supers could be done the same way?
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #4 on: May 26, 2005, 04:06:38 pm »
My personal preference is to use T-nuts on the top of the panel and mount the joysticks from underneath.
I routed out 1/4" of material underneath to raise the joysticks higher.
The advantage of this method is that you can change out the joysticks very easily without having to disturb or possibly ruin your control panel top & overlay.
Threaded inserts are another option, but the ones I can find are 3/4" in length which prevents you from routing out any material in the 3/4" MDF.
Q*Bert_OP
  • Oh yes, we did!
« Reply #5 on: May 26, 2005, 05:16:48 pm »
Use carriage bolts.
AlanS17
    • AlanS17
« Reply #6 on: May 26, 2005, 05:24:03 pm »
It completely depends on what joystick you have, whether you're installing in wood or metal, the length of the shaft, and how high your want the joystick to come up. It also depends on what type of games you plan on playing.
For example, dabone mentioned that he routed out the top for his t-stick plus. This is how I had my Supers.
However, I'm going to just screw my t-sticks directly into 3/4 wood from underneath without routing. This will keep the ball top low to the control panel. Of course, this is for a classics cocktail cabinet.
In other words:  different application -> different mounting method.
Sinner
    • Geek My Gadget
« Reply #7 on: May 27, 2005, 08:30:37 am »
In other words:
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #8 on: October 28, 2005, 11:48:45 am »
Doe anyone have any valuable comments to add about the diameter of the hole of you mount under.  IE, enough room for the throw of the stick and have the dust cover (plastic washer thing) still cover the hole with the stick fully thrown.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #9 on: October 28, 2005, 12:06:43 pm »
I just use 1-1/8" bit, and route some material from below (1/4"-3/8").  Gives me plenty of joystick range..
markrvp
  • NFL Expert
« Reply #10 on: October 28, 2005, 12:55:45 pm »
I think 1-1/8" to 1-1/4" is standard for a 3/4" panel.
Mark70
« Reply #11 on: October 28, 2005, 01:06:28 pm »
I guess I'll do my mock up that way since I don't have my router yet.
I take it the short sleve on the Happ Supers is designed around undermounting on a piece of 3/4" material.
ahofle
    • Arcade Ambience Project
« Reply #12 on: October 28, 2005, 01:07:39 pm »
That's what I did, and I haven't had any problems in 2 years of frequent playing.
ften
  • Last login:March 06, 2022, 10:20:43 pm
  • Beep Beep
    • Fathertom.net
« Reply #13 on: October 28, 2005, 03:18:09 pm »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #14 on: October 28, 2005, 07:24:18 pm »
will a super mount to where a wico leafswitch was or visa versa?  Will the holes line up, I mean?
Breaker
  • Last login:December 10, 2024, 11:38:20 am
« Reply #15 on: October 28, 2005, 09:28:01 pm »
Hi all,
I've been meaning to ask this question and it's pretty close to being on topic for this thread. ..
I'm wondering how thick the typical metal control panel is? I too plan to route out underneath but I'm also thinking about routing the top and inserting a metal plate onto which I'll connect the joystick - this method will allow for extra joystick height. Everything will be covered with laminate in the end so I think this method might work but I'm not sure how thick the metal plate should be - I'm thinking 1/8". Comments?
Thanks,
Breaker.
markrvp
  • NFL Expert
« Reply #16 on: October 28, 2005, 09:44:39 pm »
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #17 on: October 29, 2005, 11:09:26 am »
I did something similar with J-Sticks on an upright. The difference for me was that I drove the (carriage) mounting bolts from the TOP of the panel so that they'd go all the way through. The bolt-heads are counter sunk so they can be covered with artwork. Ball-tops are low to the panel and the mount is rock solid.
-pmc
