Author Topic: Stainless steel dust covers *Other custom work too*  (Read 10004 times)
Franco
« on: May 21, 2005, 03:19:44 pm »
Quite a few people seem to have stainless joysticks on there cabs but I havent seen any with stainless dust covers (the bit that stops dust getting in your CP around the joystick shaft).
I made some for my cab
« Last Edit: May 25, 2005, 05:39:08 pm by Franco »
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
Re: Stainless steel dust covers
« Reply #1 on: May 21, 2005, 03:29:22 pm »
Those are definitely cool. Any idea what they might cost?
Goz
  • KOTA
« Reply #2 on: May 21, 2005, 04:00:26 pm »
 Franco,
 They look really nice.
Are they hard to clean? (fingerprints)
Do you find that they are rougher on the CPO when they move arround?
-Goz
Franco
« Reply #3 on: May 21, 2005, 04:50:21 pm »
Depends on what price I can get the material for and how much interest there is. I should imagine somewhere within the region of $10 a pair.
They would either be made from high quality stainless with a very high quality turned finish or from high quality magnetic stainless steel if you wanted an ultra smooth ground finish.
They could also be custon made to each byoac'ers sizes and profiles (either with an oblique edge or tapered like mine) maybe even with custom grooves on the face?
Franco,
-Goz
Mine are ground and I have had no trouble with fingerprints or cleaning (I have not had to clean them, as such, even once). They have only been wiped with a duster when I have dusted my CP. As for fingerprints, I have just tried to leave prints on mine and they just are not leaving a mark. If they did, im sure they would just wipe straight off. This would be even less of an issue with a
Knievel
    • Knievel Kustoms
« Reply #4 on: May 21, 2005, 07:12:45 pm »
Hey Franco those are really nice. I have a feeling the guy I made the X-Men CP for would love a set, I'll send him the pic.
Nice cab too, I somehow missed it before. I did a take-off on that Arcade Classics marquee not too long ago, it would fit in better with the color scheme you've got going. I'll post it in your project thread for you to check out.
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #5 on: May 21, 2005, 10:56:52 pm »
I would definitely be in for a pair.
crashwg
« Reply #6 on: May 21, 2005, 11:02:11 pm »
Ooh ooh ooh, me too!  ;D
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Franco
« Reply #7 on: May 22, 2005, 06:22:16 am »
Ill look forward to seeing the marquee knievel.
If anyone would like a pair, post or PM me the following info and I will see what I can do.
DIMENSIONS:
D1 - Outside Diameter
D2 - Bore Diameter
D3 - Width
EDGE PROFILE:
A - Flat with chamferd corners to remove sharp edge
B - Full radius and chamfer.
C-
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #8 on: May 22, 2005, 04:15:18 pm »
Franco-
Figured if we're taking measurements, we oughtta post 'em, so you don't get 50 people all measuring the same joystick.
Here are the measurements for a Wico leafswitch joystick dustwasher.  These are almost certainly good for a Happ Perfect 360 joystick as well, but since I don't have one of those, I wont' say that's for sure.
d1 - outside diameter:  2 inches / 51 mm
d2 - bore diameter:  7/16 inch / 11 mm  update:  This measurement was VERY snug.  I'd go with at least 15/32 or 11.5 mm next time.
d3 - thickness:  1/16 inch / 1.5 mm
Original Wico dustwashers have a dead flat edge profile, but I like B:  Full Radius and chamfer.
You've got PM!
« Last Edit: August 31, 2005, 03:06:37 am by Kremmit »
Franco
« Reply #9 on: May 23, 2005, 04:26:22 am »
I have just finished making four of the above washers to Kremmits Wico dimensions. Ill post some pics of them tonight.
« Last Edit: May 23, 2005, 04:31:38 am by Franco »
Franco
« Reply #10 on: May 23, 2005, 10:07:20 am »
As promised, here are the pics of the washers I have made for Kremmit, just to give you an idea.
If anyone else wants some post or PM
Kremmit
  • - AHOTW -
Re: Stainless steel dust covers *New pics of the 1st new ones made*
« Reply #11 on: May 23, 2005, 12:09:29 pm »
Pretty, Pretty!
Grasshopper
« Reply #12 on: May 24, 2005, 04:47:25 pm »
Franco, the metal dust washers look great although personally I don't need them. But I'm wondering, do you have the facilities to manufacture anything out of metal? Could you for instance manufacture joystick mounting plates?
Franco
« Reply #13 on: May 25, 2005, 12:41:59 pm »
I can make pretty much anything within reason. Ive got access to CNC lathes, CNC Machining Centers, grinding M/Cs etc. I made the Stainless Joys you can see at the top of the thread.
Let me know the kind of thing you are after, ie dimentions etc and Ill see what I can do.
Mooshoo111
  • Last login:October 04, 2006, 01:03:04 pm
  • Roger is running...
« Reply #14 on: May 25, 2005, 12:48:40 pm »
Would you make things that aren't arcade related?
Flinkly
« Reply #15 on: May 25, 2005, 12:58:39 pm »
huh...wanna make the community steel handles for the happs 49-way?  randy says he's doing it, and slikstik said they would months ago, but no one has shown up with a product, and you could make them relatively special order, canceling out the need for adjustable sticks, which is what randy does best.
Franco
« Reply #16 on: May 25, 2005, 02:05:19 pm »
Dont see why not, what are you after?
Cant see this being too much of a problem. Just means I would have to buy in some more material, Ive just been using my personall steel so far. How much did Randy / Christian quote you, I dont want to give you a price that would be too high.
Send me some dimensions and Ill find out how much I can get some stainless for. How much interest do you think there would likely be? The more I make means the cheaper they would be, both in machining time and material.
Flinkly
« Reply #17 on: May 25, 2005, 02:43:31 pm »
well, you/we might just start a new thread, if this is indeed something you can make a part file for and machine right out.  i don't think either quoted prices due to the fact that neither has gotten around to making any, but you could check out randy's steel joystick prices and slikstiks prices, although slikstik is a bit expensive.
if everything come's out right, i might even be interested in another stick that i'd be the only buyer for (a williams 49-way stick).
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« Reply #18 on: May 25, 2005, 03:16:12 pm »
Franco,
Could you fabricate solid stainless steel 3" trackball rollers?
Franco
« Reply #19 on: May 25, 2005, 05:37:01 pm »
Okay. Ill get some material prices over the next few days and then start a thread if its viable. Bat tops will be the preferable design to make. Ill look into ball tops depending upon demand. I also made the stainless joys for my Happ Rotaries that you can see at the top of the thread. I also have a spare pair which I may be willing to sell.
Franco,
No problem. Send me the dimensions and quantity and Ill get a price for you. I actually made some Ms Pac man shafts for another board member which look similar to the rollers so they will be no problem what so ever as long as they are not too small.
« Last Edit: May 25, 2005, 05:41:30 pm by Franco »
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #20 on: May 25, 2005, 05:46:39 pm »
Franco,
Great idea!
also: "Ive got access to CNC lathes, CNC Machining Centers, grinding M/Cs etc."
<--- Jealous :laugh:
I want my own arcade controls!
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: Stainless steel dust covers *Other custom work too*
« Reply #21 on: May 25, 2005, 06:04:32 pm »
I would like 2 to 4 washers please.  ;D Where do I send my money?
Franco
« Reply #22 on: May 26, 2005, 01:35:45 am »
Do you want the same dimensons as the Wico's? Im making a couple of sets hopefully tomorrow or early next week so Ill do yours at the same time. Ill give you my paypal details once they are complete.
IntruderAlert
    • Intruder Alert
« Reply #23 on: May 26, 2005, 02:21:36 am »
I'll try to get you some specs on the rollers Franco unless someone else already has it.
Also,
I don't know if you have the equipment to do it but it would be really cool if you could etch the name of the cab into the tops of the dust washers.
You'd have to charge extra for that of course ;)
Franco
« Reply #24 on: May 26, 2005, 03:09:53 am »
Also,
Yeah, if you can measure them with a digital vernier or micrometer that would be ideal. I can machine them to within less than 0.0005" but obviously I need some accurate dimentions to start with. I imagine the bearing shaft of the roller would be fairly critical. I would also imagine you wouldnt want too high quality surface finish on the part of the shaft that contacts with the trackball otherwise you would not get enough friction and may lead to the trackball 'slipping'. Let me know on this issue too.
As for etching the washers, do you mean something like this:
I cant etch as such but we have a dot matrix marking machine which gives a pretty good result.
IntruderAlert
    • Intruder Alert
« Reply #25 on: May 26, 2005, 03:30:58 am »
I'm not sure..
Could you make the letters larger/thicker and curved around the washer instead of straight across?
Do you have any idea how much you'd need for each set of trackball rollers?
I don't have the proper equipment to measure precisely enough but
maybe someone could send you a worn out set for measuring purposes.
I'll look around..
Franco
« Reply #26 on: May 26, 2005, 04:24:08 am »
As far as I know I can only do text in straight lines, they can be any size though. We have key smith shops over here that do custom engraving, maybe you have facillities like that over your end?
As for a price for the rollers, I would imagine they would be around $30, depending on the tolerances and material etc.
See if you can find some sizes, maybe from the original manufacturer?
IntruderAlert
    • Intruder Alert
« Reply #27 on: May 26, 2005, 11:00:39 am »
Bob Roberts sells a Stainless Steel roller set for $8 but I have no idea if they are solid stainless steel or not.
http://www.homearcade.org/BBBB/parts.html
Franco
« Reply #28 on: May 26, 2005, 11:08:34 am »
I should imagine that they would be solid. It would actually be cheaper for them to be manufactured solid than with a bore.
Email Bob Roberts and find out. If they are I would go for it. I wish I could make them that cheap but as I am doing a one off order I would not be able to make them any less expensive.
Sounds like Bob's are a bargin to me!
whammoed
  • Last login:April 17, 2026, 12:27:07 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #29 on: May 26, 2005, 11:15:25 am »
***Franco does exceptional work***
Very precise.  He is obviously very good at what he does and must be using some nice machinery.
Highly recommended, you won't be dissappointed.
(I'm the one he did those ms pac shafts for.) ;)
thanks again Franco!
Franco
« Reply #30 on: May 26, 2005, 11:21:11 am »
Thanks mate, your too kind!  :)
KenToad
  • Last login:Yesterday at 10:47:51 pm
  • Flap Flap Flap
« Reply #31 on: May 26, 2005, 11:38:53 am »
I'm in the market for a ball top replacement for the Midway 49 Way Joystick, but I really want balltops for that old school nostalgia.  Just to let you know and btw all your work looks really great.
Cheers,
KenToad
Franco
« Reply #32 on: May 26, 2005, 11:51:19 am »
Cheers,
KenToad
Just to let you know I think both types of Joysticks would end up being too expensive lookin at the prices you can get similar joysticks for.
The problems lies with me only being able to do home orders in my lunch hour between other production runs. This means I only get to make one or two of something at once. This would mean pretty much programming, turning, further maching and polishing each order individually. If I had my own machine or the oppertunity to get a few runs of each joystick then the price would be much lower.
Unfortunatly I thnk im just going to have to concentrate on the washers and a few other bits and pieces at the moment. However if the opertunity does arise to make some I will let you all know. Sorry if I got anyones hopes up.
Franco
« Reply #33 on: May 26, 2005, 11:55:07 am »
By the way I sent the first lot of washers of and now know the shipping prices to the US from here in the UK.
One pair of washers = $10 + $4 Shipping = $14
Two pairs of washers = $20 + $5 Shipping = $25.
Let me know if anyone else requires some.
Grasshopper
« Reply #34 on: May 26, 2005, 02:54:50 pm »
I've dug up an old thread that I started a couple of years ago to give you an idea of what I had in mind.
http://forum.arcadecontrols.com/index.php/topic,7194.0.html
If you don't have the facility to accurately bend sheet metal then top mounted plates would be ok. But I'd prefer bottom mounted if possible.
I've got some CAD drawings of joystick bolt patterns somewhere. I'll post them over the weekend.
Grasshopper
« Reply #35 on: June 04, 2005, 09:12:34 am »
I've managed to track down my TurboCAB drawings.
There seem to be two main bolt patterns in use. The one used by the T-Stiks (and perhaps a few others) and the pattern used by the old Wico leafs. Most of the Happ joysticks and the Suzo 500 are compatible with both patterns.
It would also be nice if the mounting plates that come with the T-Stiks could be replaced with one of these plates. This would require four more holes to be drilled arranged in a 4.2cm x 4.2cm square.
Grasshopper
« Reply #36 on: June 04, 2005, 09:15:42 am »
Grasshopper
« Reply #37 on: June 04, 2005, 09:16:58 am »
Grasshopper
« Reply #38 on: June 04, 2005, 09:21:26 am »
