Author Topic: Making Groovymame fill entire screen on crt (already in ArcadeOSD)  (Read 12389 times)
Sarda
  • Last login:May 28, 2026, 10:54:42 am
Hi friends, I have a cabinet for years where I play Fightcade and Groovymame using Crt Emudriver and super resolutions.
On FBNeo and on Arcade OSD, I've set the pots to fill the entire screen based on CPS2 games, and they do just fine.
However, on GroovyMame, the games are a little bit more curvy on the edges and also leave some black bars on the side.
I first tested on FbNeo and ArcadeOSD and I believe this can be a matter of Groovymame being 100% accurate and I should set the pots based on it, but juding from ArcadeOSD also filling the screen when using the same resolution, I thought this could be something I could fix with settings.
I've tried setting more unevenstrech settings but couldn't do it.
I'm attaching my log here, thanks a lot.
Ps.: if anyone also has an idea on this, thank you - https://forum.arcadecontrols.com/index.php/topic,170223.msg1780971.html#new
