Author Topic: Solenoid control ideas  (Read 1883 times)
Bulliesrevival
  • Last login:Yesterday at 02:22:01 pm
« on: April 11, 2026, 09:57:47 pm »
I am redoing my skeeball machine, I'm going to be removing the original controls and boards. I'm trying to see what ideas people have to control this solenoid for the ball release. I believe it runs on the full 110v's but with that part removed I'm trying to come up with
A) a way to run 110v to it and control it with a 5v system.
B) a way to release the balls using only 5v
C) some other method I'm not aware of yet
Sent from my Pixel 9 Pro XL using Tapatalk
  • Last login:Yesterday at 09:42:34 pm
Re: Solenoid control ideas
« Reply #1 on: April 12, 2026, 03:29:40 am »
First step is to verify what voltage powers the solenoid.
- It's probably 110VAC, but that circuit board next to the solenoid might be a rectifier and (12/24/36v?) voltage regulator.
The next question is do you want the release to be wired to a button or software controlled?
For button-controlled release, you may want to consider a time-delay relay where you press the button to trigger the relay long enough for the balls to roll past.  There's some useful info about time-delay relays in this thread.
A relay like this one would probably work for you with the correct voltage and the solenoid as the load.
For software-controlled release, I don't see any mention of a solenoid control in nipsmg's Major League Skeeball software thread here, but it might be supported or he might be able to add it as an option.   :dunno
If it is supported, you'll probably need a PAC Drive to convert the software commands to an output that controls some sort of relay.
https://www.ultimarc.com/output/led-and-output-controllers/pac-drive/
Depending on how the solenoid command is implemented, it will produce either a short fixed-length pulse or a longer variable-length pulse.
- For a short fixed-length pulse, you will need a time-delay relay.
- For a longer variable-length pulse, you can probably use either a regular relay module or a time-delay relay.
Bulliesrevival
« Reply #2 on: April 12, 2026, 07:08:16 am »
Man Scott you are everywhere with the answers I need, ha ha ha.
I'm thinking simple is better, that time delay relay you posted is probably the perfect one once I verify the voltage.
The circuit board next to it actually doesn't directly attach to the solenoid. It does attach to the bulb that is at the ball release. The solenoid connector goes directly back to a main harness connection on the control board, which is what has me thinking it's 110v. Going to try to research those solenoid numbers and this brand to try and find out.
Bulliesrevival
« Reply #3 on: April 12, 2026, 08:00:42 am »
Found something similar when searching it up
https://www.grainger.com/product/DORMEYER-Solenoid-120V-AC-4X241
Looks like it is a 110v solenoid. So that should make this easy using the delay relay. Thanks Scott.  I owe you a cup of coffee lol. Keep this up and it will be a case of beer ha ha
« Reply #4 on: April 12, 2026, 04:11:46 pm »
Glad to assist.   :cheers:
Part of the reason I'm hedging my answers a bit is that I'm not certain which manufacturer/model Skeeball game you have.
If you have a Skeeball Model S or Model H, the solenoid is described as a "4x240", which is pretty close to the Grainger part number you linked to.
- If you need to replace the solenoid, pretty sure you can find better prices on Amazon.  Looks like this solenoid is also used in some wood-burning stoves.
Bulliesrevival
« Reply #5 on: April 12, 2026, 05:26:09 pm »
It's actually neither of those. It's the elusive "superball". I say that tongue and cheek due to the complete lack of info for these machines. I did find that they switched to Fab. And there's one person out in the world that posted the hand written manual for Fab, I gave up trying to figure out what's wrong and moved to my current "just make it work with new stuff" decision lol
