Author Topic: "Wobbly" trackball?  (Read 33192 times)
CmdandCtrl
  • Last login:January 23, 2026, 11:37:08 am
"Wobbly" trackball?
« on: January 05, 2026, 02:30:31 pm »
I've got an Ultimarc trackball and for lack of a better way to describe it, it has some "play" or "wobble".  A video (with sound) says a thousand words so made this little recording to demonstrate the issue.  I have tried cleaning it and adjusting it in the past with no luck.  I'm guessing the experts here might have some sage advice for me?
Video:
https://imgur.com/a/9hAOy3O
(Sound up for best effect)
Xiaou2
  • Last login:October 06, 2026, 10:54:29 pm
  • NOM NOM NOM
Re: "Wobbly" trackball?
« Reply #1 on: January 06, 2026, 09:32:54 pm »
The video is one thing... but since we cant see inside... its hard to spot any mechanical problem
Post a video showing the internals, and you rolling the rollers (with pressure), in various directions.
Not knowing how their TB is constructed.. Im thinking its possibly a bearing that is popping out of place, when pressure
is applied to the rollers.
This could be due to a partially broken or cracked post
MartyKong
  • Last login:October 06, 2026, 01:00:19 pm
« Reply #2 on: January 09, 2026, 12:15:27 pm »
The only thing I can add is when I took my Happ trackball apart after cleaning the bearings I added a little 3 in 1 household oil and spun them really good to make sure their was no binding. This of course was just for maintenance not for an issue I was having.
CmdandCtrl
« Reply #3 on: January 16, 2026, 06:21:21 pm »
I opened it up and the rollers were nice and clean, the bearings spun freely and smoothly.
Here is what I discovered: it vibrates when you are rolling in a direction where two rollers come together in a "v".   So, it seems like there is clearance between the ball and top of the housing that allows the ball to rise up on rollers when you are pushing the ball towards the "v".    Here is a little video that I created that shows what I mean:
https://imgur.com/a/e4hbyHT
I didn't really see any way I could affect the spacing between the top of the ball and the housing so I'm not sure if there is anything that could be done to resolve this.   Thoughts?
Xiaou2
  • NOM NOM NOM
« Reply #4 on: January 17, 2026, 06:30:34 am »
Your video makes no sense at all.
 In your first video, you seem to be pressing the ball Downwards, and its actually moving the ball
slightly down.. which shouldnt be possible.
 In this new video, you are intentionally pushing the ball horizontally... so of course its going to
come up off the rollers... because the TOP Plate isnt there to keep it Centered.
 There is always going to be more "Resistance" when both rollers are moving at the same time.
But you would never be able to move the ball like in your video.. because the Top plate is designed
to keep the ball Centered.
 Firstly, show closeup photos of the rollers.  Look for any wear marks, or an uneven spot, on the
rollers.
 Next, remove all of the rollers from the bearing holders.  Look for any Debris, in the housing.
 Next.. go to an Auto-Parts store.. and get something called  "Electronics Cleaner".  It will come in an Aerosol spray can.
 Also, buy a small bottle of  "3-In-One"  Lubricant / Oil  (Walmart might stock this, if the Auto Store doesnt)
Properly Checking + Cleaning + Re-Lubricating the Bearings...
*** Checking the Bearings for Internal Race-Damage / Dirt
1) Take all bearings off of the Rollers.
2) Hold a single bearing between your pointer finger, and your thumb.  Spin it slowly, while applying pressure towards
the center hub
3) While its moving.. you should not feel any changes in sensation.  If at any time, you feel a Grinding or tighter Resistance
level.. then you might have a bad bearing, that needs replacement.
4) However... the feeling of Grit, or Resistance, could also be internal Rust, or Dirt.  It might be possible to clean it out.
*** Cleaning + Re-Lubrication of Arcade Trackball Bearings
1) Attach the Red Straw to the Electronics Cleaner, for better spray accuracy
2) Place a single bearing on a your finger or hand, and spray one side, generously... so that it pools liquid on the surface
3) Grip the bearing between your Pointer Finger and Thumb... and SPIN the bearing as fast as possible... for a solid 15 seconds
4) Repeat this process again
5) Flip the bearing over..  and do the same exact process, already described above
6) Apply some 3-in-One Oil to the side of the bearing
7) Start to spin the bearing between your fingers.  Start slowly.. and gradually work your way up to full speed spins
8 )  Repeat on the other Side, just to make sure that enough oil got into the bearing housing
9) Clean the Metal Rollers... then wipe them down with a Rag that has a small amount of 3-in-1 Oil on it
Wipe of clean of any "Excess" oil
Now.. Make sure your Trackball housing is completely cleansed of all dust / dirt.  You can use the Electronics Spray
if you like.. to douse the thing..  then invert the housing, and pour out the dirty liquid that remains.  Wipe down
with a cloth... then Reassemble.
Additionally... Inspect The OUTSIDE EDGE of all bearings for any Dents / Defects
Inspect the Bearing holders for Any Hairline Cracks (use a magnify glass to check up close)
Inspect the UNDER-SIDE of the Top part of the Housing... for any uneven surface wear
Make sure that when the thing is reassembled, that there is no "Gap" between the top and bottom housings
And finally... Inspect the Ball Itself.. for any surface divits / pits.  Clean the ball with some rubbing alcohol,
and potentially use some car-spray, or floor polish, to lightly polish its surface
(Note... Do not soak bearings in WD40.  Trust me.  I ruined some rollerblade bearings like that)
« Last Edit: January 17, 2026, 06:34:23 am by Xiaou2 »
  • Last login:October 06, 2026, 11:37:34 pm
« Reply #5 on: January 17, 2026, 11:44:46 am »
It’s a half assed Ultimarc trackball. Get something meant for actual use like a Betson or Happs and you won’t have these janky problems.
Vicinus
  • Last login:May 12, 2026, 05:17:34 am
« Reply #6 on: January 22, 2026, 01:48:42 am »
I have the same trackball - and the exact same issue since day one until today.
So I don't think any cleaning will help with this issue. (Though cleaning all parts, especially the bearings is still a good advice!)
It is said, that after an hour of heavy use the ball will groove itself into the bars. That did not happen for me.
The issue comes with its design. The ball needs allowance (wording?) to roll fast but because of the high friction and angle (movement relative to bars) it cannot transfer the full force to the bars in some directions so it goes up.
If the ball had less allowance it would not wobble but touch the case or other parts than the bars -> more friction less spin.
The ideal design would have two bars above the canter point of the ball to keep it in place.
Anyway..
So in your case to lower the friction use a bit (very small amount) of lube on the ball. I used mlking greas since we have that at home and it works wonders.
While this is not permanent, it is a good solution for some gaming sessions.
I really would like to try out other trackballs like the ones pbj (mentioned) but they are probably to expensive to just test them.
« Last Edit: January 22, 2026, 01:52:56 am by Vicinus »
KenToad
  • Last login:October 06, 2026, 08:47:41 am
  • Flap Flap Flap
« Reply #7 on: January 22, 2026, 09:43:00 am »
Yes, I have the ultimarc u trak as well and would agree that this problem isn't fixable. I've opened it up and it's clean and smooth rolling inside. I've used it for years and it's never fixed itself by some magic roller break-in. I suspect the wobble is a design issue. I would have to assume that they had to make sacrifices to make it installable in wood panels without a mounting plate.
The U-trak trackball is good enough for "roll forward" bowling and golf games, but not great for "roll all around" games like missile command or centipede, as some directions will make the ball jump and resist and others will be smooth. In short, it doesn't function at what I would call arcade quality.
CmdandCtrl
« Reply #8 on: January 23, 2026, 11:37:08 am »
Thanks for confirming that I'm not alone with having this issue with this model of trackball.  The bearings and rollers are in great shape so it is not that. In response to the comment that the video I posted doesn't make any sense, some further explanation:
In the first video where I show the issue from the top, it does appear that the trackball is going down into the cabinet, but just the opposite is happening: It is actually riding slightly upward toward toward the camera as it rides up on the rollers and then collides with the top of the housing.
In the second video, my control panel is removed from the cabinet and is face down.  The trackball housing is disconnected, but it is 180 degrees to how it is normally mounted in the cabinet.  (had to do that to get to sit flat while not disconnecting the wiring).
When I took the video, I had wondered if this might cause confusion and I even considered mirroring the video so it would match the installed orientation.  Probably should have done that...
Thanks all! Guess I'll be researching new trackball options.
Mr. Peabody
  • Last login:July 15, 2026, 09:31:11 pm
« Reply #9 on: February 11, 2026, 11:46:09 pm »
Somewhat storming this party: I essentially gave up on track ball games years ago for this reason. Two Happs have behaved like this, and the Betsons I bought only a little better. The first Happ I replaced Everything but the encoders (with GGG parts, including bearings): spun better, not great and certainly not killer; still choked and tracked in the same direction. The issue lies with a lack of precision in the housing design. Ten or so years ago I happened upon found a pretty great though worn and dirty Betson (I think) in a Golden Tee, so some don't suck.....but.....
