Author Topic: Need For Speed Cabinet + Immersion PCB  (Read 17698 times)
FrizzleFried
    • Idaho Garagecade
« on: March 04, 2025, 10:23:14 am »
Hey guys... been a while...
I currently have a multi-Need For Speed cabinet running (it runs NFS, NFS Underground and NFS Carbon... authentic versions)...
I also happened across a brand new Immersion PCB that I remember buying some 10 years ago that I never used.
What do I need to do to make a MAME/(whatever emulator) multi-driver with this cabinet?
Being it is currently running a PC... would it be just a matter of building a MAME PC running drivers only... setup attract mode (or some other front end) to use the wheel and buttons to navigate... then rock on?   Is it that simple?
Do I have a good reason to keep this brand new Immersion PCB?  It seems I have one already in the NFS cabinet (obviously)....
« Last Edit: March 04, 2025, 10:27:27 am by FrizzleFried »
Jollywest
  • Last login:Today at 09:13:47 am
Re: Need For Speed Cabinet + Immersion PCB
« Reply #1 on: March 07, 2025, 02:00:09 am »
Emulator based Driving cabs take a lot of work to get them working well.
I’m not familiar with the makeup of the NFS cabs, is it Linux based?… can you upload some photos of the internals?
From the info given, you have a couple of options I’d say;
1. Adapt the PC that’s in there already to set up a dual boot system, one for the original NFS stuff and one to boot into the Emulator based OS. The spec of this PC might not have enough grunt to play the more demanding emulated stuff though.
2. Setup another PC with all your Emulated stuff on. You would need to switch cables from the NFS PC to this PC when you want to swap between the two systems. If all your controls are connected to the Immersion board, then it’s simply a matter of switching the USB cable from this board between the PC’s to interface the controls. Then the controls need to be configured. If there is another I/O board connecting some of the controls then this would also need to be interfaced to the new PC if compatible.
Which ever way you go, each emulated game will need to be configured and tweaked individually to get the game playing correctly, that in itself takes a lot of time.
mongoosetoo
  • Last login:September 15, 2026, 01:33:04 pm
  • If you ain't first, you're last!
« Reply #2 on: May 04, 2026, 10:22:17 am »
Sorry for resurrecting an old post, but I am doing this very thing.
All the NFS Games run on Win XP,  Embedded I think.  The processor is an old Duo Core Intel or AMD Athlon.  Graphics card is NVidia GeForce 9600GT or 9800GT.  I am certain it is NOT up to task on running any modern racing games.  |It may do ok with Pole Postion or other racers from that era.
Please keep feeding this topic.  I am trying to get my 2 NFS cabinets to work on emulation with the stock FFB.
|Thanks
Jollywest
« Reply #3 on: May 04, 2026, 03:10:18 pm »
The pc spec required with depend on what you intend to play on it.
I’m totally out of the loop regarding MAME driving games these days, so not sure what spec you’d need for that.
If you plan to run more modern racing games using Teknoparrot, then you’d need at least a NVIDIA GTX 1070 6GB GPU, and at least a i3 4th Gen CPU, to avoid slowdowns in some of the more demanding games.
