Author Topic: CRT Emudriver - Non emulated compatible games  (Read 288235 times)
CRTFTW
  • Last login:March 28, 2026, 06:37:27 pm
Re: CRT Emudriver - Non emulated compatible games
« Reply #240 on: April 27, 2024, 12:07:22 pm »
So Mega Man 9 and 10 essentially have "native" PC ports via Mega Man Legacy Collection 2. But something really weird is going on with their resolution, even beyond the forced 16:9 aspect ratio with borders.
I was able to get it down to 224 pixels tall, and you could tell that the vertical scaling "locked" to 1:1, but there was absolutely nothing I could do to get horizontal scaling to lock to 1:1.
The horizontal resolution should be 256. But even with me trying to adjust the horizontal resolution to allow the extra 16:9 space (then essentially cropping out with short timings in ArcadeOSD), it seems there was nothing I could do to get 1:1 on the horizontal axis.
It's been a while since I experimented with this, I just now remembered to post about it. But my best guess from that experience: it needs to be hacked to actually get it to display correctly at 256x224. Hack in what I way? I don't know. There seems to be some kind of intermediate frame buffer being used that does not line up with the game's native 256x224 resolution
I ended up just playing the games in Dolphin, where you can get a 1:1 lock on 256x240 (letterboxed 224p). Only problem being there was likely a small input lag penalty for emulation, which you could probably eliminate by playing the PC versions instead
« Last Edit: April 27, 2024, 12:12:14 pm by CRTFTW »
Rion
  • Last login:Today at 07:14:14 pm
  • 240p, 480i
« Reply #241 on: May 03, 2024, 05:14:57 pm »
First Cut: Samurai Duel
GOG
320x180 1X Native resolution
320x200@60 Then Integer Scale down to 320x180
I used GameScope in Linux but should work just the same using integer-scaler
superbike81
  • Last login:May 16, 2024, 01:56:32 am
« Reply #242 on: May 08, 2024, 12:09:02 am »
So I'm messing with this for the first time. I've used CRTEmudriver for a while but never used it to run modern PC games. So I'm just trying out a few games and was recommended this thread.
Instead of adding a modeline for every resolution, I saw a comment from 2020 that said to download a standalone version of Switchres. Is that still the recommended way to do this in 2024?
psakhis
  • Last login:September 24, 2024, 11:54:25 am
« Reply #243 on: May 08, 2024, 01:52:11 pm »
Yes, standalone switchres works perfect.
superbike81
« Reply #244 on: May 16, 2024, 01:56:32 am »
Okay so the game launches, I use the Switchres command to get 360x200@60hz, but then the Switchres shows it's running my normal desktop resolution.The game starts up fine and there are no error messages. I installed a modeline for 400x240 for my widescreen desktop, and it keeps settings it to that. Any ideas?
psakhis
« Reply #245 on: May 20, 2024, 09:04:43 am »
Lords of Exile
Steam
Lords of Exile
704x448 Native resolution
384x240@60 Downscaled
Here works better with 352x224@60
Rion
  • 240p, 480i
« Reply #246 on: June 02, 2024, 12:00:59 pm »
Overbowed
Steam
Overbowed
Native resolution is 160x144 GameBoy
Set display resolution to 320x240
Game Scale to 1x
Perfect integer scaling just like GameBoy Player
Rion
  • 240p, 480i
« Reply #247 on: June 06, 2024, 10:28:42 am »
Penny’s Big Breakaway
Steam
Try any of the following modes that Suit Your display best.
854x480 (16:9 -> 4:3)
864x486
960x480
Rion
  • 240p, 480i
« Reply #248 on: June 08, 2024, 06:41:54 pm »
ASTROLANCER
Steam
ASTROLANCER
480x270
phasermaniac
  • Last login:June 10, 2025, 09:39:41 am
« Reply #249 on: June 12, 2024, 03:31:20 pm »
Shadow of the ninja demo:
https://store.steampowered.com/app/2543760/Shadow_of_the_Ninja__Reborn/
480x270?
Amazing grahics. The best retro art I've seen
Rion
  • 240p, 480i
« Reply #250 on: June 16, 2024, 03:48:13 am »
480x270?
Is that a question or did you try with the demo?
phasermaniac
« Reply #251 on: June 17, 2024, 04:15:29 am »
It was a question because I tested the demo in another pc and did not remember.
But just cheked and yes, its 480x270
Rion
  • 240p, 480i
« Reply #252 on: June 29, 2024, 04:27:59 pm »
Angry Video Game Nerd I & II Deluxe
Steam
GOG
320x224
CRTFTW
« Reply #253 on: July 05, 2024, 05:34:24 am »
Update for Huntdown:
This one is complex. If you run it in a x1 window on a normal monitor, it will say 480x270
But I think it will crop itself to any resolution you throw at it, and it seems to scroll with the character to accommodate (sort of like Sonic Mania with the pixWidth setting)
So that means that the resolution listed in the first post isn't necessarily incorrect, it's just one of many resolutions this game can theoretically do.
I played it in 4:3 at 320x240.
Main menu text looked correct, and the game itself looked perfectly scaled. I did noticed the stage end screen had badly scaled text. So I'm not sure if there are any other things in the game that might get scaled, I'll be looking out for that.
I'm also experimenting with Special K for Latent Sync and Delay Bias to get near instant input latency. The game already has good latency but I thought why not improve it further. My best combo seems to be to disable flip-model (use legacy exclusive full screen) then use a 50% delay bias. I was getting a bit of tearing/stutter otherwise. This was just after 15 mins testing so YMMV
« Last Edit: July 05, 2024, 05:39:23 am by CRTFTW »
grendelrt
  • Last login:July 31, 2025, 04:05:14 pm
« Reply #254 on: July 11, 2024, 10:58:41 am »
Looking for some help, I have switchres running using a bat file and everything seems to work correct, except it doesnt keep the resolution open long enough for the game to launch. I run the bat, switchres calculates the correct resolution, switches the resolution, but before the game can launch the resolution goes back to desktop then the game launches right after. My current bat looks like this after taking some examples out of this thread,
set fullpath=%~dp0
echo fullpath
C:\Users\Arcade\Desktop\Switchres\switchres.exe -s 400 224 60 -l C:\Users\Arcade\Desktop\Switchres\BattleAxe.lnk
Command prompt output attached.
Rion
  • 240p, 480i
« Reply #255 on: July 13, 2024, 04:02:46 am »
set fullpath=%~dp0
echo fullpath
All you need to do is add -k (keep resolution) it will be flushed out on the memory once you reboot or shutdown.
Example
C:\Users\Arcade\Desktop\Switchres\switchres.exe -s -k 400 224 60 -l
You could also probably make th batch file that monitors when the game closes and then edit the bat file. But I have no idea how to do so since I hardly ever use Windows.
grendelrt
« Reply #256 on: July 13, 2024, 06:18:12 pm »
set fullpath=%~dp0
echo fullpath
EDIT: Found the reason in discord with some help, thanks guys!, its due to being a pre 5xxx series card, allow hardware refresh doesnt work with legacy cards before then.
Thanks, I went this route with using AHK and everything seems to work, but it looks like I am forced into some kind of tate mode (reversed height and width? picture attached EDIT: weird thing on this is that the resolution looks correct before the game launches, its full screen no bars and 240p ish), is there an ini place for orientation? I have it set to to 4:3 but didnt see orientation. Here is my script,
#Requires AutoHotkey v2.0
RUN "C:\Switchres\switchres.exe -s -k 400 224 60"
sleep 2000
RUN "C:\Program Files (x86)\Steam\steamapps\common\Battle Axe\Battle Axe.exe"
sleep 2000
NewPID := ProcessWait("Battle Axe.exe", 5.5)
sleep 2000
ProcessWaitClose(NewPID)
sleep 2000
RUN "C:\Switchres\switchres.exe -s -k 640 480 60"
« Last Edit: July 15, 2024, 01:56:55 pm by grendelrt »
Rion
  • 240p, 480i
« Reply #257 on: August 13, 2024, 07:57:26 pm »
Huntdown is mention in the first post by psakhis but it is named Hunt down instead of Huntdown.
The best resolution for 15khz would then be 432x240@60
Rion
  • 240p, 480i
« Reply #258 on: August 13, 2024, 08:28:42 pm »
ANIMAL WELL
Official Website
Steam
ANIMAL WELL
Rion
  • 240p, 480i
« Reply #259 on: August 15, 2024, 09:25:25 am »
The Ninja Saviors: Return of the Warriors (named The Ninja Warriors Once Again in Japan)
Steam
The Ninja Saviors: Return of the Warriors / The Ninja Warriors Once Again (Japan)
Edit
432x243@60  (Aspect Ratio 112%) Edited
« Last Edit: August 28, 2024, 07:11:04 pm by Rion »
grendelrt
« Reply #260 on: August 19, 2024, 04:51:07 pm »
Steam
426x240@60  (Aspect Ratio 112%)
Awesome! Been waiting for this to go on sale to pickup, good to know it will work ahead of time.
Rion
  • 240p, 480i
« Reply #261 on: August 27, 2024, 07:51:23 am »
Abathor
Steam
Abathor
384x216 1X Native resolution
Rion
  • 240p, 480i
« Reply #262 on: August 27, 2024, 02:26:37 pm »
CYBORG FORCE
Steam
CYBORG FORCE
itch.io
CYBORG FORCE
320x240p
Native resolution is 640x480 since this is most likely a port of the DreamCast version.
But there is no visual difference between 320x240 & 640x480..
Recapnation
  • Last login:February 23, 2026, 12:10:18 pm
    • Eiusdemmodi
« Reply #263 on: August 27, 2024, 03:46:59 pm »
Hi, guys.
It'd make my day if you can try for me the just-released Akumajou Dracula Revisited at 427 * 240:
https://store.steampowered.com/app/2369900/Castlevania_Dominus_Collection/
The screenshot there is natively 480 * 270 but only 427 * 240 is active:
I wonder if something like Special K would be needed in this case (to crop the frame).
By the way, Ninja Warriors Once Again is natively (designed at) 427 * 270:
Seems it's scaled anamorphically, I'm afraid, but subscaling it to 240 lines is equally destroying its art.
Basically the same will apply to the Kage remake by the same people, about to be released:
Be civil and use a 24 or 31 kHz monitor for these!
Cheers.
« Last Edit: August 27, 2024, 04:15:55 pm by Recapnation »
Rion
  • 240p, 480i
« Reply #264 on: August 27, 2024, 06:54:21 pm »
Cheers.
The hole point of this thread is not to force people into using 24/31Khz, but to find ways of displaying them in 15khz if possible.
My solution might not been the best but hopefully someone will figure it out.
Recapnation
    • Eiusdemmodi
« Reply #265 on: August 27, 2024, 07:34:36 pm »
Is it or maybe just some of you misunderstood it, though?
Subscaling dot art or even altering refresh rates is never a solution. And there can't ever be one if the game's just beyond the monitor's capabilities. So just get another monitor suitable for it -- CRT Emudriver will do wonders with with that as well. Spreading methods to ruin a game's graphics well goes against the forum's philosophy, I'd say.
Rion
  • 240p, 480i
« Reply #266 on: August 28, 2024, 04:47:55 am »
No just trying to not display the games in a Interlaced resolution.
But Ninja Warriors Once Again will work without issues if you use 854x480 instead.
But again then the image is interlaced.
Rion
  • 240p, 480i
« Reply #267 on: August 28, 2024, 05:56:55 am »
Are you sure about that?
I have been playing around with the registry file settings and applied that resolution as the border-less window res and it does not look right..
Code: [Select]
Computer\HKEY_CURRENT_USER\SOFTWARE\TAITO CORPORATION\The Ninja Saviors Return of the Warriors
Edit: Experiment with the registry keys in window mode with
Screenmanager Resolution Height_h2627697771
Screenmanager Resolution Width_h182942802
Change hexadecimal to decimal
Edit2:
I think I'm on to something here
Looking at this screenshot the size is actually 600x337
Been doing some tests with 432x243 72% of that resolution.
« Last Edit: August 28, 2024, 10:11:08 am by Rion »
Recapnation
    • Eiusdemmodi
« Reply #268 on: August 28, 2024, 12:19:19 pm »
At least, it won't be downscaled. I already suggested a 31-kHz monitor if you don't like interlacing. Whatever it takes in order to keep the graphics' integrity (or to get it back, actually, as it was taken away by the devs and their flat panels). Two wrongs don't make a right.
Where does that screenshot come from? It clearly is not 1 : 1, just check the last zero in "700". If you look at the screen I posted you won't find artifacts (though it was downscaled from a JPG, if I recall, so there may be some color inaccuracies and whatnot), but again, it had to be done anamorphically.
Rion
  • 240p, 480i
« Reply #269 on: August 28, 2024, 06:22:45 pm »
I'm only interested in downscaling modern pixel art games in 15khz for now.
I do own a 31khz PC Crt..
It's from steam. The first screenshot from the store page.
Recapnation
    • Eiusdemmodi
« Reply #270 on: August 28, 2024, 07:37:34 pm »
So I wonder, for something like Guilty Gear X, do you also downscale it to 15-kHz progressive?
apoketo
  • Last login:April 12, 2025, 10:49:03 pm
« Reply #271 on: August 28, 2024, 08:48:08 pm »
Ninja Warriors Once Again is weird...
Using the built in scanline option only achieved uniformity with 1440x900 windowed, which is letterboxed to 810p
each pixel 3x3, so it's 270p - aka the standard multiple of 1080p
...but the scanlines are misaligned when set to 1080p
The default 112 horizontal scaling results in uneven pixel uniformity, a CRT should optimally use 100 and stretch to 16:9 by the display itself
Forced to 480x270 via WinExplorer (the game actually saves these changes):
edit: I never tested 112% 426x270 but it doesn't seem to lock aspect in fullscreen unlike borderless/windowed so maybe that works too.
« Last Edit: August 28, 2024, 09:04:32 pm by apoketo »
Recapnation
    • Eiusdemmodi
« Reply #272 on: August 29, 2024, 07:29:41 am »
Thanks for confirming. And for the Winexplorer tip, I guess it won't do for Akumajou Dracula Revisited as well, to crop the frame, right?
Rion
  • 240p, 480i
« Reply #273 on: August 29, 2024, 09:03:46 am »
I think gamescope would be a good candidate for this.
Rion
  • 240p, 480i
« Reply #274 on: August 29, 2024, 09:09:42 am »
Crypt Stalker (Developer Sinclair Strange)
Steam
Crypt Stalker
Original Game not the game boy version
384x216 Full Screen
Alien Splatter Redux (Developer Sinclair Strange)
Steam
384x216 Full Screen
apoketo
« Reply #275 on: August 29, 2024, 09:18:33 am »
You could probably force the position of the window so the margins are just offscreen.
edit: oh IntegerScaler can position, crop and resize if you don't mind cmd lines
« Last Edit: August 29, 2024, 09:28:28 am by apoketo »
Recapnation
    • Eiusdemmodi
« Reply #276 on: August 29, 2024, 11:43:23 am »
As I posted earlier, the thing with Revisited is that seemingly the frame at its native resolution is 480 * 270 but the active area is actually of 427 * 240:
So while the full frame wouldn't be suitable for 15-kHz progressive, if you crop it to get rid of the borders, you do get a 240-P picture, so that solution will hardly do. This is still a guess as it's possible the game offers in the end a full-screen border-free video mode with proper or no scaling -- some screenshots distributed by the media are like this.
Totally forgot about Integer Scaling having indeed a crop feature. It could help if there's nothing better.
Rion
  • 240p, 480i
« Reply #277 on: August 29, 2024, 04:11:36 pm »
You should be able to use IntegerScaler and crop the image in a borderless window. That should give you the desired results..
 https://tanalin.com/en/projects/integer-scaler/#h-commands
« Last Edit: August 29, 2024, 04:13:32 pm by Rion »
Rion
  • 240p, 480i
« Reply #278 on: August 29, 2024, 04:22:54 pm »
Shadow of the Ninja - Reborn
Steam
Start the game up in 480x270p set Screen Mode to Borderless.
While the game is running switch resolution to 480x240p.
Set Screen Mode to Fullscreen but keep resolution at 480x270 in the options menu.
This has to be done every time but will make the game display correctly in 480x240p.
Edited with new instructions 2024-09-20
« Last Edit: September 20, 2024, 02:33:49 pm by Rion »
Rion
  • 240p, 480i
« Reply #279 on: August 29, 2024, 04:46:20 pm »
The Curse of Issyos
locomalito.com
The Curse of Issyos
320x240 Native Res
Enable Fullscreen, Disable Overlay, Enable V-Sync
Edit: Opps this was already mention  :angel:
