Author Topic: CRT Emudriver - Non emulated compatible games  (Read 298676 times)
Rion
  • Last login:Yesterday at 02:55:15 am
  • 240p, 480i
Re: CRT Emudriver - Non emulated compatible games
« Reply #200 on: October 09, 2022, 07:26:21 am »
Street Fighter X Tekken
Street Fighter X Tekken 640x480@60
alex2005
  • Last login:Today at 05:11:36 am
« Reply #201 on: January 12, 2023, 09:51:24 am »
Anyone had success with Wild Guns Reloaded? (426x240@60) (112%) on a 15khz monitor?
I've been trying all possible resolutions I could, but it will never display correctly (the image is centered but it has big black borders, so not a "real" fullscreen)
Tried also to append these parameters at the end of the command line, but no luck so far :(
-screen-fullscreen 0 -popupwindow
-screen-fullscreen 1 -window-mode exclusive
Thanks in advance :)
phasermaniac
  • Last login:June 10, 2025, 09:39:41 am
« Reply #202 on: January 12, 2023, 12:21:32 pm »
Yes, It's 426x270.
Windowed at 480x270 and set Ratio and scale to 100%.
Then you can just create an ahk to create a false fullscreen and move to -27,0
psakhis
  • Last login:September 24, 2024, 11:54:25 am
« Reply #203 on: January 12, 2023, 01:39:55 pm »
I don't know why, i added -forced3d9 on Wild Guns too.
alex2005
« Reply #204 on: January 13, 2023, 09:03:38 am »
Thank you guys for the hints. Apparently I cannot change the resolution in game, no matter windowed or fullscreen. Its set to something like 1520x720 (not sure about the first digits, they're unreadable :)
Would you mind sharing the switchres call for this game, or the ahk used?
Normally I do like this:
switchres.exe -s 640x480x60 -f 426 480 60 -l "WildGunsReloaded.exe"
Thanks a lot!
psakhis
« Reply #205 on: January 13, 2023, 09:09:47 am »
You can try with shortcut but always with same resolution, on shorcut you can set params.
switchres.exe -s 426x240x60 -f 426 240 60 -l "WildGunsReloaded.lnk"
alex2005
« Reply #206 on: January 13, 2023, 09:34:18 am »
thats strange. all i get with the command is:
Switchres: could not find a video mode that meets your specs
Anything I need to tweak in the switchres.ini file? adding the user modes ini as well, just in case it helps.
psakhis
« Reply #207 on: January 13, 2023, 11:06:21 am »
Try with allow_hardware_refresh    1
psakhis
« Reply #208 on: January 13, 2023, 11:53:50 am »
Vengeful-Guardian-Moonrider 428x240
alex2005
« Reply #209 on: January 13, 2023, 02:45:15 pm »
thank you! one step forward. Now it switches the resolution, but the borders are still there, doesnt fill the screen completely :(
Switchres: Modeline "426x480_60i 15.690000KHz 60.000000Hz" 8.676570 426 443 484 553 480 483 489 523 interlace  -hsync -vsync
psakhis
« Reply #210 on: January 13, 2023, 03:21:39 pm »
Why do you set interlaced resolution?
Check register, probably is wrong, HKCU -> Software -> NatsumeAtari and check resolution here
« Last Edit: January 13, 2023, 03:23:54 pm by psakhis »
alex2005
« Reply #211 on: January 14, 2023, 07:46:39 am »
Thank you psakhis! The register settings were the issue. Once I set there the right resolution, it worked! This was driving me a bit crazy  :dizzy: thanks so much! And I took the chance also to remove some of these interlaced resolutions that I was no longer using :cheers:
CRTFTW
  • Last login:April 04, 2026, 03:51:35 pm
« Reply #212 on: January 16, 2023, 12:42:07 am »
Ugh, I just picked this game up on steam, and it only works with DX12 cards!
On my HD 5450 it gave me an error saying my GPU doesn't support the right feature level or something, even though the game is supposed to run in DX11.
Can you guys drop in and make a (friendly) comment on the "error 69" thread in the "technical support" section on the steam forums? I really don't think there's a reason any 240p 2D game needs DX12 features. I hope they can fix this.
Rion
  • 240p, 480i
« Reply #213 on: January 16, 2023, 01:07:34 am »
That won't happen anytime soon if ever
The question would more be why on earth are you using such an old card? I mean any cheap R9 would do and then you would have at least DX12 support and Vulcan.
CRTFTW
« Reply #214 on: January 16, 2023, 02:31:33 am »
Huh? Isn't this forum full of people using older low power cards like the HD 5450?
This GPU has handled everything I've thrown at it. Whether it's a 2D game on Steam, GroovyMAME, Retroarch, whatever.
This is the first game I can't play, and it's only because the game engine is configured (likey misconfigured) to look for the DX12 feature level
It's a great looking game, but at the end of the day, it's just pixel art. They could have designed this on DX9 no problem.
psakhis
« Reply #215 on: January 16, 2023, 03:58:52 am »
Mmmmm...weird...
I'm playing on a W7 (not DX12). Can you test with compatibility W7?
CRTFTW
« Reply #216 on: January 16, 2023, 04:59:37 am »
Mmmmm...weird...
Well.... I think I found my answer when I went into the folder to do that.
It has files with "vulkan" in the filename.
Namely vk_swiftshader.dll and vulkan-1.dll
So even though the game runs in DX11, it must be running some of its graphics with Vulkan and then outputting to DX11's frame buffer, or something like that.
Maybe just for the 3D levels? Digital Foundry mentioned these levels are done with a different engine entirely:
I guess I'm screwed with this one. Doubt that's something the programmer is interested in modifying for likely an incredibly small number of users who are on cards older than 400-series Nvidia or HD 6000-series AMD
PTSamurai
  • Last login:February 09, 2023, 10:50:55 am
« Reply #217 on: February 09, 2023, 10:49:35 am »
Has anyone messed around with the demo for Grim Guardians yet? I forgot it was launching 2 weeks from now and it's by Inti Creates so I'm hoping it can do 240p.
psakhis
« Reply #218 on: February 09, 2023, 02:31:14 pm »
Probably not. Seems >= 480p.
DukyNuky567
  • Last login:March 06, 2023, 12:29:36 pm
« Reply #219 on: March 06, 2023, 04:02:45 am »
I actually did, for the most part it works with 400*240 @60hz, but the text isn't readable at all and cutscenes look really bad due to the low resolution.
I wonder if anyone could make a patch to change the text in the game.
You could also use English dub to avoid reading the text.
I've also tried Gunvolt 1 and 2, they also worked fine with 400*240 @60hz and the text this time is readable, because the game was made for a handheld device.
I don't know why no one has added them before to the list.
« Last Edit: March 06, 2023, 12:29:36 pm by DukyNuky567 »
CRTFTW
« Reply #220 on: March 09, 2023, 03:14:07 pm »
I'm guessing that's not the right resolution, based on your screenshots. They look a bit blurry, and those grey patterns on the wall don't look symmetrical (I'm guessing they're supposed to be symmetrical).
The easiest way to find out a pixel art game's native resolution is to run it in windowed 1x mode and inject Special K. Special K's UI will tell you the window (and thus the game's) resolution
Also, I have Azure Striker Gunvolt 1, and I noticed it has some sort of background pattern when it letterboxes. And I found the only way to get rid of that is to run it at 400x224. So for that game at least, native res is 400x224. Later games probably change that. Like none of the Blaster Master games run at the same resolution
« Last Edit: March 09, 2023, 03:16:44 pm by CRTFTW »
Rion
  • 240p, 480i
« Reply #221 on: March 18, 2023, 12:08:44 pm »
Vernal Edge
Got the resolution by using Special-K in 1x window mode. Thanks @CRTFTW
GOG
Vernal Edge
Steam
Vernal Edge
480x270
Edit corrections from psakhis.
480x240 in-game
« Last Edit: March 26, 2023, 07:54:23 am by Rion »
Rion
  • 240p, 480i
« Reply #222 on: April 02, 2023, 11:06:50 am »
LUNARK
Steam
LUNARK
400x224
DJO_Maverick
  • Last login:August 18, 2025, 05:32:31 pm
  • Chrono Crosser
« Reply #223 on: April 12, 2023, 07:15:27 pm »
Touhou 6
Touhou 7
Touhou 8
Touhou 9
Touhou 9.5
Touhou 10
Touhou 11
Touhou 12
Touhou 12.5
Touhou 12.8
Touhou 13
Touhou 14
Touhou 15
(previously reported)
Touhou 16
Touhou: Gensokyo Reloaded
All working fine with 640x480x60i.
They also all work fine in combination with their VPatch mods and THCrap.
DJO_Maverick
  • Chrono Crosser
« Reply #224 on: April 12, 2023, 11:36:41 pm »
Also...
Touhou 10.5
Touhou 12.3
Also at 640x480@60i
They try to force into 640x480 windowed mode even with the res matching the desktop, but installing SWRSToys and enabling the Window Resizer will allow it to be toggled to true fullscreen again.
CRTFTW
« Reply #225 on: August 13, 2023, 10:58:14 pm »
Just noticed Downwell's resolution is way off in the top post.
This is a game you want to play in TATE, and its native res is 284x160.
I found that 284x216 is a good resolution to run on a 4:3 display so it letterboxes to the right size. I definitely had to fiddle with porches to get it to touch the sides on the long axis.
And it's also a pain to get this game to not do weird scaling that takes it out of native res. I think I had to do some alt-tabbing and some toggling of options back and forth.
But cool game to play for anyone with a black and white tube especially
« Last Edit: August 13, 2023, 11:00:17 pm by CRTFTW »
Rion
  • 240p, 480i
« Reply #226 on: August 30, 2023, 09:34:12 am »
Prison City
Steam
Prison City
384x216@60 Native resolution
« Last Edit: August 30, 2023, 09:59:43 am by Rion »
Chebby
  • Last login:March 05, 2024, 10:44:53 am
« Reply #227 on: September 19, 2023, 05:39:55 am »
Raindrop
224x288 tate mode
https://room-909.itch.io/rain-drop
Rion
  • 240p, 480i
« Reply #228 on: September 22, 2023, 04:51:43 am »
Aqua Ippan - Demo 2023 -
itch.io
Aqua Ippan
304x224@60 Native resolution
mr4eyes86
  • Last login:December 19, 2023, 06:48:45 pm
« Reply #229 on: September 30, 2023, 09:08:09 am »
TMNT x Justice League Turbo 320x240 60hz. Native resolution is 1280x960 per the developer Kamekaze. https://kamekaze.world/xjlt/
Side question. How do I stop my modelines from changing back to their default values when using the standalone switchres binary? For example when using 2560x240, the default horizontal H center value is 52/65
But my actual edit is 46/65 to have it nearly perfectly centered.
Whenever I use the standalone switchres binary for a script I use to run Capcom vs SNK 2 (or any script with any edited modeline)
It defaults back to 52/65. Any help with this issue would be greatly appreciated!
« Last Edit: October 01, 2023, 09:18:42 pm by mr4eyes86 »
Rion
  • 240p, 480i
« Reply #230 on: October 01, 2023, 03:43:00 pm »
When posting pictures please use the size option
Example:
[img width=320 height=240]
mr4eyes86
« Reply #231 on: October 01, 2023, 09:20:15 pm »
Done, thank you. Any suggestions for why my modeline switches back to default? Thanks.
Example:
makya
  • Last login:March 22, 2026, 10:57:48 am
« Reply #232 on: October 02, 2023, 02:41:04 pm »
I believe switchres uses its own crt_range, so what you do in arcadeosd is not taken into account
mr4eyes86
« Reply #233 on: October 06, 2023, 02:57:51 am »
Then why does it reset my arcadeosd settings then?
mr4eyes86
« Reply #234 on: October 14, 2023, 01:40:38 pm »
Bump. Any help anyone?
makya
« Reply #235 on: October 17, 2023, 01:00:10 pm »
Maybe I misunderstood your issue, I thought you were complaining saying that even though your resolution was correctly set/centered through ArcadeOSD, the game launched with switchres wasn't.
« Last Edit: October 29, 2023, 04:29:14 pm by makya »
mr4eyes86
« Reply #236 on: October 24, 2023, 06:06:23 pm »
That's correct. However, despite switchres not using my arcadeOSD settings when launching games, switchres resets my arcadeOSD settings back to their default values after I've exited the game and switchres goes back to my desktop resolution of 640x480i. And I'm not complaining, I'm looking for a solution to an issue.
Maybe I misunderstood your issue, I thought you were complaining that even though your resolution was correctly set/centered through ArcadeOSD, the game launched with switchres wasn't.
Chebby
« Reply #237 on: February 25, 2024, 11:25:20 am »
Cash cow dx
320x240
From the creator of donut dodo
Rion
  • 240p, 480i
« Reply #238 on: March 21, 2024, 01:42:01 pm »
Lords of Exile
Steam
Lords of Exile
704x448 Native resolution
352x224@60 Downscaled (Edit as per @psakhis instructions)
« Last Edit: May 30, 2024, 08:54:32 am by Rion »
Rion
  • 240p, 480i
« Reply #239 on: March 21, 2024, 02:14:34 pm »
Rebel Transmute
Steam
Rebel Transmute
768x432 2X Native resolution
384x216@60 50% Downscaled
