Author Topic: Pac-Man Legion  (Read 421868 times)
Zebidee
  • Last login:Today at 10:04:21 am
Re: Pac-Man Legion
« Reply #400 on: October 01, 2026, 11:48:25 pm »
I need to give some thought to getting the Sanyo TV system to switch to DVD mode (component input) after power up. It's not the default.
Have you gotten into the service mode yet?
I also have some issues getting AttractModePlus working with the modified Radeon driver on the CRT. I'm working on resolving that as well, probably will discard AttractModePlus as an FE choice rather than struggle with it. All good! Damn it's nearly playable! Hah ha.
I use Attract Mode on my CRT cabs so may be able to help you, or at least share what works for me. I did try using AM+ but ultimately went back to AM vanilla as AM+ did not support a third-party plug-in I wanted to use (to display an instruction page if certain buttons on the main control panel were pressed)
AM's default layouts automatically scale to whatever desktop resolution you are using. I stuck with 720x480i. However for CRT TVs, with their built-in overscan, I had to edit/tweak the layouts a lot to get them to fit properly. AM doesn't have an offline layout editor tool, so that meant just learning about Squirrel programming, cracking into .NUT files and jumping onto Notepad++ for some light code hacking.
The Mala FE revamp is an interesting option.
You'll get that new GreenAntz for this once the new cases come in. Delayed by floods in Bangkok.
Cool CRT brackets! CRT shelves begone! Good for tight spaces.
  • Last login:October 07, 2026, 05:26:21 pm
Re: Pac-Man Legion
« Reply #401 on: October 02, 2026, 05:31:29 am »
I have gotten into the service mode on this TV Zeb, very useful in adjusting the over scan and a few other things. There is no feature in the service mode to change the default AV mode on power-up however. If I have to I'll automate a button press via Arduino to change to component in on power on. I have a question for you though. Supposing I wanted to reset the TV to factory reset settings in the service mode. Is this advisable? I ask because I'd like a second go at making adjustments for over-scan but from factory standard settings if there is such a thing.
With AttractModePlus the problem is with OpenGL failures in CRT Emudriver involving atig6pxx.dll. OpenGL applications crash. I'm looking at various options here. Happy to test older/other versions of Attract Mode if you think it will work. I am also looking at the revamped Mala but I'm more interested in testing that for the longer term and maybe other projects.
No worries about the GreenAntz 2.3 delay, I am excited to see it though!
Zebidee
Re: Pac-Man Legion
« Reply #402 on: October 02, 2026, 07:47:30 am »
Let's accept for now that the default behaviour cannot be changed. If all you need is a button press, you may be able to simulate that with a single capacitor.
You'll want an electrolytic, say 10uF or 100uF. Positive lead to active signal line, negative to ground. Now, when power is applied to the TV, the micom circuit wakes up. Signal line become live, starts charging the capacitor. Until the cap is fully charged it conducts, that line is grounded, circuit closed, like the button has been pressed.
This usually happens in microseconds. Then the cap becomes charged up, no longer conducts, circuit open, like the button has been released.
You can vary the closed period (charge time) by using a larger or smaller capacitor. Adding a resistor in series will also extend it.
Won't work for every occasion but give it a go. Cheaper and easier than an Arduino ;D
Before fraggling around with such stuff, I recommend you make a backup of the jungle memory EEPROM. This is an 8-pin chip somewhere near the jungle, perhaps a DIP-8 (through-hole) but maybe a SOIC-8 (SMD). You may need to remove the EEPROM.
Go on ALiexpress and grab a CH341a set (they are really cheap).  The set will include some extras like a "grabber" for the SOIC ICs (saves you from removing the IC to read it). You may as well order a few matching blank EEPROM chips in case you want to keep a physical backup separately, or just want to burn some EEPROMs later. And grab a USB 2.0 extension cable (male/female ends) while you are there if you don't already have one. This last bit, the cable, is to save you constantly bending down and also from having the CH341a sticking out like a sore thumb from your USB port (you can place it somewhere more approriate, like on your desk).
Some TVs have a 4-pin I2C header for the EEPROM on the motherboard, which you can use to plug in a logic analyser. In some cases the header is missing, but there remains a footprint to which you could simply add a header. It is possible to hack into this with the CH341a, which would save you the trouble of removing the EEPROM from the board.
I wrote up a thread on this EEPROM hacking a while back on the Monitor/Video branch, so check it out for more info.
If you really want to master TV hacking the you can learn how to snoop the jungle data traffic (I2C, UART etc) using a logic analyzer. This is because some data/options are coded into the jungle itself. For some TVs I think this may be the only way to unlock hidden but unused/disable features like RGB mode and remembering prior AV mode selection. It may be essential for RGB modding certain TVs. This is new territory for me, something to dive into when I have the time and right equipment.
Yeah look it was years ago I looked at this stuff. AM+ seemed perfect, but some things didn't work how I expected them too. So I went back to AM vanilla and that does what I need for a pretty straightforward FE. AM has some nice default layouts that you can use like the Pacman maze one which would look cool on this Pacman Legion cab.
Re: Pac-Man Legion
« Reply #403 on: October 07, 2026, 03:08:25 am »
That's excellent information Zebidee! I've gone and got myself the CH341a set.  Anything i may do with it will not impact my more important goal of getting this done though. I already had the USB extender lead, and I'll sell myself some blank EEPROM chips, I find myself much cheaper than online. After some further investigation there are many service menu entries which shouldn't be reset or basically messed with. I'll be very careful when the time comes. The capacitor hack (or some variation of it) sounds good to me. It's a single button press of the AV button, I may use a transistor/optocoupler to momentarily parallel the existing TV/AV switch to avoid any unwanted voltage issue, we'll see.
So, some further progress on this project. I now have a working control set and a working Front End! In keeping with my requirement for a really basic Front End menu I've ended up developing my own in Python. I'm ok at Python programming but still needed some A.I. help with the Pygame side of it which I'm not that familiar with. That said, I'm still going through with beta testing Loadman's Mala 2.0 beta. It's worth doing, more so for future projects than this one. The challenge with setting up a Front End on a system like this is that you really need a second LCD screen in play until everything is done and tested. It's just too hard working on a CRT at 240x320 in Windows. Developing my own FE let me do just that. Yes I can add Snaps etc later if I want, but I like it simple and fast. So no pics or it didn't happen as PBJ says, I'll go one better and provide a video.  The end goal is basically as per this concept with maybe a few color tweaks:
Here's the video replay. Enjoy, it's even in 4K if you so desire.
« Last Edit: October 07, 2026, 05:26:21 pm by Ond »
abispac
  • Last login:Yesterday at 05:53:03 pm
Re: Pac-Man Legion
« Reply #404 on: Yesterday at 05:53:19 pm »
awesome work, you are the master
Zebidee
Re: Pac-Man Legion
« Reply #405 on: Today at 12:23:04 am »
Indeed that is his correct title. "Master Ond" certainly has a ring to it. I wonder what colour lightsabre he uses?
That's excellent information Zebidee! [...] The capacitor hack (or some variation of it) sounds good to me. It's a single button press of the AV button, I may use a transistor/optocoupler to momentarily parallel the existing TV/AV switch to avoid any unwanted voltage issue, we'll see.
Just don't overthink it. It'll just be a micom low voltage (5v or 3.3v) logic gate state, the cap momentarily pulling the logic low to trigger a "press", and once the cap is charged the circuit will be opened, disconnected from ground, releasing the "press", so no voltage flowing anywhere.
