Author Topic: A 0 games found workaround for MAME v.162 and later with Mala.  (Read 162185 times)
SGT
  • Last login:March 04, 2026, 07:39:32 pm
Re: A 0 games found workaround for MAME v.162 and later with Mala.
« Reply #40 on: January 05, 2021, 09:37:40 pm »
... and the method still works for Mame 0.227.   Someone should write a utility to make the job a little quicker?  ;D
Cakemeister
  • Last login:June 02, 2026, 11:00:20 pm
Old, but not obsolete.
1upmegaman
  • Last login:December 19, 2021, 12:39:43 pm
« Reply #42 on: December 19, 2021, 12:33:30 pm »
Well i have to thank the person who came up with this strategy it works but not all the way if u let mala pull the xml or even let cmd pull it and then use this strategy it does not change the exe u have to tell mala not to create xml then point mala to changed xml then u only have 3 times to start mala before it recognizes the change and locks then u must start process over agian. so the goal is to find a program that can turn exe scribble to normal xml format notepad++ must have this feature but iam a noob at at of this just like to play old games. IF ANYONE KNOWS HOW TO CHANGE THE EXE PLEASE POST.
loadman
  • Last login:September 12, 2026, 04:03:50 am
  • MaLa FE developer
    • MaLa
« Reply #43 on: May 30, 2026, 05:51:13 am »
Sounds like an easy fix to add to Mala2.0
loadman
  • MaLa FE developer
    • MaLa
« Reply #44 on: July 02, 2026, 11:33:55 pm »
..and Done.
Now if only there were people willing to test MaLa 2.0 Bata 1....   :)
I will be looking for testers soon
motoschifo
  • Last login:July 17, 2026, 06:57:55 am
    • Arcade Database
« Reply #45 on: July 03, 2026, 02:40:33 am »
I created this tool for Windows years ago and will update it in the future.
The "Utility" section includes an export function that uses different names for XML nodes based on the target MAME release number; perhaps this can help.
The replacement procedure (via ps, bash, cmd) can corrupt files, which should not be edited like normal text files.
In detail, this is the correct replacement pattern: from <machine name=" to <game name="
Including the "name" attribute prevents errors. If the "name" attribute appears in the middle of the attribure list of the node, the entire process will produce an invalid XML file.
I've attached a screenshot of the tool, now tested on the latest version of Mame.
You can do almost everything anonymously; no login is required.
I hope this helps while we wait for the MALA fix.
This is the link to download page of my website:
https://adb.arcadeitalia.net/?page=download
loadman
  • MaLa FE developer
    • MaLa
« Reply #46 on: July 06, 2026, 03:06:44 am »
That looks like a great tool. Also for grabbing missing art
I will put on my to do list to add "Export list of missing artwork and videos: to MaLa
