Author Topic: New Intel G3220 Socket 1150 Haswell Processor Mame  (Read 19639 times)
nimda79
  • Last login:February 18, 2014, 03:35:57 pm
  • I like Chicken
« on: January 22, 2014, 11:34:43 am »
This is more of an informational message than anything.
Quick background. I built a custom stand-up arcade machine on a tight budget, but didn't want to sacrifice quality. I utilized a SDTV made in 2007 (RCA brand) for my monitor, went with Ultimarc controls (8/4 way switchable), goldleaf buttons, and I-pac2 along with a mouse spinner hack and a 3" USB "happ" trackball for my setup. I had an old AM2 X2 Dell lying around so I initially used it to run my emulation w/ Maximus Arcade frontend, since I do MAME, NES, SNES, ATARI, Sega Genesis and Daphne. I've been lurking the forums for a long time and realized very quickly that AMD processors, especially old ones like that wouldn't cut it for games like MK4 in MAME. I have several 775 processors lying around, including the famous Intel e8400 but I have one problem, motherboards. I quickly found out that if I wanted to use that processor, OC it and keep it going for a long time, it wasn't going to happen since most boards I found were $80 and liquid filled caps, not to mention the idea of OC'ing something, while doesn't bother me if I am replacing it every 3 years, doesn't sound like a long term plan.
So after looking around and researching I decided on getting the Intel G3220 3.0Ghz dual core Pentium processor with a motherboard, and boy am I happy that I did.
Based on what I have seen, cores don't really matter, it's single thread performance that makes or breaks MAME. Based on this Mini Review (http://www.cpu-world.com/Compare/385/Intel_Core_2_Duo_E8400_vs_Intel_Pentium_Dual-Core_G3220.html) you can see that the G3220 is 1.3X's faster than stock e8400. If you OC an e8400 to the 4Ghz range they are practically identical in terms of speed only now you get a board you can support and upgrade processors on if needed (and cheaply!)
Games like Gauntlet legends run at 99% to 100% almost all the time. MK4 is always at 100%. I have yet to see any slowdowns at all. Config wise I am running MAME64 with hi-score and no-nag compiled for my system with 22khz audio vs the default 48khz at 640x480@29Hz (interlaced)
Note: if you want me to run a bench on a specific game, let me know and I will do it.
Parts and cost below:
Intel Pentium G3220 (Amazon had it for $62) http://www.newegg.com/Product/Product.aspx?Item=N82E16819116950
GIGABYTE GA-H81M-S2PH (has ESD protection! $61) http://www.newegg.com/Product/Product.aspx?Item=N82E16813128657
GIGABYTE GeForce 8400 GS 512MB (Card from old MAME PC and Fanless) http://www.newegg.com/Product/Product.aspx?Item=N82E16814125242
4GB DDR3 1333 (had laying around but costs $45) http://www.newegg.com/Product/Product.aspx?Item=N82E16820231179
1TB Hard Drive (Any 7200rpm drive will do $60) http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
Case and powersupply (I have spare supplies and cases lying around but you can get one for $50-60)
Total build cost: ~$300
ABACABB
  • Last login:August 26, 2023, 12:37:07 pm
Re: New Intel G3220 Socket 1150 Haswell Processor Mame
« Reply #1 on: January 22, 2014, 12:51:39 pm »
very interesting.... Thanks for posting :applaud:
ark_ader
  • I glow in the dark.
« Reply #2 on: January 22, 2014, 04:28:36 pm »
The G3220 is a bag of crap.  Fine for light office and desktop use, but not for anything intensive.  You get what you pay for, and it is highly doubtful that it is faster than the E8400.  Even the review said it was for light computing uses.  I would say this is a perfect example of what not to buy, unless you are a noob.
stripe4
  • Last login:April 16, 2026, 03:08:09 am
    • forum.arcadecontrols.com/index.php/topic,129541.0.html
« Reply #3 on: January 22, 2014, 04:44:35 pm »
Thanks for the advice! I'll go with i5 for Donkey Kong then.
nimda79
  • I like Chicken
« Reply #4 on: January 22, 2014, 11:46:25 pm »
While I appreciate your views:
A) Check the mini review http://www.cpu-world.com/Compare/385/Intel_Core_2_Duo_E8400_vs_Intel_Pentium_Dual-Core_G3220.html (This is real world comparison)
B) E8400 technology wise is 5 generations behind Haswell based processors, the proof is in the pudding ^. I have an e8400 and I am willing to prove that stock E8400 is slower than G3220 (beyond the chipset limitations of socket 775 and the power and heat produced by a 45mn processor vs a 22mn processor.
C) I've been building computers since I was 14 (20 years now) and have been in IT since I was 19 (15 years). Definitely not a noob to computers and how they function.  (Though I do not blame you if you thought so because you don't know me)
 :soapbox:
D) If you like burning all your money for overkill, that's your business. I offered to bench any game requested. Back your critique with facts not speculation.
Haze
    • MAME Development Blog
« Reply #5 on: January 23, 2014, 09:15:26 am »
this hasn't made a performance difference for at least 15 years.... sound is still always rendered at the same resolution, so unless you have a truly awful onboard sound that can't cope with a 48khz stream (and those have been extinct for probably 10 years) all you're doing is making it sound like bottom.
nimda79
  • I like Chicken
« Reply #6 on: January 23, 2014, 10:21:22 am »
Yea I haven't really tried it at 48Khz, I'll change it back and see if there is really a difference.
nimda79
  • I like Chicken
« Reply #7 on: January 23, 2014, 11:19:03 am »
Ark_Ader,
While trolling is fun, please refrain from trying to start a flame war. In case you haven't read the rules lately, check out rule #1 http://arcadecontrols.com/arcade_message_rules.html
You did miss a point of sustainability that I was trying to avoid with the e8400 and the e6400, those sockets are getting harder to support and find "good" motherboard for. There are a few that do support cheaper DDR3 but most are DDR2 which has been phased out as well, so it costs out the wazoo (just like the 775 motherboards). Since 775 was release, there has been 1156, 1155, and now 1150 sockets for lower end systems.
Cpu-world.com is NOT biased an any way. They take benchmarks then you choose which processors to compare them to based on the same benchmarks.
I.E. an E6400 vs G3220 http://www.cpu-world.com/Compare/383/Intel_Core_2_Duo_E6400_vs_Intel_Pentium_Dual-Core_G3220.html
Based on BENCHMARKS the G3220 is 2x's faster than the E6400 in Single and Multi-Thread operations. Even current AMD low-end FM2's that run at 4Ghz (6790K) run slower in single thread operations.
I would love to see the specs of the setup you used with the G3220 you tried out and what applications you had problems with. I am sure if you thought that a G3220 would satisfy a power user, then yes, I would agree they would be greatly dissatisfied with that choice. MAME however is different than most modern-day programs that multi-thread effectively. Using this processor for a single purpose will yield different results, and since we are only concerned about static horsepower being delivered to a single program, MAME functions rather well, and at a cheap price.
I'll post back this weekend and compare my results based upon these http://www.mameui.info/Bench/Bench.htm and if I eat crow, so be it.  :P
s_busby_uk
  • Last login:August 22, 2017, 02:28:51 pm
« Reply #8 on: January 23, 2014, 12:06:42 pm »
Heck I have a E6400 stock that performs better than that G3220.  We got a bunch in and had to return them as they were not fit for function. We opted for the G3240 instead (and they were the same price) which is why I think they are crap.  Go on, amuse us with your comparison, if you want to use a crap processor then you are completely in your right to do so.  If you are such an expert, why are you referring to a biased review?  :laugh2:
Not that these things are bible or anything, but they do provide a fairly useful insight:
http://cpuboss.com/cpus/Intel-Pentium-G3220-vs-Intel-Core2-Duo-E6400
A lot of this stuff can depend on the rest of your setup, but seems as thought under certain control conditions, the G3220 is better.
Funnily enough it's the CPU I've been looking at myself if I feel flash enough to actually buy new hardware for my build.
Out of interest, how does it handle Hyperspin (that is, if you're even running it!).
nimda79
  • I like Chicken
« Reply #9 on: January 23, 2014, 12:16:31 pm »
I'm running Maximus Arcade for the frontend actually. I ran it on my old AMD X2 AM2 system for a little bit and it seemed to handle it well. I doubt you would have any problems but I'll load it and check it out for you this weekend if you would like me to.
s_busby_uk
« Reply #10 on: January 23, 2014, 12:17:46 pm »
Would be amazing if you could - I'd like to be able to run it with all the bells and whistles ideally.
nimda79
  • I like Chicken
« Reply #11 on: January 29, 2014, 12:36:11 am »
Here's the benchmark results on my G3220 running at Stock 3.0Ghz vs e8400 running at 3.6Ghz overclock
Game      G3220(@3.0Ghz)      e8400 (@3.6Ghz)
blitz               181                          166
gauntleg       219                          221
gradius4       142                          125
propcycl        135                          135
scud             155                           86
starsldr        100                           58
e8400 benchmarks attained from:
Attached is screenshot of setup with benchmarks (Note: dolphin and radikalb did not run because of bad dump on my box)
s_busby_uk as soon as I have a chance I'll get you a video or something of Hyperspin running.
stripe4
« Reply #12 on: January 29, 2014, 04:12:22 am »
I'm curious about the MAME version you used to benchmark G3220. Was it also 0.141? I ask you this because performance regressions (and their subsequent fixes) are nothing out of the ordinary in MAME, here's an example:
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=309357&page=16&view=expanded&sb=5&o=&fpart=1&vc=1
The huge difference in scud and starsldr results was the one that made me suspicious. If MAME versions really do not match, can you please rerun the tests using 0.141?
nimda79
  • I like Chicken
« Reply #13 on: January 29, 2014, 09:45:26 am »
You are right, I tested mine on .149
I'll compile up .141 x64 for it and run again to get more "accurate" comparison.
I more wanted to show it can handle the workloads more than anything but I'll get you the results.
Like I said pretty pathetic for a Haswell processor.  ::)
Thank you, Captain Obvious  :applaud:
Still, this shows that it handles the more demanding games as I stated (and you laughed at).   ;D
I'd be curious how the AMD A8-5500 3.2GHz Quad-Core Processor compares to this, as you have recommended it to someone back in December.
http://forum.arcadecontrols.com/index.php/topic,135997.msg1406224.html#msg1406224
nimda79
  • I like Chicken
« Reply #14 on: January 30, 2014, 12:22:29 am »
Well just as I feared...my .149 rom set is too much different, so .141 won't run. I guess I'll have to install a second drive in my e8400 box and install Windows 7 x64 to give the full comparison. Bonus is that it will be stock clock speeds so it will be a true 1:1 comparison vs the benchmarks I linked to that have an OC'ed e8400.
Ark_Ader, would you like a blood sample or something? Holy crap dude. I proved it runs the games that drown most systems and you still have a hard on for flaming. I'm starting to doubt you are 45 as your profile states, due to the immaturity of your comments. As I see it you have 3 options: (1) Act your age (2) admit defeat (3) stop posting flame-bait comments
By the above comments, I see I am not the only one annoyed by this behavior. I really hope a mod sees this crap and puts you and your attitude where it belongs, post-hell and perma-ban. Add value or GTFO.
« Last Edit: January 30, 2014, 12:44:41 am by nimda79 »
ark_ader
« Reply #15 on: January 30, 2014, 01:45:33 am »
Sounds like someone doesn't like criticism.   ::)
I don't think those results are accurate, as I have said before the processor is crap.  Post something from a legitimate (and accurate) source.  But like I said before: If you want to use this crap processor in your build then please do so, but please do not advertise that this chip is beneficial as it is clearly not.  Name calling or ultimatums do not work on me.  Only the truth does.  ;)
nimda79
  • I like Chicken
« Reply #16 on: January 30, 2014, 01:49:57 am »
It is the truth. I posted a freaking screenshot, posted a standard benchmark from a site, and someone else posted another comparing it to an e8400 as well, yet you still drink from the fountain of ignorance.
How about you do this...tell me the "legit sources" that you speak of, since apparently the 2 shown thus far have not met your "standards"
ark_ader
« Reply #17 on: January 30, 2014, 01:57:53 am »
At least let's agree to disagree.   :cheers:
nimda79
  • I like Chicken
« Reply #18 on: January 30, 2014, 02:31:41 am »
Is this your way of saying, there isn't any sites that meet your standards? I really want you to drink the koolaid  >:D PCMark from FutureMark.com? (http://www.3dmark.com/compare/pcm8wrk/24997/pcm8wrk/8618) There's got to be some synthetic benchmark that you'll trust.
I have both processors e8400 and G3220. I'll run whatever, there's no shame in being wrong. Even I said I would "eat crow" if it came out that way. Hell I'll post a video if it makes you feel better. :P
ark_ader
« Reply #19 on: January 30, 2014, 04:30:42 am »
No, when I am wrong I freely admit it, and have done so on this board several times.  I am currently not in the position to perform any tests, but I do not mind revisiting this at a later date, and post scores of the A8 as requested.  I have made my position clear, on both a professional standpoint and personal as indicated.  It is not about blame or credibility.  The processor is crap.  Buy the next series up and you will see a huge performance increase.
I think you are taking my stance as personal slight. That is your problem.  :lol
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:April 05, 2026, 08:28:15 am
« Reply #20 on: January 30, 2014, 10:27:07 am »
 :angry: :angry: :angry: :soapbox: :soapbox: :soapbox: :angry: :angry: :angry:
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
nimda79
  • I like Chicken
« Reply #21 on: January 30, 2014, 11:01:17 am »
Wow, I love it when people's posts defending my stance get deleted, yet Ark_ader still get's to post flame bait(which obviously was taken). Mod's what gives?!
I don't care if you have 3 posts or 3000 posts. If you piss off a good chunk of the community by being more detrimental than helpful, and yet you still keep allowing people like that to post?
1. Be nice to each other. We're serious about this one. Disagree, debate, argue at will - but please be respectful. Messages that are flame-bait, hateful, racist, or otherwise pointlessly antagonistic will likely be sent to post-hell, and repeat offenders banned from posting.
Glad I wasted my time posting to this site, because apparently the rules don't matter when you have a high post count.
Judging by the amount of people coming to my defense I can only assume this isn't the first time he's started a flame war.
Yes I am talking to you JustMichael, NIVO, OSCAR, SirPoonga, SirPeale, HaRuMaN, DeLuSioNal29 and whomever else has power on this site.
I expect a post from one of you as to your reasoning as to why you allow his behavior to continue because this is CRAP.
saint
« Reply #22 on: January 30, 2014, 12:09:10 pm »
*Sigh*
I work for a living. I work full time. I have 3 kids. I have an ailing father. I occasionally like to have a personal life. I have run this web site for something like 15 years.
Don't yell at anyone else if you don' t like the moderating, it's all me. I stole 30 seconds from my job to try to trim out this thread while still keeping usable bits. I think Ark's a --cream-filled twinkie-- half the time. Maybe more than half. I've yelled at him more times than I can count. I also think he contributes something to the forum despite his negative personality. I am always going to err on the side of leaving content up and letting folks push the envelope of the rules, I try to keep a light hand. I think it makes for a better forum.
Specifically here, I deleted *four* of Ark's posts that I thought were needlessly inflammatory, and five other posts from other folks that were also inflammatory or made no sense without the context of the posts I pulled. All in the 30 seconds I was able to steal from my job. As usual I regret if my efforts failed to live up to expectations.
--- John St.Clair
     Project Arcade 2!
nimda79
  • I like Chicken
« Reply #23 on: January 30, 2014, 12:24:46 pm »
*Sigh*
Actually you fail to live up to your own RULES. How can you have a rules when you don't follow through on them?
Yes I have 5 kids, a full time manager job, and go to school full time as well. I fully get where you are coming from. Perhaps if you did what your rules said, you wouldn't have to "trim up" posts like these.
That's parenting 101, punish when needed but the second you don't punish when you say you will, that's when they bend you over and break the rules because there is no consequences (since you let them get away it over and over).
After all this is YOUR site, and I am not telling you how to handle your hobby site that tons of users come together and contribute on, I am suggesting you rethink your parenting style or risk having more people turned away because you allow this behavior of 1 person.
« Last Edit: January 30, 2014, 12:28:25 pm by nimda79 »
saint
« Reply #24 on: January 30, 2014, 12:30:41 pm »
I think I adequately cleaned up this thread, but if you see parts you'd recommend I clean up further I'm all ears.
Ark, stop being a --cream-filled twinkie--.
--- John St.Clair
     Project Arcade 2!
  • Last login:Yesterday at 07:04:52 pm
« Reply #25 on: January 30, 2014, 12:33:53 pm »
So can this processor run Gauntlet Legends 100% or not?  That's all I care about.
nimda79
  • I like Chicken
« Reply #26 on: January 30, 2014, 12:36:27 pm »
You did clean it up fully, and sorry for yelling at JustMichael, NIVO, OSCAR, SirPoonga, SirPeale, HaRuMaN, and DeLuSioNal29.  :P
I hope you make the right choice in future matters. Being a father of 3, I am sure you are fully aware that the internet turns grown men into children (with bigger pocket books).
And I am sure you don't hear it much but thank you for making sites like this one, as I have been using it over the course of my build.
saint
« Reply #27 on: January 30, 2014, 12:43:13 pm »
--- John St.Clair
     Project Arcade 2!
nimda79
  • I like Chicken
« Reply #28 on: January 30, 2014, 12:54:43 pm »
From the little I played it was constantly at 98-100% run speed but I am using .149 and there may be more performance tweaks, as shown above, with the newer .152 release. I've heard that it really taxes the game when there is a boss fight.
I'll try to get on it tomorrow, since I have class tonight and see what happens when I make it that far.
I know it's hard to justify $140 processor over an $70 processor for 500Mhz. You could get the G3420 or G3430 which gives you more memory bandwidth, since you can use DDR3-1600 vs only DDR3-1333 of the G3220, and slightly higher clock speed (200-300Mhz). If it dogs down, I'll see if I can get the .152 update running for that game and see how it goes.
ark_ader
« Reply #29 on: January 30, 2014, 02:40:33 pm »
OK I'm a --cream-filled twinkie-- for telling this guy the processor is crap, and suggesting the next one up, which is the G3420.  Which now it appears a better buy.   ::)
Sucks to be right.
nimda79
  • I like Chicken
« Reply #30 on: January 30, 2014, 02:44:23 pm »
Sucks to be right.
Nowhere in here have you even said to use that processor. Let you LIES be your comfort...
ark_ader
« Reply #31 on: January 30, 2014, 02:56:01 pm »
Sucks to be right.
I also had said the same thing when Saint Deleted my posts.  What is wrong with people today?  Can they not read the posts properly?
nimda79
  • I like Chicken
« Reply #32 on: January 30, 2014, 02:58:20 pm »
Sure sure...blame it on Saint... :P LOL
ark_ader
« Reply #33 on: January 30, 2014, 03:01:06 pm »
*Sigh*
--cream-filled twinkie--?  Thanks for that. ::)
Needlessly inflammatory?  Probably.  I should stop responding to those childish taunts.  Point taken.
I would never admin my site at work.  You are lucky.
saint
« Reply #34 on: January 30, 2014, 04:57:12 pm »
*Sigh*
I make the mistake of checking my personal email at work sometimes.
I'm sure you're a nice guy, but a disproportionate number of the complaints I receive involve a very small number of people. I don't respond to all of them, and they aren't that frequent, but certain names do come up more than once.... Make of that what you will.
--- John St.Clair
     Project Arcade 2!
ark_ader
« Reply #35 on: January 30, 2014, 05:36:09 pm »
This hobby tends to bring the eccentric out of people.  You will see a lot of that on KLOV.  When I make a statement about an item, either positive or negative, it is still my opinion.  Name calling and throwing fits is not going to change it.  This new guy's heart is in the right place, but he needs to realise that we are all different.  Taking time out and doing reviews is great.  It belongs in the review forum.  I would hate to see someone spending their hard cash on a weak processor, considering the hardware requirements that our hobby requires, compared to an older generation processor and system that is cheaply available on Ebay.
« Reply #36 on: January 30, 2014, 06:03:01 pm »
*Sigh*
Sorry to hear about your father.    My thoughts are with you.
s_busby_uk
« Reply #37 on: January 31, 2014, 10:41:39 am »
Sorry ark, it's all very well saying "we're all different", "know me know me ways" etc... but this "new guy" isn't the only person who thought some of your comments - or at least the way you were delivering them - were childish and unhelpful. Certainly, putting an animation at the end with a smiley rolling around in fits of laughter doesn't help as it implies - in my eyes - that you're laughing at someone's stupidity. Maybe you didn't mean it to come across like that, maybe you did - we'll never know - but the whole thing reeked of misplaced superiority to me and it's not hard to take sides against someone displaying that sort of behaviour.
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« Reply #38 on: January 31, 2014, 10:54:46 am »
Is it just me that thinks it's funny imagining a real fight between people obsessed with playing and building old arcade games? :laugh2:
nimda79
  • I like Chicken
« Reply #39 on: January 31, 2014, 12:42:55 pm »
The visual of that in my mind is far more hilarious than it would be in real life.
I do know from experience people generally don't complain about things until it's too late, most people put up with heavy trolling especially by someone who has a higher post count than them.
Then there are the small percentage, like me who don't put up with it.
Sadly it happens everywhere, I even saw it today on another forum (however that user was banned for excessive trolling).
I know it's fun to get your jolly's off or even disagree with someone, but there is disagreeing, and then there is being a dick about it as well while you disagree, like straight up calling someone a noob on the very first post to them because you have a different point of view. That's what the 16 year old gamers do over voice chat in online games, not adults (well at least I thought not).
I tried to be an adult about most of it and I even asked the behavior to stop, but I can only be egged on for so long before I've had enough, even after others tried to defend me.
