Author Topic: Sega Monaco GP 1979/1980 - My Remake  (Read 893599 times)
0 Members and 16 Guests are viewing this topic.
geecab
  • Last login:September 30, 2026, 04:11:04 am
Re: Sega Monaco GP 1979/1980 - My Remake
« Reply #600 on: July 25, 2025, 07:04:03 am »
Thanks excellent to hear GPForverer2024!
Its weird that changing from a Pulsed Wave to a Square Wave makes such a difference. I would have said Pulsed Waves should work better because that's what I thought the ignition coil on a car produces... Maybe the ignition coils on modern cars produce square waves... Maybe older revcounters would work better with a Pulsed Wave... who knows lol! Just happy we've got rid of that instability on your revcounter!
BTW. Should anyone ever feel the need to set the output wave back to a Pulsed Wave, you'll see there is a setting in arduino_rev_sim.ino that allows you to do this.
>>I had to increase the damping in your file to 95 because in first gear, the needle was rising too fast compared to the graphical rev counter.
I increased the RPM to 8300 because in second gear, it was lagging behind the graphical rev counter, and what's more, it didn't reach 8 RPM at full throttle.
OK, I think I understand what is happening, and I'm going to re-do my damping code to sort this :)
>>I just noticed a small, not too serious detail, but the needle has trouble at low revs.
Let me explain: if I accelerate and slow down, the needle stops at 1 rpm, which is normal.
However, if I have an accident with the car, the needle should drop to 0 rpm, and then it stops for about 1 second at 0.5 rpm, then 0 rpm, when it should drop directly to 0 rpm.
I think I understand what you are saying. So I can get a better idea of what is going on, can you run a couple of things for me:
1.In arduino_rev_sim.ini set DAMPING to 75 and RPM_STALL to 0 (I think its currently set to 500). Then run the demo like this:
    scoreboard_to_revcounter.exe 10 demo 8 8000 0
  The moments in the demo where the needle should move from 2000RPM to 0RPM, do you still see then needle 'stick' at 500RPM for 1 second?
2. Can you repeat the above but this time in arduino_rev_sim.ini change the line that reads:
    noTone(OUTPUT_PIN);
  and change it to:
    tone(OUTPUT_PIN, 1);
Many thanks!
« Last Edit: July 25, 2025, 02:52:39 pm by geecab »
GPForverer2024
  • Last login:August 24, 2025, 09:43:10 am
« Reply #601 on: July 26, 2025, 03:09:38 am »
Hi Geecab!
I changed the damping to 75 and the rpm_stall to 0 in the Arduino_rev.sim.ino file.
 And strangely, the needle goes all over the place.
What if there were throttle inputs from 1 to 6 very quickly?
Nothing's consistent anymore.
Then I modified the file by changing oar tone(OUTPUT _Pin,1); And the needle doesn't go to zero; it increases and then drops to 2 rpm.
Nothing's consistent either.
So I tried changing the damping to 75 and rpm_stall to 500 in the file, leaving the tone(OUTPUT _Pin,1); The rev counter responds better, but doesn't go down to 0 rpm at all; it only goes down and freezes at 500 rpm.
Finally, I went back to the file as I did yesterday with the Damping at 95, the rpm_stall at 500, and the noTone(OUTPUT _Pin);
This is the best result I have, except that the needle doesn't go directly to 0; it stops at 500 rpm for 1 second, then goes down to 0 rpm.
I noticed that as soon as I go below 500 with the rpm_stall, the needle goes crazy.
I hope this helps, thanks.
GPForverer2024
« Reply #602 on: July 26, 2025, 03:15:37 am »
Hi Geecab!
Finally, I went back to the file as I did yesterday with the damping at 95, the rpm_stall at 500, and the noTone(OUTPUT _Pin);
GPForverer2024
« Reply #603 on: July 26, 2025, 03:16:17 am »
Hi Geecab!
GPForverer2024
« Reply #604 on: July 26, 2025, 03:18:43 am »
Hi Geecab!
GPForverer2024
« Reply #605 on: July 26, 2025, 03:19:13 am »
Hi Geecab!
GPForverer2024
« Reply #606 on: July 26, 2025, 03:20:10 am »
Hi Geecab!
GPForverer2024
« Reply #607 on: July 26, 2025, 03:20:23 am »
Hi Geecab!
GPForverer2024
« Reply #608 on: July 26, 2025, 03:20:40 am »
Hi Geecab!
GPForverer2024
« Reply #609 on: July 26, 2025, 03:25:42 am »
Hi Geecab!
This is the best result I have, except that the needle doesn't go directly to 0; it stops at 500 rpm for 1 second, then goes down to 0 rpm. I noticed that as soon as I go below 500 with the rpm_stall, the needle goes crazy.
GPForverer2024
« Reply #610 on: July 26, 2025, 03:28:33 am »
Hi Geecab!
And strangely, the needle goes all a over the place.
Nothing's consistent either. So I tried changing the damping to 75 and rpm_stall to 500 in the file, leaving the tone(OUTPUT _Pin,1);
Finally, I went back to the file as I did yesterday with the damping at 95, the rpm_stall at 500, and the noTone(OUTPUT _Pin); This is the best result I have, except that the needle doesn't go directly to 0; it stops at 500 rpm for 1 second, then goes down to 0 rpm. I noticed that as soon as I go below 500 with the rpm_stall, the needle goes crazy.
GPForverer2024
« Reply #611 on: July 26, 2025, 08:52:28 am »
Hi Geecab!
This morning it was impossible to post on the site, I don't know why.
I changed the damping to 75 and the rpm_stall to 0 in the Arduino_rev.sim.ino file. And strangely, the needle goes all over the place.
Then I modified the file by changing oar tone(OUTPUT _Pin,1); And the needle doesn't go to zero; it increases and then drops to 2 rpm. Nothing's consistent either.
geecab
« Reply #612 on: July 26, 2025, 10:04:55 am »
Hi GPForverer2024!
>>I'm writing you a private message because I can't post anymore, I don't know why.
This forum is a bit strange sometimes. I'll post this response on the main thread too in case you don't receive it.
Thanks for running those tests. The point of them was to see what your revcounter did when you try to display low RPMs (lower than 500RPM). My revcounter's needle also goes crazy when I send it low RPMs. I was hoping your revcounter might be able to handle low RPMs better than mine (and your needle would drop to zero better, avoiding that 1 second freeze thing you are seeing), but clearly this is not the case. Anyways, good to know.
OK, so with this configuration when the game's RPM is 500 or lower, the Arduino will completely stop sending pulses to the revcounter. The Arduino will only send pulses to the revcounter when the game's RPM is greater than 500RPM. That's what the RPM_STALL thing does.
Regarding the "It stops at 500 rpm for 1 second, then goes down to 0 rpm", I can't say for sure, but I suspect this is just the way your particular revcounter was designed (So might be something we just have to live with). The occasions when the Arduino completely stops sending pulses, its like your revcounter freezes for 1 second at the last 'good' RPM its needle pointed at. Then if its still receiving no pulses after 1 second,  it decides the engine really has been switched off and its needle drops to zero. Does that make sense?
I have another arduino_rev_sim.ino that I'd like you to try please. I've improved the damping code (You shouldn't need to set it so high, and you shouldn't need to increase the rpm_range to 8300 anymore). I've also renamed the "RPM_STALL" option to "LOWEST_RPM", and added a "LOWEST_RPM_NEEDLE_ACTION" option which can be set to "DROP_TO_ZERO_RPM" or "POINT_TO_LOWEST_RPM". Hopefully this will make more sense when you read the descriptions of these options in the file.
The new version of arduino_rev_sim.ino can be downloaded HERE.
Hope this helps :)
go2ldook
  • Last login:December 25, 2025, 04:11:52 pm
« Reply #613 on: November 27, 2025, 10:39:39 pm »
Installed on Windows 11 and will not run from cmd line or using the application. Even tried running as admin. When I click START I get a brief screen pop-up then nothing. Would love to get it going. Was looking for this game and learned MAME could not emulate, then found your post. Was my fav racing game back in the day!
neilsnonsense
  • Last login:June 01, 2026, 06:21:13 am
« Reply #614 on: December 01, 2025, 05:16:00 am »
Runs fine on Win11 24H2 for me. A couple of things to be aware of:
  • You have to fully extract the archive. Don't try to run the exe from the Windows explorer view of the archive folder without extracting
  • When launching from command line the terminal has to have the current working dir as the dir with the mgpr.exe in. i.e. cd to this dir first and run only with command mgpr.exe - do not provide a path to the exe from another dir
geecab
« Reply #615 on: December 01, 2025, 07:32:48 am »
Hi go2ldook!
Some good advice from Neil in the last post. Just thought I'd add:
Unfortunately, WIndows 11 is very strict on what executables it allows you to run these days. When you click the GUI Launcher's START button, the GUI Launcher will attempt to run mgpr.exe with various command line arguments. Even though you may have run gui_launcher.exe as admin, those privileges don't automatically get assumed by mgpr.exe.
Thus, can you make sure you have given administrator privileges to both gui_launcher.exe and mgpr.exe. I.e. For both files, right-click and select 'Properties', go to the 'Compatibility' tab, check the box for 'Run this program as an administrator', click Apply, and then OK.
Hope this helps :)
geecab
« Reply #616 on: December 06, 2025, 01:01:20 pm »
Hi All!
I thought I'd put together a full release containing the new utilities I had been working on (Allowing the game to control a physical revcounter and 'CH340' USB Relay boards) and that has a few minor bug fixes. I have added new sections to the release note that explain how the new utilities work. I've also updated the first post on this thread to include the links to the new version that you see here.
enjoy! :)
Monaco GP Remake (v1.5.2) is ready download from my google drive.
****EDIT: This version is now obsolete, please see initial post (on page 1) for download links to the latest version****
Extract from the release notes version history:
v1.5.2 (6-12-2025)
 - Added new Scoreboard To Relays utility. See Section 13 of the release notes for details.
 - Added new Scoreboard To Revcounter utility, Arduino sketch file ('arduino_rev_sim.ino') and circuit diagram ('arduino_to_revcounter_circuit.jpg'). See Section 14 of the release notes for details.
 - OPTO2_DEVICE configuration option added. See Section 9 'Accelerator Pedal' of the release notes for details.
 - Bug fixed on the 'Enter Your Name' screen. Ensure the player is off the gas before detecting the first pedal press.
 - Bug fixed in the arcade game track file that was causing 'Number of Opponents' errors in the console window.
« Last Edit: May 23, 2026, 04:50:24 am by geecab »
janderclander14
  • Last login:May 24, 2026, 05:06:47 pm
« Reply #617 on: March 05, 2026, 04:39:54 am »
Hello geecab,
Thanks a lot! I'm setting this up in a dedicated machine with a raspberry pi 5 and some complementary 'outputs' (secondary lcds, 7 segment display, leds, etc.). May I ask whether it would be possible to implement any of the following QoL features?:
- I only have a mouse and a joystick interface connected to the raspberry. I was able to map the main controls to the mouse and the joystick but it does not seem to be possible to specify the device used to "exit". So, as it is now, I need to connect a keyboard just to exit the game. Would it be possible to add an option to map the exit to a button (or, even better, a combination of two buttons) of the joystick device?
- Regarding joystick mapping, I see the game recognizes the joystick buttons and axes, but not the digital hat (up, down, left, right), which in my case corresponds to the dpad.
- Being able to change the ingame audio volume in real time with some mapped joystick buttons (or button combinations) would be very nice.
Again, thanks for this great remake!
« Last Edit: March 07, 2026, 06:18:52 pm by janderclander14 »
hafoudha
  • Last login:September 18, 2026, 11:06:46 am
« Reply #618 on: March 27, 2026, 05:55:07 pm »
Thank you again for this game, I ended up running it on an arcade on windows games, I deleted all cfg files except the one I need to use, so if I hit gui-launcher.exe I'm prompted with the gui with just 1 cfg to select, it's running good, but I wonder if I can bypass that gui and as soon as I hit gui.launcher.exe the game starts without the need to select the cfg file. or if I can run the game by hitting mgpr.exe without the need to select the cfg's number.
neilsnonsense
« Reply #619 on: April 02, 2026, 07:31:20 am »
mpgr.exe -cfg "my config.cfg"
Just replace 'my config,cfg' with the correct filename for the config you want to launch.
More details are available in geecab's release notes
hafoudha
« Reply #620 on: April 03, 2026, 09:06:18 pm »
I was able to run the game using your suggestion, thank you so much, from the game folder I opened  terminal, wrote mgpr.exe -cfg 1980x1080_pro_monaco_gp_8bit.cfg . the game started with my favorite cfg, but when I close the game then hit mgrp.exe I get the full list to chose from, I think it did not save my settings to run that specific cfg automatically.
« Last Edit: April 03, 2026, 09:11:16 pm by hafoudha »
hafoudha
« Reply #621 on: April 03, 2026, 09:08:44 pm »
« Last Edit: April 03, 2026, 09:16:18 pm by hafoudha »
geecab
« Reply #622 on: May 03, 2026, 11:04:07 am »
Hi hafoudha!
You always need to 'tell' mgpr.exe what configuration to run, otherwise it will display a menu and ask you to manually choose a configuration (Based on what .cfg files exist in the cfg directory).
May I suggest doing the following....
In the directory where mgpr.exe resides, create a file named "go_pro_monaco_gp.bat". Edit that file and add the following text:
call mgpr.exe -cfg 1920x1080_pro_monaco_gp_8bit.cfgthen save the file.
Now all you need to do is double click on the go_pro_monaco_gp.bat and your favorite configuration should start.
geecab
« Reply #623 on: May 03, 2026, 11:39:32 am »
Hello geecab,
Hi janderclander14!
Regarding your joystick's hat buttons, you say these correspond to the keyboard's dpad keys. So if, say, your joystick's "up hat" button corresponds to the "8" dpad key, couldn't you set MGPr's control options to change the KEY_ACCEL to PAD_8.  Wouldn't that mean each time you pushed the "up hat" joystick button your car would accelerate?
Yes, I'll add this (Should have done this along time ago). I'll add some extra options for the two button combo exit too.
Sounds like a good addition! I'll add this too.
janderclander14
« Reply #624 on: May 03, 2026, 03:52:00 pm »
Hi geecab
Thanks for your answer
No, sorry. I'm only using a joystick that reports (in windows control panel) as 2 analog axes, several buttons and a directional hat (that physicially corresponds to they joystick's dpad). Both the analog axes and the buttons can be mapped through the menu and the config files, but the hat directions do not show.
Thanks a lot for considering this!
geecab
« Reply #625 on: May 03, 2026, 04:54:22 pm »
Hi janderclander14!
Thanks for clearing that up about the hat dpad thing. I think MGPr might be recognizing your hat controls as another analog axis for an additional joystick. Not sure if you've tried this, but if you go through all the "steering_device" options, do you see any hat controls for any joystick? If you do, and you select it, then when you play the game does moving the hat have any affect on the steering? I know you most probably don't want to steer with the hat, but it would be a good test to confirm that MGPr is seeing the hat movement in some form.
Just a couple of other questions, what game controls did you want to map the hat to? And also what type/make of joystick do you have (Just out of interest)?
No worries, I've made a start on it! :)
geecab
« Reply #626 on: May 04, 2026, 11:37:32 am »
Hi janderclander14,
I'm having second thoughts about modifying MGPr to support combinations of keys/buttons to trigger specific inputs. It will just make the in-game configuration menu too complex.
Just wondering, have you looked into the free "antimicrox" tool? Its specifically designed to map all imaginable combinations of gamepad axis and buttons to keyboard keys. I've installed it on Linux, its got a nice front end, its available to Raspberry Pi also...
janderclander14
« Reply #627 on: May 04, 2026, 03:04:26 pm »
I'm using an arduino leonardo with the Joystick library and a xbox controller-like layout: 1 dpad/hat, 4 analog axes, and several buttons. The arduino also reports as a mouse, where the mouse X axis is read from a rotary encoder. All axes and buttons, including the dpad, work fine in emulators and the emulationstation frontend installed in the same machine.
In the ingame menu, the steering_device option shows mouse x, mouse y and the four analog axis (but not hat or digital directions, which are reported as a digital 'hat'). For the remaining 'digital' devices (gear, coin, start), it cycles through mouse button numbers and the joystick buttons, but not the dpad/hat. Being the latter a digital input, I was expecting to be able to map any of the directions (up/down/left/right) to any fo the digital devices. For example, mapping gear_change_device to 'hat_up' or, if a volume_device is added, map volume up/down to the up/down hat.
My current config file regarding control is a follows:
CONTROL steering_device "mouse axis x"
CONTROL accelerator_device "arduino llc arduino leonardo stick 2 x"
CONTROL gear_change_device "arduino llc arduino leonardo b2"
CONTROL coin_a_device "arduino llc arduino leonardo b3"
CONTROL start_device "arduino llc arduino leonardo b 4".
« Last Edit: May 04, 2026, 03:22:16 pm by janderclander14 »
janderclander14
« Reply #628 on: May 04, 2026, 03:09:11 pm »
Hi janderclander14,
I understand and yes, I'm familiar with it.
I'm also perfectly fine with no combinations of keys. Just being able to map the inputs I currently don't use (such as the dpad/hat I was mentioning above) to these special functions, or that all functions can be maped to a joystick, rather than being keyboard-exclusive, is more than enough!
geecab
« Reply #629 on: May 05, 2026, 01:13:46 pm »
Hi janderclander14,
I think I see what is missing from my code which is the reason for hat devices not showing up. I probably need to get myself an Arduino Leonardo board to ensure this gets implemented correctly.
Have you considered modifying your arduino sketch to trigger button presses when the hat is moved (This is in addition to the "setHat" stuff I believe your sketch currently does)? So basically, when you move the hat whilst playing MGPr you will be able to detect a button press... And when you move the hat whilst running your emulationstation frontend you'll still be able to detect the hat movement the old way too.
janderclander14
« Reply #630 on: May 05, 2026, 03:28:34 pm »
Hi janderclander14,
Thanks. That's indeed a solution, but it may complicate control mapping, e.g., in MAME, because a button press will be reported as two, and any of them would end up being assigned. It may also require reconfiguring standard mappings to avoid interferences. At the end, the issue is that the cabinet is not exclusively devoted to MGPr, so I would prefer to keep a more standard input behavior.
Anyway, not a big deal, I can live not being able to map the hat :D I only asked because I found it strange that these inputs were not assignable.
geecab
« Reply #631 on: May 07, 2026, 02:43:05 am »
I understand what you are saying regarding complicating MAME's control mapping and its good to know you can live without the hat not working. Leave this one with me for a bit anyway (I've got a Teensy dev board somewhere, I can write a sketch for that and get a better idea of how to handle the hat events).
In a couple of weeks I should have the following going:
 - Allow exit MGPr by pressing a joystick button or mouse button or key (Previously, you could only define a specific key).
 - in-game volume up / volume down controls using joystick buttons or mouse buttons or keys.
 - Allow reset hiscores by holding a joystick button or mouse button or key (Previously, you could only define a specific key). I thought I'd add this for completeness so that MGPr would have no more 'keyboard-only' controls.
janderclander14
« Reply #632 on: May 08, 2026, 06:40:00 pm »
Great! I'll be happy to test
geecab
« Reply #633 on: May 18, 2026, 04:15:19 am »
Hi janderclander14!
Here is the next release, v1.5.3, with the following changes:
 - Added support for exiting MGPr using a joystick or mouse button
   (Previously, the only option was to use a defined key).
 - Added support for resetting hiscores using a joystick or mouse button
 - Added in-game volume up and volume down controls (See section 5 of the
   release notes for more details).
I've only built the Linux package for now? If you are happy with it I'll update the first post on this thread will this version (Where I'll also add a link to the Windows package).
You do have to press and hold the volume buttons for over a second before the audio level starts to change (Feels a bit clunky at first, but stops the player from making accidental volume changes). There is an onscreen "Keep held to change" message that appears immediately when you press a volume button. Pressing both volume up and down buttons as the same time sets the volume to the default level (50). Volume changes get saved to the game configuration file upon exit (Thus, remembered the next time you start up MGPr).
For Linux and Raspberry Pi:
    The release supports x86 Linux PCs Ubuntu 24.04 based distros (e.g. Linux Mint 22) and ARM Linux Debian 12 ('Bookworm') based distros (e.g. latest Raspberry Pi OS) 32-bit & 64-bit:
    Monaco GP Remake v1.5.3 for Linux & Raspberry Pi (Download from my Google Drive)
    Please read the release notes HERE.
janderclander14
« Reply #634 on: May 19, 2026, 03:05:06 pm »
All changes worked as expected. Tested on a Pi 5 with Bookworm. Thanks!
geecab
« Reply #635 on: May 20, 2026, 03:15:51 am »
Great Stuff! Thanks for giving that a test, I'll get the Windows release ready shortly :)
Edit: Monaco GP Remake v1.5.3 for Windows and Linux, now available for download on the first post of this thread.
« Last Edit: May 24, 2026, 05:23:09 am by geecab »
burritodamus
  • Last login:September 15, 2026, 01:47:22 pm
« Reply #636 on: June 22, 2026, 12:24:36 pm »
Enjoying the game and have added to my Cabinet through Launchbox and a batch file.   Can you think of any logic in the code that would prevent me from being able to use reshade against the mgpr.exe?  It seems to take exclusive screen overlay access and I cannot access the reshade gui to set scanline effects,  would lovbe to complete the look and feel with CRT effects.
Thanks for the recreation and your time.
geecab
« Reply #637 on: June 23, 2026, 01:40:46 pm »
Hi burritodamus!
You might want to ask AI "what can stop Reshade working with games that use the Allegro Game Library?" (Because that is what MGPr was built with).
Seems that if the line of your batch file that runs mgpr.exe begins with the 'start' keyword, then according to AI that might cause Reshade to fail. Any chance you could copy & paste the contents of the batch file that starts mgpr.exe with?
You could also try changing the DISPLAY_OPTIONS -> SCREEN_MODE setting using the in-game editor to the WINDOW option and see if that makes a difference?
Hope this helps!
burritodamus
« Reply #638 on: June 26, 2026, 11:56:04 am »
Thanks for taking time to reply.
I have tried the direct injection method....using opengl, and all DX variants.   I have also tried renaming .dll as well as mix and matching the various properties.... the only way I can get reshade to show a log is using opengl and toggling that in the game.
In doing so I can see in the log:
Registering hooks for 'C:\WINDOWS\system32\opengl32.dll' ...
I am not a coder, but it looks like the game may be forcing reshades hand here and specifying the windows system32\opengl32.dll rather than the copy reshade puts locally to the games executable.
geecab
« Reply #639 on: June 26, 2026, 12:58:03 pm »
Thanks for giving those suggestion a go.
I've just asked google AI "My allegro game is registering hooks for c:\windows\system32\opengl32.dll rather than the copy Reshade puts locally. My allegro game is 32-bit and statically links with allegro v5.0.10.1".. It responds with quite a few interesting solutions (You might want to ask it the same thing). I thought this one answer sounded worth a try:
Change Windows DLL Search Order:
You can force Windows to check the local game directory before looking anywhere else by enabling safe DLL search mode or using a local redirection file.
- Create an empty text file in your game directory next to your .exe.
- Rename this file exactly to appname.exe.local (replace appname with your actual game executable name).
So maybe creating an empty file named "mgpr.exe.local" in the same directory as mgpr.exe will do the trick?
It also suggested how I could rebuild mgpr.exe to force it to look for DLLs locally before looking in system directories. I don't mind doing this, but rather we try and find a simple workaround first.
Hope this helps?
