Author Topic: fan for arcade  (Read 2948 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
fan for arcade
« on: August 08, 2013, 10:14:59 pm »
hello there i just got this fan for free idk much about this.. sticker says frull range   :dunno can i just connec fan to power :dunno
SORHP
  • Last login:January 18, 2026, 03:57:45 pm
fan for arcade
« Reply #1 on: August 08, 2013, 10:33:31 pm »
That's not a fan, it's a power supply
Games: Super Punch Out, Fix It Felix Jr, DK, DKjr, DK3, PC10, UMK3, TRON, MS-Pac, Pac, Centipede (2x), Robotron, Galaga, Space Invaders, Street Fighter 2 CE, X-Men vs SF, BuckHunter HD, 2X Custom Vewlix, Custom Nintendo VS 3/4, Atomiswave
Re: fan for arcade
« Reply #2 on: August 08, 2013, 10:34:10 pm »
That's not a fan. It's a PC power supply.  It says right there on the Zalman sticker.
Re: fan for arcade
« Reply #3 on: August 08, 2013, 10:36:39 pm »
Its not a power supply, its a power supply shell with the fan. its pretty much the same as a PC fan.
Caparo8bit
  • Hyperspin/Maximus
Re: fan for arcade
« Reply #4 on: August 08, 2013, 10:40:03 pm »
well can i take the fan out and connected in a 12v line?
Brian74
  • Yep... I built that!!
Re: fan for arcade
« Reply #5 on: August 08, 2013, 10:40:22 pm »
LoL, it looks like a power supply. Or is it a power supply shell with a fan in it?^-^
Sent from my SGH-T989 using Tapatalk 2
Caparo8bit
  • Hyperspin/Maximus
Re: fan for arcade
« Reply #6 on: August 08, 2013, 10:57:04 pm »
ok my arcade has a fan and two extra power ports available can i connect second fan on those ports (secon fan is for cpu) chec pics please
"And I know the im going for the Noob of the year"
« Last Edit: August 08, 2013, 11:00:10 pm by Caparo8bit »
  • Last login:April 15, 2026, 12:32:32 pm
Re: fan for arcade
« Reply #7 on: August 08, 2013, 11:05:13 pm »
Hey, is it me, or does that fan look like power supply?
GoYouSalukis
  • Last login:March 18, 2020, 11:58:59 am
Re: fan for arcade
« Reply #8 on: August 08, 2013, 11:07:48 pm »
The fan in your last photo says 12VDC, so yes you can connect it to 12 volts. the direction is controlled by which way you connect the wires. If it is blowing the wrong way, just reverse the wires.
Caparo8bit
  • Hyperspin/Maximus
Re: fan for arcade
« Reply #9 on: August 08, 2013, 11:08:32 pm »
i gues its you
Caparo8bit
  • Hyperspin/Maximus
Re: fan for arcade
« Reply #10 on: August 08, 2013, 11:15:26 pm »
thanks question fan for arcade amp is blowing out shold i put second fan blowing in
GoYouSalukis
Re: fan for arcade
« Reply #11 on: August 08, 2013, 11:55:58 pm »
I would set it to blow in so that you get a positive airflow through the case.
Re: fan for arcade
« Reply #12 on: August 09, 2013, 12:12:01 am »
i gues its you
 :lol
Drnick
  • Plodding Through Life
Re: fan for arcade
« Reply #13 on: August 09, 2013, 02:50:55 am »
Set the one at the bottom to blow air into the cabinet (Will probably want reversing from existing) and then set the one you have higher up to suck air out of the cabinet.   Warm air rises so this would be the most effective. I would recommend a dust filter for the one blowing air into the cab.
Re: fan for arcade
« Reply #14 on: August 09, 2013, 08:04:00 am »
DONT TOUCH THOSE.
Thats the AC line in , its fused from the power cord to the power supply. If you want to tap 12v, tap it off the power supply where it is clearly labeled +12v. Honestly if you're putting a PC in there I'd just get another PC fan and tap it off the PC power supply.
