Author Topic: PC in the case, or gutted?  (Read 15399 times)
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
« on: July 25, 2013, 06:18:58 pm »
Hi all,
What are everyone's thoughts on stripping the PC for my cab, or leaving it in the case.
When I started building PC's many years ago, I was taught that the airflow through a PC was designed so efficiently and directionally that if you actually took the hardware out it would overheat causing performance problems.
Now I know that is probably an extreme example, or a point over emphasised, but I am struggling to come up with a good solution.
a) a PC inside a case & strapped inside my cab would not get any 'fresh' airflow thereby potentially causing overheating problems.
b) a PC stripped would have no directional airflow other than a couple of fans / outlets in the cab, also causing potential overheating.
Thoughts?
Thanks chaps...
EssJay
JDFan
Re: PC in the case, or gutted?
« Reply #1 on: July 25, 2013, 06:36:57 pm »
6 of one half dozen of the other !!  :dizzy:
Figure either solution should be fine as long as there is some airflow inside the cab and decent heatsinks on the various parts of the PC (ie. GPU - CPU - possibly RAM chips) - possibly a couple fans or air vents in the bottom portion of the case to allow air in and a couple toward the top to vent hot air out. Figure nowadays most GPUs and CPUs have large enough heatsinks and fans on them to keep them cool enough for either situation unlike old times when the case usually had a single small fan if that other than the one on the PSU and the heatsinks were minimal, and they are made with enough headroom that a few extra degrees in temp isn't going to cause shut down.
DGP
  • Gamer4Life
    • My Toys...
« Reply #2 on: July 25, 2013, 07:43:20 pm »
I went in-case with liquid cooling.
Jason
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #3 on: July 25, 2013, 07:49:10 pm »
I left my PC in the case but without a cover.  Also put a fan near the top of the cabinet.  Have never had an issue.
gildahl
  • Last login:September 24, 2025, 10:32:51 pm
« Reply #4 on: July 25, 2013, 08:43:30 pm »
shponglefan
« Reply #5 on: July 25, 2013, 09:38:38 pm »
I remember hearing the same thing, but in my experience I think it's just an urban legend.
UFO
Re: Re: PC in the case, or gutted?
« Reply #6 on: July 26, 2013, 06:11:04 am »
I used one of these
http://www.newegg.com/Product/Product.aspx?Item=N82E16811353001
I'm liking that...
If I were to strip the case, I would be taking out the case board too and attaching everything to it, then attaching that to the cab case - along with a good gap between the two for airflow.
UFO
« Reply #7 on: July 26, 2013, 07:04:43 am »
Not sure its an urban legend - I know it to be true but I wonder what the best way to keep cool would be (other than using liquids!).
Access would be a pain if  the hardware were inside a case...
Here is some more stuff on airflow: http://www.iceteks.com/articles.php/casecooling/1
I guess if no one here has had any issues, then I will just strip everything from the case...
Cheers guys...
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #8 on: July 26, 2013, 07:26:06 am »
I have 3 different cabs that have computers in them, all 3 are overclocked and deceased. I made sure to do my heat testing in the most extreme of circumstances such as leaving them benchmarking under full load for 48 hrs with crt monitors running and never had a problem.
1 is in a driving cabinet that has 1 fan at the back of the cabinet pulling air out. There are vent holes at the front to pull cool air in. I added the fan here because of how little room there is in the bottom of the cabinet. Not sure if it's needed but it was piece of mind because I have a home theatre amp in there as well. 1 is a mortal Kombat 2 cab with no fans. 1 is a new astro city with no fans.
Sent from my Nexus 4
« Last Edit: July 26, 2013, 07:29:08 am by brad808 »
Dawgz Rule
« Reply #9 on: July 26, 2013, 08:30:47 am »
Cabinet size is also a consideration.  My cab is full size so there is a lot of ambient loss within the cabinet itself.  I should have added that I have a 29" arcade monitor stuffed in there as well and have left it running for days at a time without any issue.  I think the fan I used on the top of the cabinet was a 120mm.
« Reply #10 on: July 26, 2013, 08:34:29 am »
I like to get rid of the PC case...mainly as there is a lot of wasted space otherwise (who needs all the drive bays etc). It also makes the inside of your cabinet look more like a 'real' arcade machine, if you care about things like that.
I've never had a problem with my main cabinet, which doesn't have any intake vents. I am a bit more concerned about my recent build (which also has no intake vents), as the PC design means no CPU fan as such, just an exhaust fan which draws air over the CPU heatsink. But that would still be an issue whether in the PC case or not.
« Reply #11 on: July 26, 2013, 08:41:28 am »
Ive done both, but Im leaning towards leaving it in the case just because its easier for me. I can unhook the PC, pull it out of the cab then work on it. And it makes swapping out rigs even easier.
brad808
« Reply #12 on: July 26, 2013, 08:58:53 am »
That's a good point. I should note that my pcs are mounted on wooden boards that can be removed if needed. I wouldn't fix the components directly to the cabinet itself.
Dawgz Rule
« Reply #13 on: July 26, 2013, 09:10:28 am »
Exactly why I did it that way.  I also stripped out everything that was not necessary.   Have a couple of USB ports on the outside of the cabinet should I need to do a file update or use a keyboard.
mike_bike_kite
  • Last login:January 07, 2023, 05:16:39 am
« Reply #14 on: July 26, 2013, 10:23:47 am »
I left mine in the chassis for my last build but didn't include the sides. I did this because I wanted to be able to view the innards of the build and having them attached to the chassis made it easier to position everything. It also makes the PC easier to test before installing into the cab. You should really be using a relatively low power CPU anyway - there's no requirement for high power CPU's in a cab.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #15 on: July 26, 2013, 10:51:07 am »
I decase and board mount my pc. Hot glue is all you need to secure the power supply. A couple of wood screws secure the mobo.
Todays Mobos have sound, video, and network integrated so there is no worry about cards to secure. Once the OS is installed I also remove the optical drive.
Any tweaks are then done over the network or with a usb chip.
shponglefan
« Reply #16 on: July 26, 2013, 12:33:32 pm »
All I can say is that I have never seen a situation where a cased PC has outperformed a partially or fully decased PC in terms of cooling.  I can see it being an issue if one puts a decased PC into another type of enclosure without proper ventillation or airflow.  But decasing by itself shouldn't cause issues.
paigeoliver
  • Awesome face!
« Reply #17 on: July 26, 2013, 01:37:52 pm »
When looking for authenticity one should realize that pretty much every arcade game that ever ran on PC hardware left the computer in the case.
GiMiK
  • Last login:October 21, 2013, 03:13:54 pm
« Reply #18 on: July 26, 2013, 03:10:27 pm »
I would see 3 considerations for making this decision, heat, dust, and grounding.
Cases can improve airflow, but that is not a given fact, poorly designed cases from ultra cheap big box store PC's can actually make it worse. A high end case can net you a difference of ~5C in my experience between running it open and closing it up. In an enclosed area of a cabinet that performance may be lost. As long as you have good airflow through the case, you should be fine. If you are concerned there are programs you can run to report heat levels from a number of components on your system. Generally speaking below 70C is good, 70-80C is pushing it, anything beyond that risks failure.
On the subject of dust, the most immediate risk of dust in my experience is from clogging vents of power supplies and jamming the fans. I can't speak to how quickly dust accumulates in a cabinet, but I would monitor the amount of dust.
Grounding only really applies if you go without a case, one or more of the screw mounting points on the case will often have a silver ring around it that is the ground. Normally that connects to the motherboard mounting panel in the case, which grounds itself to the power supply. If you are mounting it to the cabinet directly, make sure you maintain the ground in some fashion
UFO
« Reply #19 on: July 26, 2013, 05:51:13 pm »
Thanks guys - all very valid points to consider.
For my own interest, I will install some software to monitor temps while it is currently out of the cab and see what difference there is when it is stripped and installed in the cab.
I hope to be able to report the findings!
paigeoliver
  • Awesome face!
« Reply #20 on: July 26, 2013, 07:49:35 pm »
Out of the many, many PC based cabinets I have built only one ever suffered a heat death and it was a decased one.
UFO
« Reply #21 on: July 27, 2013, 04:36:45 am »
Out of interest, was the PC in a case, or decased?
paigeoliver
  • Awesome face!
« Reply #22 on: July 27, 2013, 12:49:41 pm »
Decased PC, Pentium 3 based, with a voodoo 3 graphics card in a Space Firebird mini cabinet. It did not die on me, it died about a year or two after I sold it at superauctions. Saw it on ebay with a brand new PC in it and asked them what happened.
  • Last login:April 15, 2026, 12:32:32 pm
« Reply #23 on: July 27, 2013, 12:54:04 pm »
I always decase because it looks better and seems more authentic. Having said that, I'm building a cab for my wife's friend and I'm keeping it cased for simplicity's sake.
chopperthedog
  • Last login:Yesterday at 04:14:30 pm
« Reply #24 on: July 27, 2013, 01:06:12 pm »
My current builds / redos have all been left in the case. Now when I built my first cab in 2003 (which I will make a project thread for so we can all have a good laugh at my expense) I used parts that I had acquired but had no case for. The computer ended up dying in 2008 and I can't figure it out. But I can't tell you how many times I bumped the cpu fan and vid card or dropped a tool while I was still tinkering with the cab. If the pc is cased and should something ever go wrong all that is required is unplugging a few cables and bring the unit to the bench.
good day.
« Last Edit: July 27, 2013, 01:08:12 pm by chopperthedog »
darkSSide
  • Last login:March 24, 2024, 08:19:48 pm
  • I want to make my own money!
« Reply #25 on: July 27, 2013, 01:52:06 pm »
Kind of on subject but,what about fans?
I'm thinking maybe one on top blowing in and one in the back of the cab blowing out? What would be suggested?
Sent from my Atari 2600
  • Last login:Yesterday at 06:21:17 pm
« Reply #26 on: July 27, 2013, 03:58:25 pm »
Remember that heat rises.
Work with the thermodynamics instead of against it.
Top fan blowing out -- lower fan blowing in.
shponglefan
« Reply #27 on: July 27, 2013, 04:16:42 pm »
+1
darkSSide
« Reply #28 on: July 27, 2013, 06:01:36 pm »
Gotcha,THANX!
UFO
« Reply #29 on: July 31, 2013, 07:49:31 am »
Hmm... here ia my problem!
Can't actually fit the coin mech in, so decased it is!
Dawgz Rule
« Reply #30 on: July 31, 2013, 08:32:14 am »
That does look kind of tight in there and the power supply fan is right up against the side.  Definitely agree on removing everything from the case.
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« Reply #31 on: August 17, 2013, 09:44:17 pm »
sweet  :cheers:
ahofle
    • Arcade Ambience Project
« Reply #32 on: August 17, 2013, 10:36:49 pm »
+1
IMO cabinet size is the only consideration.  I have an upright with a cased PC and a cocktail with a decased (because nothing else would fit), both of which have been operating fine for years.  If space is tight, make sure to install a large quiet fan somewhere near the top.
Caparo8bit
  • Hyperspin/Maximus
« Reply #33 on: August 17, 2013, 11:18:43 pm »
this is what i set so far 12v fan will b on top of cpu
love the fan (green circle) can change speed  L.M.H
CoryBee
  • Bopity Boopy
« Reply #34 on: August 18, 2013, 12:02:34 am »
Is that a direct tv box in there?
Caparo8bit
  • Hyperspin/Maximus
« Reply #35 on: August 18, 2013, 12:09:19 am »
nope is a DCCK Directv Cinema Connection Kit normaly used to connect HDDVR to internet (wifi) in this case is connectin my cpu to the internet  ;D
kiwasabi
  • Last login:September 28, 2014, 12:14:51 pm
« Reply #36 on: August 18, 2013, 02:54:59 am »
If space is not an issue, what would you guys recommend? In case, not in case, or in a hacked up/ cannibalized case as someone else mentioned? I guess if space is not an issue, the best option may be to do it out of the case, and go overkill with the fans to guarantee no overheating?
Caparo8bit
  • Hyperspin/Maximus
« Reply #37 on: August 18, 2013, 12:43:49 pm »
I think with case is best ( remove side covers)
UFO
« Reply #38 on: August 18, 2013, 04:41:18 pm »
This is what I ended up with...
Hambo3
  • Last login:December 03, 2014, 05:19:21 pm
    • insert coin
« Reply #39 on: August 18, 2013, 05:04:22 pm »
Just my 2 cents, unless someone can say they had problems with one or the other i guess it doesnt matter but a case does protect the PC. Mine is without and wondered why it kept cutting out, until i found a large wood chip had somehow got stuck in the fan!!  :lol
