Author Topic: fooling with m2emu network  (Read 485854 times)
0 Members and 95 Guests are viewing this topic.
dekkit
  • Last login:October 03, 2026, 08:18:05 pm
Re: fooling with m2emu network
« Reply #320 on: October 09, 2024, 07:03:47 am »
Updated 14/5/26 - various edits to the post tl summarise experiences.
Firstly thank you sailorsat for the massive efforts to debug the emulator and try and troubleshoot the network component also to the community for keeping this thread active for one of the best arcade games ever made.
I recently setup another 2 player Daytona emulation rig (with newer hardware ) and was really surprised to see how differently (ie worse) the network performed on the newer rig when compared to my older pair of laptops.
Note: I use a cross-over cable between the two PCs (no hub/ router) to minimise lag.
Original PC Hardware
Old pair of laptops (both running at 640x480 @60hz resolution)
Laptop 1
 2 Cores, @2.26 GHz, Penryn (was master) win7 32-bit
Laptop 2
2 Cores, @1.66 GHz, Merom (was slave) winxp 32-bit
Both had 2GB ram
Using a cross over cable , 100Mbit network (so no jumbo frames)
Performance
Performance was great - with all the recommended settings (network sync =1 and did not need to use the m2 lagfix).  No freezes/pauses, very minimal purple car flickering (occasional after a few races and not enough to spoil the fun)
Newer PC Hardware
A pair of matching/identical HP Elite 8300  'All-in-one' pc's (running at 1920x1080 @60hz)
Were a different story initially but thankfully now are running better (it wasn't as good as the original setup for a while, but after lots of tinkering its finally there running widescreen and at a sharp resolution).
i5-3470. @3.6 GHz running on win7 64bit
Cross over cable, 1gb network (originally with jumbo frames =off)
Performance (initial)
The settings I carried over from the original setup resulted in the dreaded 1-2 pause people mention all over this thread but other than that the cars didn't flicker too much if at all - however the in game freezes eally killed the gameplay.  It seemed to happen randomly.  Sometimes not at all but then a few games in a row.
After turning off network sync(=0), and using the m2lagfix it was stable and removed the freezes but introduced a constant heavy flickering of the other players car (seen from p1 and from p2).  Still more playable but hardly fun.
Performance (tweak network adaptor + lagfix)
After reverting back to my original settings eg. network sync =1 the problem disappeared for a while until eventually the 2 second freezes returned.
I followed a gaming ' lag reducing' guides to turn off a bunch of network adaptor settings, turned on jumbo frames, changed the network cable ... amended the UDP cache size (increased windows buffer to 1mb or something)..and still the 2 second freeze problem persisted but now I do not get any purple car flickering at all.
Using the lagfix again but m2network with network sync on(=1), the freeze now seems to have been reduced to some very minor occasional glitches (like a very brief stutter).  Playing around the m2lagfix settings to see if there is anything can be done with the minor glitches and will update this post in case it helps anyone.
Performance  Update (with hacked lagfix with reduced wait times  on both machines)
Using the recompiled m2lag fix with stall detection reduced to a wait of 64ms has resolved all glitching issues now.
I installed the hacked lagfix on both PC's (with throttle=1). See my other post for link.
It seems to have given the emulator the packets it needs for smooth game play.  Very happy with the results now
Note - I'm running just 2 X players using a cross over network cable.
« Last Edit: May 16, 2026, 07:31:02 pm by dekkit »
buttersoft
  • Last login:October 03, 2026, 07:13:31 pm
  • Is running at 15kHz
« Reply #321 on: January 26, 2025, 05:17:45 am »
Sailorsat, sorry to be pain, but do you have outputs working ok with your 1.1c version?  I can see outputs in mamehooker but they never change state.
I was told, ages ago in another thread, that you needed the scripts from https://github.com/njz3/vJoyIOFeederWithFFB/tree/master/gameassets/nebula_m2_1.1 but that dir is 404 now.
EDIT: ok, new location for those scripts found (thanks @vincerplay) and outputs working again - https://github.com/njz3/BFF_gameassets/tree/dd185d82ea3829033a4d99a65767b3a4739778cc/image_njz3/Emulators/Model2%20v1.1a/scripts
I'd love to figure out how to get STCC leader lamps running next, but that looks like it's going to be much trickier.
EDIT2: @vincerplay modified a version of outputblaster to receive outputs from STCC and Sega Rally Champsionship - https://fastupload.io/1b9ad0d3638c2684
That file is all that is needed to get outputs from m2emu 1.1c. It works with the two games listed, does not work with Daytona anymore, and you would need to test other games.
« Last Edit: January 29, 2025, 05:36:43 pm by buttersoft »
SailorSat
  • Last login:Yesterday at 04:06:45 am
    • For Amusement Only e.V.
« Reply #322 on: January 31, 2025, 12:32:35 am »
I have outputs for all games in m2em woring, but I use my own tool to get them.
Basically the offset to read them is 'EmulatorEXE + 0x174CF0'
The only Exception is Daytona*, which uses 'M2EM_RAMBASE + 0x824' (and requires the lua patch)
Not very that helpfull I guess.
buttersoft
« Reply #323 on: January 31, 2025, 05:55:48 am »
I wouldn't say that, it's all interesting :)
Monkee
  • Last login:June 08, 2025, 10:45:43 am
« Reply #324 on: March 23, 2025, 10:49:25 am »
Just discovered this thread and it sounds great but sadly the download link seems to be down.  :'(
SailorSat
Monkee
« Reply #326 on: March 24, 2025, 05:42:45 pm »
Thanks a lot SailorSat! I cannot wait to try all those amazing arcade racers in multiplayer just like in my childhood!  8)
WolfRagnell
  • Last login:April 11, 2025, 07:51:45 am
« Reply #327 on: April 11, 2025, 07:47:43 am »
Yo currently adding race leader lights to my setup as I learn the ins and outs. the link for the output blaster sega rally & stcc file is down do you know where else I could find it, or if you could upload it for me? tried searching around to no luck,would love the file especially for sega rally cheers!
buttersoft
« Reply #328 on: May 25, 2025, 12:07:12 am »
Hi @WolfRagnell, i've bene moving househad no time to check the forums. I think Vincerplay & MightyMike updated Boomslangz new OutputBlaster to let M2Emu push outputs to MameHooker. Try Boom's channel in the TeknoParrot Discord.
And my god that sounded like a lot of gibberish even to me. If it doesn't make sense or you still get stuck, msg me in a week or two!
themotherbrain
  • Last login:August 18, 2025, 10:26:09 pm
« Reply #329 on: July 20, 2025, 06:15:31 pm »
try https://www.rev-girls.de/m2em/emulator_multicpu_11c.zip
Hi!  :)
I've been setting up my own pair of Daytona racecabs and it has led me here to this thread. I have managed to get everything going just great and I am now just down to the flickering car issue. I have download the 11c multicpu exe and throttle linked in this thread but I do not understand what I am supposed to do with it.
If I am using IP 192.168.1.4 for player 1 and 192.168.1.5 for player 2 could you possibly show me how to add this into my files and what values to use please? I assume I keep these files in the model2link folder. Do I need to have these files running on both pcs? Do I need to download anything else to make this work?
If you wouldn't mind giving a little nudge across the finish line id appreciate it so much! Also I wanted to personally say thanks for working on this emulator!   :notworthy::notworthy: Daytona is one of my absolute favorites and am looking forward to having a bunch more linked up soon! I can't even imagine the effort it takes to figure this stuff out so I want to say I truly appreciate the work you've done!
Many thanks in advance for any help that can be offered!  :cheers:
« Last Edit: July 20, 2025, 07:05:30 pm by themotherbrain »
Endprodukt
  • Last login:September 08, 2026, 05:50:12 am
« Reply #330 on: August 14, 2025, 04:10:09 pm »
Do you have further information if they made it work? I'm fighting with the same problem of no state change in m2emu.
buttersoft
« Reply #331 on: August 15, 2025, 05:04:54 am »
No, i have not set up FFBBlaster yet! And TBH i'm not sure it's meant to cover M2emu, but maybe it is?
I do, however, have outputs working fine with FFBplugin and Outputblaster. All my files for those two elements, and my complete scripts directory from the m2emu folder, are attached. Using these with the 1.1c update by sailorsat gets me working outputs in mamehooker.
MY setup is mostly aimed at STCC as that game is my fav, so you might need to try the different DLL files in there and see. The one with ronames in the title will give individual rom ini's in mamehooker, not just the generic m2emu.ini or whatever it is that covers all roms.
ddraigcymraeg
  • Last login:September 04, 2025, 12:08:09 pm
« Reply #332 on: September 04, 2025, 10:17:20 am »
Hi All,
The original link to M2lagfix download just hangs for me. Can anyone provide another link? Thanks.
Just catching up with all the work done here great job! Looking to get Sega Ski Super G to work for 2 players 4 tops, as well as the other games.
buttersoft
« Reply #333 on: September 05, 2025, 09:13:59 pm »
Is M2lagfix still needed with the 1.1c version of the emulator and framesync enabled? I'm not saying it's not, just asking...
SailorSat
« Reply #334 on: September 06, 2025, 04:50:34 pm »
don't think so.
vertex
  • Last login:October 27, 2025, 09:07:40 am
« Reply #335 on: September 16, 2025, 11:00:48 am »
Using your m2emu files and the Sailorsat version, Mamehooker works, but when I exit, sometimes the lights stay on. I have to close Mamehooker and restart it. This doesn't happen with Mame. Is there a specific reason for this? Or is there a way to fix it?
mamehooker keeps listening to m2emu outputs, but exiting it doesn't delete the information and sometimes the lights stay on.
buttersoft
« Reply #336 on: September 16, 2025, 07:37:20 pm »
Firstly, glad to hear you got it working :)
Secondly, sometimes the lights stay on. I imagine it's because when you exit, the game never sends a message to your arduino or whatever turn off the output. Happens to me with most games. MAME must have a close protocol that sends a 0 or something. And Mamehooker must do so on startup, or just re-initialise the arduino or something.
If you really needed to do something about it, you could write an autohotkey script that fires each time you close a problem game, and closes and re-opens mamehooker... That would be the simplest way i can think of to do it. Or maybe your frontend could do it for you, IDK.
« Last Edit: September 16, 2025, 07:39:51 pm by buttersoft »
dekkit
« Reply #337 on: May 14, 2026, 09:28:10 am »
what my "m2lagfix"-tool does
  • check status of header; the tool won't do anything until status-2 is reached.
  • received frames get buffered, sent to the emulator and (if enabled) a copy is sent to the "control tower"
  • if the emulator does NOT respond within 64ms, the buffered frame will be sent to the emulator again.
  • double-frames sent by the emulator will be split to get rid of "lost" frames.
  • if no frame gets received in 256ms, we have a network stall. (nothing will be done)
each event gets noted in a log file. no response in 64ms = LAG; double frames = DOUBLE; network stall = STALL
Hi Sailorsat - apologies for digging up an old post but I've been going thru the code of the m2lag fix and just want to check if the version on the GitHub is the latest version of your vb code?
I couldn't see anything in the code the handles the double frames condition (or writes something  to the log when it sees a double). Also the value for the stall condition seems different to your post (128ms vs 256ms unless I read it wrong)?
Do you recommend using the Throttle=1 line in the ini if using lagfix on all cars/ emulator instances?
 I'm thinking it might be inadvertently causing some glitching in my setup which has lagfix running on each car
Eg when throttle = 1
 car 1 - emulator doesnt send a packet in 128ms, so lagfix detects a throttle and sends a dummy packet for car 2.
Car 2 - meanwhile lagfix on car 2 also realises it didnt receive a packet in 64ms (the LAG condition), so lagfix also creates it's own dummy packet  and sends it to the car 2 emulator
Car 1 - meanwhile car 1 emulator now sends a new 'real' UDP packet which lagfix then immediately sends to car 2.
If I've read the code correctly, is it possible that the car 2 emulator could receive a burst of 3x UDP packets in quick succession (possibly with conflicting information) when throttle =1 and each car has its own instance of lagfix?
Source code for lagfix link: https://github.com/SailorSat/m2lagfix
Lagfix is a smart workaround, many thanks for sharing the source code
dekkit
« Reply #338 on: May 16, 2026, 08:49:56 am »
Ok I think I've now resolved the issue for my setup and it has removed all intermittent glitches and lags (however small).   In short, the fix for me was to reduce the Stall detection wait time from 128ms down to 64ms in m2lagfix for my setup.
The reason i can think of why i'd need to do this is because is because i migrated my setup to PC with faster CPUs (but who really knows)
I found the original m2lagfix sourcecode within SailorSats respository https://github.com/SailorSat/m2lagfix and recompile it in a version of VB6 professional i found in archive.org.
In the m2lagfix source code - I just replaced line 224 "If GetTickCount - STALL_Tick >= 128 Then" with "If GetTickCount - STALL_Tick >= 64 Then"
I've put my code changes in a fork next the original m2lagfix (named _stall64ms) and dropped a compiled exe (m2lagfix_stall64ms.exe) here in my github:
https://github.com/dekkit/m2lagfix_stall64ms/
Please note on windows 10 triggers an alert in defender (i'm not sure if there is a way around it - but have shared the source code in case someone can compile or wants to port this to a newer language without this issue)
Sharing in case this helps anyone else experiencing or scratching their heads trying to resolve the random glitches in there setup.
DJ_Izumi
  • Last login:Yesterday at 10:56:21 am
« Reply #339 on: September 26, 2026, 10:14:40 pm »
Sorry for the necro question, I came across this thread trying to resolve the 'cars flicking in Daytona with network play' thing and the conclusion seems to be 'there's no real fix' but have any of you tried it on a VRR/FreeSync capable display?
With FrameSkip and FrameSync to 1, I had flickering.  Vsync was off since I was using 180hz FreeSync displays, but I decided to turn it on and voila?  The framerate is a bit funny, it's 58fps, then jumps for a moment every few seconds, but nothing flickers and the audio doesn't seem to desync either.
araujofilipe
  • Last login:October 03, 2026, 03:18:04 pm
« Reply #340 on: September 29, 2026, 12:50:58 pm »
Honestly, this topic will never be closed until the issue is resolved; it’s been nearly 13 years since the first post, and a lot has happened since then, MAME emulating Model 2 decently, and just a few days ago, teknoparrot also running Model 2 games great (I hope teknoparrot sorts this out once and for all). Still, it would be interesting if you posted a video of the result and a mini-tutorial here.
Maillouski
  • Last login:October 03, 2026, 11:33:14 pm
« Reply #341 on: October 03, 2026, 11:27:58 pm »
Agreed. I'm currently fooling around with this custom ARM HW that is able to run Daytona at full 60FPS without a sweat. It runs natively on it. Minimal linux Kernel + Daytona Emulation code with many fixes. It natively boots into Daytona. There's just the Kernel and the emulator. No Operating System. It acts just like a real arcade.
No network issue. No flickering/lagging/synchro issue.
It currently workj with USB steering and I'm going to develop a PCB to interface with the DriveBoard, IO Board PreAmp, and the most difficult, the original CRT (if you don't want to use LVDS or HDMI output). The soundboard will not be needed anymore.
Oh, native 16:9 also. Color is perfect, too.
I want to build this so I can still enjoy my real cabinet without the fear of getting a Soundboard or CPU stack to stop working.
« Last Edit: October 03, 2026, 11:33:14 pm by Maillouski »
DJ_Izumi
« Reply #342 on: Yesterday at 10:55:16 am »
Nah I spoke too soon.  I thought it was resolved but it's more like it made it 'less bad'.  With enough time it occurs and it seems nothing is different at all.  So no fix, please ignore my above post.
In the end the only suitable solution was to  use DaytonaThrottle between Machine 1-4.  There are very short audip drops every 15s or so, but it's tolerable.
