Author Topic: What is the throw like on a U360?  (Read 2462 times)
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« on: May 21, 2013, 10:29:52 pm »
What is the throw like on a U360 with the circular restrictor and the regular shaft length (ie. without the longer shaft add-on)?
I'm gonna be doing a one player panel and I want to be able to play both 8-way and 4-way games properly, and I'm not crazy about having two sticks or having to manually switch a restrictor between 8-way and 4-way.
The U360 sounds like a good option, but I really want a stick with a short throw. If it's got a longish throw, I'm probably better off with an alternative.
Thoughts?
Re: What is the throw like on a U360?
« Reply #1 on: May 21, 2013, 10:33:40 pm »
Go with an octagonal restrictor. I gotta feel those corners...
nitz
« Reply #2 on: May 21, 2013, 11:41:16 pm »
Normally I'd agree with you - but 90% of the games I'm gonna play on this will be 4-way or shmups. I like a circular restrictor for shmups.
nitz
« Reply #3 on: May 25, 2013, 09:47:59 pm »
Anybody? :dunno
shponglefan
« Reply #4 on: May 25, 2013, 10:03:21 pm »
Can't speak for the circular restrictor as I haven't tried it.  But using the 4-way restrictor, it still feels longer than other sticks (like the Leaf-Pro or LS-32).
nitz
« Reply #5 on: May 26, 2013, 06:54:33 pm »
Thanks shponglefan.
I think I'm gonna have to pass. Too bad, sounds like just what I need except for the throw. Maybe I would find it ok, but it's too expensive to buy one just to try it out. I had a 4 way with a longish throw on a panel once, and I found Pac games and DK difficult to play, and Frogger borderline unplayable.
I'll have to decide between having two sticks or a switchable stick I guess.
eds1275
  • Last login:April 16, 2026, 11:43:58 am
  • Rock and Roll!
« Reply #6 on: May 27, 2013, 11:17:49 pm »
I'm finding it really short. Mine is mounted in a 3/4 panel without the long shaft (they're sold out right now) and with a bat top, no restrictor.
shponglefan
« Reply #7 on: May 28, 2013, 12:20:27 am »
I find that somewhat surprising, since w/o a restrictor I found its throw quite long.  How do you have it mounted?  If its undermounted beneath a 3/4" CP, depending on the hole size, the CP itself could be limiting the throw distance...
« Last Edit: May 28, 2013, 12:28:29 am by shponglefan »
eds1275
  • Rock and Roll!
« Reply #8 on: May 28, 2013, 06:54:24 pm »
Maybe it's because I'm used to more "american style" sticks. It is under 3/4, but the stick doesn't touch the sides of the 1 1/8 hole at all.
shponglefan
« Reply #9 on: May 28, 2013, 09:07:51 pm »
Maybe.  I'm just surprised because I've heard people complain about the U360 (sans restrictor) being too long a throw, but never too short.  And in my experience at least comparing to the other joysticks I've tested, without a restrictor it's probably got the longest throw of the bunch.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #10 on: May 29, 2013, 05:50:35 pm »
eds is used to suck-ass Comps is what it is. Even an original Pac stick had a fair amount of throw, and moved a little past the actuation point. Okay for ringing mazes, I guess, and maybe okay for shooters. I think the circular U360 restrictor is decent. I'd like it shorter/smaller, but the mapping isn't fine enough to handle it. Octagonal restictor is good, too.
-Banned-
