Author Topic: What to pick?  (Read 10613 times)
trekking95
  • Last login:March 07, 2013, 06:46:44 pm
What to pick?
« on: February 27, 2012, 02:17:35 pm »
Greetings!  ;D
I have been thinking about it and thought I would treat myself to something, so after having a vote it was decided that I would buy some good arcade parts (its hard to not win in a vote when your the only one voting  ;))
So I have figured out what I want but don't know what type, so here is where you guys come in. Please help me decide what type of these items to get. I would like reasons, pros, cons, your opinions, etc. on why these are the best (or really, really good). So here it goes!  ;D
Control encoder (like an Ipac but whatever is maybe better)
Spinner (push-pull and regular)
Trackball (how well it mounts and how the edge on top looks matters)
8 way trigger stick (happ 8 way trigger stick is the only type I think so in case I am wrong you can say)
Well this is all I can think of right now so I will add to this if I can think of more. What are some good arcade parts in general?  ;D
"Do or do not, there is no try"- Yoda
Unstupid
Re: What to pick?
« Reply #1 on: February 27, 2012, 03:00:24 pm »
By themselves they are all kind of useless!  Are you sticking them on a cab you already own or are you building a new cab around them?
elkameleon
Re: What to pick?
« Reply #2 on: February 27, 2012, 03:06:04 pm »
I have a miniPAC, I think its a pretty great product personally, albeit a bit confusing to setup at first. Having options can do that to ya! :P
Re: What to pick?
« Reply #3 on: February 27, 2012, 03:15:18 pm »
Encoder - IPac (i have the 4 but the 2 is the same only for 2 players)
Spinner - I went with Ultimarc spintrack with flywheel and USB, has worked great.
Trackball - I went with dual Happ 3" with transluscent balls. Mounting is very straightforward and they're USB so they're easy to hookup.
Sticks - I like the U360's, but for 4or 8 way, I might very well have chosen the Magstick+ over them, knowing now how finicky my U360's have been
But I'm no arcade purist either, so there is that.
trekking95
Re: What to pick?
« Reply #4 on: February 27, 2012, 03:47:03 pm »
I meant a trigger stick, like for Tron.
And what about this for the trackball?
http://www.ultimarc.com/trackball.html
Or is the Happ one better?
Also what about this for the spinner?
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=86&products_id=268
Or this for a push pull spinner. Or are they worth it?
http://www.apachecontrols.com/products.html
« Last Edit: February 27, 2012, 03:50:15 pm by trekking95 »
GregD
  • Last login:December 23, 2025, 04:38:08 pm
    • Arcade Nebula
Re: What to pick?
« Reply #5 on: February 27, 2012, 03:53:30 pm »
Sort of a broad question without knowing what you plan on using the parts for.  What type of control panel will you be building?  You mention how the trackball will look on the control panel.  Do you prefer it to be high in the control panel.  if so, Happ makes a high ball trackball.  The Ultimarc trackball is a good trackball.  It is easy to mount in 3/4" material without a plate or having to do any routing.  The downside is that it is expensive.  Both the Ipac/Minipac and the Groovy Game Gear KeyWiz are really good encoders.  Both will be fine for you.  If you are ordering a bunch of parts from Ultimarc then get the Ipac.  If you are ordering a bunch of parts from Groovy then get the KeyWiz.
trekking95
Re: What to pick?
« Reply #6 on: February 27, 2012, 03:53:46 pm »
Kinda like asking for a 4 topping pizza and no dough to put it on.  :laugh2:
No really though is that meant to be serious?
trekking95
Re: What to pick?
« Reply #7 on: February 27, 2012, 04:01:18 pm »
What about a 1/4 inch panel for the ultimarc one? Its not about the high part, just that the edge looks nice (like the ultimarc one).
Does the GGG one need routing and would it look nice? I can do routing if needed. Also the GGG one needs the Opti-Wiz, right?
Anyway besides the Ipac there was not much else from ultimarc that I needed, but from GGG there was the Tron joystick, the trackball for $59 and a spinner so yeah maybe it will all be from them, except the Happ trigger stick.
And are the Keywiz ones good?
Anyway its like a Tron panel with the trigger stick and spinner and the trackball since there will be room for it.
« Last Edit: February 27, 2012, 04:03:52 pm by trekking95 »
GregD
    • Arcade Nebula
Re: What to pick?
« Reply #8 on: February 27, 2012, 04:13:33 pm »
The Ultimarc U-Trac trackball is for mounting in 3/4" wood panels.  A Happ trackball looks really nice above the panel if done correctly.  I have only used the KeyWiz so that is all I can recommend.  If you search on the two products you will find that both are good encoders and each has a following.  You can get a Happ trackball with a USB and PS/2 interface built in.  I got mine on ebay for $10 and had to buy a $15 optiwiz.  No big deal.
Unstupid
Re: What to pick?
« Reply #9 on: February 27, 2012, 04:26:46 pm »
Hahah good analogy...  No it would be easier to make recommendations if we could analyze what you already have... that way we can see your weak point and recommend what would net you the beiggest benefit.
Re: What to pick?
« Reply #10 on: February 27, 2012, 05:00:27 pm »
Really take a look at the cost benefit of the push pull spinner.  Absolutely go with a GGG turbotwist2, you can mount it in a button hole, great all around spinner, but a push pull is a more expensive and different animal with a very restricted game selection.  Once you decide what peripherals you want that will help determine what encoder you need since different ones do different things differently.  Different.
paigeoliver
  • Awesome face!
Re: What to pick?
« Reply #11 on: February 27, 2012, 05:32:09 pm »
Isn't the push pull spinner just for one game? Or did something other than Discs of Tron use one?
Re: What to pick?
« Reply #12 on: February 27, 2012, 05:38:46 pm »
Zwackery and Forgotten Worlds. That's it. I got mine because I'm a DOT diehard but really have started to enjoy Zwackery which I started playing only recently.
trekking95
Re: What to pick?
« Reply #13 on: February 27, 2012, 05:48:58 pm »
Yeah if its only for the 3 games I will go with the GGG one. But should I get an flyweight for it?
So the 3 inch GGG trackball should be okay?
trekking95
Re: What to pick?
« Reply #14 on: February 27, 2012, 05:52:49 pm »
I guess a Tron type panel (Happ trigger stick with non-Happ spinner) with the trackball is what I want.
All I have right now is the 2 player style with 2 bat sticks and 7 buttons each.
So yeah I would be building a new CP for the 3 things. Then just swap 'em for different games! XD
trekking95
Re: What to pick?
« Reply #15 on: February 27, 2012, 06:32:34 pm »
Would a Tron Atari joystick work with a computer? And would it work good as a Tron arcade game joystick?
alfonzotan
  • Last login:August 10, 2025, 04:06:03 pm
    • The Cab With No Name
Re: What to pick?
« Reply #16 on: February 27, 2012, 06:51:02 pm »
First question:  Only with an Atari-to-USB converter like Stelladaptor.
Second question:  No.
trekking95
Re: What to pick?
« Reply #17 on: February 27, 2012, 06:51:53 pm »
Also would the GGG Tron handle fit the Happ 8 way trigger stick?
And would the Tron restrictor make the joystick useless for normal 8 way games?
trekking95
Re: What to pick?
« Reply #18 on: February 27, 2012, 06:52:32 pm »
alfonzotan
Re: What to pick?
« Reply #19 on: February 27, 2012, 06:55:44 pm »
Why is that?
Because it's a glorified Atari joystick.  Not only does it not have the diamond restrictor from an arcade Tron stick, it's a sub-par controller all around for anything other than Atari 2600 games.
alfonzotan
Re: What to pick?
« Reply #20 on: February 27, 2012, 06:58:24 pm »
I think so, but you should email GGG and ask to be sure.
No.  I have an original Tron stick on my CP, and it works fine for other flightstick games like Gorf or Satan's Hollow.
Re: What to pick?
« Reply #21 on: February 27, 2012, 07:28:11 pm »
For select games you might not notice a difference, any 4 way game or 2 way (Satan's Hollow) you will have no issues but if the game requires you to hit solid diagonals then you'll notice.  I wouldn't recommend a round of streetfighter with a triggerstick.
Most flightstick games require an analog control which a TRON stick isn't.
alfonzotan
Re: What to pick?
« Reply #22 on: February 27, 2012, 07:31:15 pm »
Yeah, it depends on the game.  Certainly I wouldn't want a flightstick (or Tron stick) as the primary joystick on a panel.
trekking95
Re: What to pick?
« Reply #23 on: February 27, 2012, 08:39:16 pm »
Well I still have the regular joysticks, this is for Tron and what else works. And is an analog one like the modern flight sticks?
trekking95
Re: What to pick?
« Reply #24 on: February 28, 2012, 05:10:24 pm »
I did, they said yes.  ;D
trekking95
Re: What to pick?
« Reply #25 on: March 02, 2012, 11:32:44 pm »
On the stuff at GGG, what is the mouse button harness you can buy with the spinner?
And would this be a good USB encoder of theirs or is it more for rotary joysticks?
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=76_81&products_id=235
And where it says you can buy the Pro Wiring Set in 10, 20, 30 and 40 switches does that mean it only gives you enough wire for that many switches even though you can have up to 40 on the interface?
trekking95
Re: What to pick?
« Reply #26 on: March 03, 2012, 05:31:05 pm »
Please guys, need to know on the last question!  ;D
BobA
  • What Me Worry?
Re: What to pick?
« Reply #27 on: March 03, 2012, 10:23:54 pm »
Looks like GGG is down right now.
trekking95
Re: What to pick?
« Reply #28 on: March 04, 2012, 12:34:46 am »
Not here! :applaud:
trekking95
Re: What to pick?
« Reply #29 on: March 06, 2012, 12:04:03 am »
 :bump
Please guys, I need to know!!  ;D
wizkid32
  • Last login:August 30, 2013, 07:27:03 pm
  • Portland Trailblazers, FTW!
Re: What to pick?
« Reply #30 on: March 06, 2012, 12:28:08 am »
I am using a KeyWiz Max for my project.  I really hesitate to say it is "better" or "worse" than an IPac.  I like it because it is cheaper than an IPac, has more inputs, and has excellent programming software.
(\__/)
(='.'=) This is Bunny. Copy and paste him into your
(")_(") signature and help him on his quest for world domination.
Best,
Wizkid32
trekking95
Re: What to pick?
« Reply #31 on: March 06, 2012, 02:28:57 am »
Would this be good too? It sounds better to me than the KeyWiz Max as its USB.
wizkid32
Re: What to pick?
« Reply #32 on: March 06, 2012, 11:39:36 pm »
Are you talking about the GPWiz?  If so, be aware that any software you use must support gamepad input.  Also, USB has some keystroke and software limitations that you should be aware of.  For these reasons, I prefer a keyboard encoder.
(\__/)
Best,
Wizkid32
trekking95
Re: What to pick?
« Reply #33 on: March 07, 2012, 04:43:26 pm »
Where did my link go? Must or never posted it. Here it is:
So USB does have problems? Never heard that.
If so which of these is better?
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=76_80&products_id=199
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=76_80&products_id=303
Blanka
Re: What to pick?
« Reply #34 on: March 07, 2012, 05:21:24 pm »
Get a minipac-opti with harness. It will save you tons of frustration!
trekking95
Re: What to pick?
« Reply #35 on: March 08, 2012, 01:00:04 am »
Not really because....
A: they are expensive
B: I am buying all my stuff from GGG and don't want to pay double shipping
C: they are expensive
 :lol   ;)
Other than that, what is the reason you like them? Like if they are really good I might get one.
« Last Edit: March 08, 2012, 01:02:10 am by trekking95 »
trekking95
Re: What to pick?
« Reply #36 on: March 08, 2012, 01:01:26 am »
Please guys, answer this!!!!!!  :(
Re: What to pick?
« Reply #37 on: March 08, 2012, 09:00:26 am »
You know you can contact the retailer directly and he would answer all your questions about his products in detail right?
Mouse button harness allows you to add switches to the spinner's wiring harness.  These switches when depressed will send mouse click signals.
The wiring harness numbers do indeed determine how many switches can be wired to that harness.  My board for instance only uses 22 so I wouldn't need all that extra wire that would come with a 40.
Mini--pac opti allows you to wire your optical devices and your momentary switch devices all through one interface.  They are fantastic little products but if you are getting a GGG spinner with USB or PS2 connection and that's your only optical device it wouldn't be necessary.  If you wanted to use an Atari spinner or trackball that product would get you rolling.
trekking95
Re: What to pick?
« Reply #38 on: March 08, 2012, 04:46:19 pm »
Still waiting to here back from GGG.
So would the mouse button harness really be needed?
Re: What to pick?
« Reply #39 on: March 08, 2012, 04:55:39 pm »
No.  Convenient perhaps, needed no.  I don't like them.  I don't like dedicated trackball buttons either so take my advice with a shaker of salt.
« Last Edit: March 08, 2012, 05:02:05 pm by Le Chuck »
