Author Topic: best 4-way joystick ?  (Read 7143 times)
ntk
  • Last login:June 06, 2011, 12:09:59 pm
« on: November 27, 2010, 05:36:12 pm »
hello
what is the best 4-way joystick for all games  ?
 thanks
severdhed
  • RIP Dinosaur Hippo
Re: best 4-way joystick ?
« Reply #1 on: November 27, 2010, 05:42:29 pm »
i have only used a few different ones:
Wico 4way leaf switch stick
betson space invaders 4 way stick
Sanwa JLW-TM-8 with the restrictor set in 4way mode
and the Sanwa JLW is by far my favorite.  It has a wonderful feel to it, is very quick and responsive and the throw distance just feels perfect.  I have one in my vertical classics cabinet and it is perfect.
Vebbo
    • Overaged Lucky Drivers
« Reply #2 on: November 28, 2010, 04:52:45 am »
+1 Sanwa JLW-TM-8 with the restrictor set in 4way mode
I am not an expert, but i really like the feel of the jlw.
Vebbo
LeedsFan
« Reply #4 on: November 28, 2010, 03:49:52 pm »
I used a JLW on a Turnarcades cab at the Blackpool expo. It felt really nice and played Donkey Kong excellently. The spring was really light too which I think helps quite a bit. I notice that many people tend to want to go for a stronger spring (they always say this about the U360s) but for me it's the complete opposite.
mytymaus007
« Reply #5 on: November 28, 2010, 04:00:09 pm »
Actually the best way to find out is to buy each joystick and then you'll know exactly what works for you. Sell them on here or ebay when your done! :dizzy: :dunno
RandyT
  • Last login:April 16, 2026, 01:13:33 pm
    • GroovyGameGear.com
« Reply #6 on: November 28, 2010, 04:07:48 pm »
Link  ;)
Ginsu Victim
  • Comanche, OK -- USA
« Reply #7 on: November 29, 2010, 08:31:53 am »
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
« Reply #8 on: November 29, 2010, 10:18:44 am »
Link  ;)
Agreed.
Is there some sort of adapter that will allow this joystick to be used in place of a standard joystick? (The longer side seems about right, but the shorter side is too short).
Also, what is the thickness of the base? (For months I've been searching for a joystick with a shallow profile and long stick for a wooden CP that has very little space beneath it).
I picked up two of these: http://www.jammaboards.com/store/classic-arcade-joystick-8-way-to-4-way-switchable-/prod_282.html?ccSID285e73f64c04744fc5f33ff68f529742=1a68d80ce5ab409ff63f8d4b094e0232
But the short stick means relegates their use to metal CPs. :(
Thanks.
Darren Harris
Staten Island, New York.
« Last Edit: November 29, 2010, 10:24:20 am by D_Harris »
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
« Reply #9 on: November 29, 2010, 10:19:43 am »
Wico 4 way
RandyT
« Reply #10 on: November 29, 2010, 12:29:12 pm »
The item you linked to does not function as a true 4-way.  You will likely be disappointed with the ease in which you can hit diagonals with it, even in it's supposed 4-way mode.
As for mounting, just rotate the stick 90 degrees and it will fit between your current mounting holes.
Simple geometry indicates that longer sticks sometimes make for sloppier controls.  If you like the tight reaction time of the old school 4-way controls, you pretty much need to route a pocket into the underside of your panel.  Either that, or flush-mount them, which will take care of your depth concerns as well.
RandyT
D_Harris
« Reply #11 on: November 29, 2010, 01:33:16 pm »
I don't know what you mean by "Flush-mount" them, but the original plan was to route out the underside of the control panel,but I'd need to use a metal plate because it would severely weaken the panel if I want it thin enough so that the joystick is at "classic height".
Thanks.
Darren Harris
RandyT
« Reply #12 on: November 29, 2010, 01:51:39 pm »
Flush-mount means to cut a hole to accommodate the body of the stick and to route the top of the panel to accommodate the thickness of the metal plate.  You can then fill or use an overlay to finish.
Also, You might not think so, but 1/4" of material is fine to hold a stick, as it is a small area surrounded by much thicker material.  It would take a hammer to break that through.  If the loss of 1/4" is enough to ruin your day, then you need to flush-mount.
RandyT
ntk
« Reply #13 on: November 29, 2010, 04:03:29 pm »
thanks to all
Link  ;)
i need to make a big order from you this week ( 600$ ) so i think i will add this to the order
thanks
D_Harris
« Reply #14 on: November 29, 2010, 07:28:44 pm »
Ok. Then that is exactly what I had intended to do. I just hope these joysticks are worth it, because the bottom of the stick has a nut on it. ?!?
Darren Harris
Gray_Area
  • -Banned-
  • -Banned-
« Reply #15 on: December 01, 2010, 08:04:16 pm »
Link  ;)
Is this completely your own design?  How is it different from a Sanwa?  How would this compare to the Wico microswitch sticks?
Regarding shaft length...um, yeah....I recently used a shaft longer....hahahhaah.....than I ever have, with a looser spring than I'm used to....my, my....and, though the height was kind of weird, overall I liked the response.
« Last Edit: December 02, 2010, 12:33:14 am by Gray_Area »
-Banned-
