Author Topic: Best way to fasten 1/2" plywood CP  (Read 4229 times)
Donkbaca
    • Slim built MAME/Xbox cab
« on: October 21, 2010, 01:27:49 pm »
Making my CP box out of 1/2" plywood.  I mitred out the sides, now wondering what the best way to fasten it all together is.
Help!
Garza
  • Last login:July 09, 2015, 10:53:29 am
Re: Best way to fasten 1/2" plywood CP
« Reply #1 on: October 21, 2010, 01:38:15 pm »
I would use wood glue and then small brad nails and gun if you have it and clamp together till dry... thats the best if not small penny nails and wood glue then clamp down wait till dry. Just a little harder to nail in small nails manually.
ragnar
  • Last login:August 16, 2022, 10:40:56 am
« Reply #2 on: October 21, 2010, 02:47:41 pm »
If painting and not staining, I'd also do the finsih nail thing as already stated.
if staining, you could glue it together (make sure things are square and tight while drying) and then add L brackets afterwards.  That's hwo I did it and it worked out great (see build in signature for pics)
MY FIRST BUILD:
Donkbaca
« Reply #3 on: October 21, 2010, 04:51:53 pm »
Gonna stain, I was thinking about the glue and then L-bracket thing.  Thanks!
Donkbaca
« Reply #4 on: October 21, 2010, 04:52:04 pm »
BTW, what kind of glue?
BobtheAddict
  • Last login:October 29, 2010, 12:00:22 am
  • Icy Cold Beverages
« Reply #5 on: October 28, 2010, 11:56:11 pm »
You should be fine with Elmer's glue!
BobTheAddict
push2reject
  • Last login:January 28, 2014, 06:55:40 pm
« Reply #6 on: October 29, 2010, 11:37:00 am »
Elmers wood glue.  Not the white stuff from grade school art class.
If you are really worried about the glue strength use polyurethane construction adhesive in the tube.  A little more flexibility after it cures and easier to apply.  It is not as messy as gorilla glue.
On the other side of the screen, it all looks so easy.  -Kevin Flynn
Donkbaca
« Reply #7 on: October 29, 2010, 12:29:01 pm »
Since I am staining, I used elmers stainable wood glue on the mitred edges, then I used a bunch of L brackets with wood screws to make it square.  Worked great!  My plywood had a little bit of a bow to it and the L brackets and wood screws helped pull everything back to square.  Afterwards I used stainable wood putty fo fill my edges.  Now I am ready for a stain!  Hopefully it takes the stain well, I am worried about the putty taking on more/less stain than the plywood, but I figure using a wood conditioner should make it all even.
Thanks everyone!
