Author Topic: Length of shaft - how short is too short?  (Read 12018 times)
EightBySix
« on: June 22, 2010, 08:31:08 am »
And yes, this IS SFW  :-[
I have a Sanwa ball top joystick, which I need to mount in a shallow space (within a drawer, so the overall height is the issue). I'm thinking I could just cut the shaft a bit to reduce the height, but how far do you think I could go without affecting gameplay? I think I can get a smaller ball top for it, but again - does it affect the experience much?
I'm mounting in wood so I need to consider how much of the shaft will actually be exposed (this is just getting more and more dodgey  :laugh2: )
I realise this is a personal preference, and I'm not really worried about how 'authentic' it needs to feel, but I'd be interested in your opinions and any issues you might know of that I need to consider...
So - how long is your shaft?
Re: Length of shaft - how short is too short?
« Reply #1 on: June 22, 2010, 09:21:23 am »
*cough* no comment...   :afro:
DillonFoulds
« Reply #2 on: June 22, 2010, 10:45:35 am »
Well, I recently played Ms Pac on a cocktail with metal panels, that had joysticks that seriously couldn't have been more than .5cm off the control panel.
Felt like crap, was dragging my fingertips the entire game. Would NOT play again.
DashRendar
« Reply #3 on: June 22, 2010, 10:48:40 am »
Yeah, I've seen some Japanese arcade games that have short shafts like that.
Definitely not my preference.
Trap
  • Last login:November 07, 2015, 12:22:32 pm
« Reply #4 on: June 22, 2010, 12:23:07 pm »
You could put some spacers between the bottom of the cp and the top of the joystick so you could try it out for yourself.  The throw would be shortened by cutting the shaft down but you could do this just to get a general feel of how short you want to go.
_|_  cp
o|o spacer
[=]   joystick base
DashRendar
« Reply #5 on: June 22, 2010, 12:34:09 pm »
That's not a bad idea.
Get this:
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=70&products_id=317
To undermount your joysticks.
Replace those screws with longer ones, and use washers to control the spacing.
That way you can adjust it to the height you like without permanently modifying the joy shaft.
Alpha17X
  • Last login:September 19, 2023, 01:44:51 am
  • wheee!
« Reply #6 on: June 22, 2010, 12:39:50 pm »
I know I'm not really adding anything here but;
... That's what she said.
In all seriousness though.  and possibly rediculous question, why not just get some sanwa shafts? Or do you have spares that you want to put to use?  Does anyone know how far above the... I can't think of how to avoid innuendo in this... how far above the shaft.. hole the shaft extends on a normal sanwa set up?
« Last Edit: June 22, 2010, 12:46:30 pm by Alpha17X »
I miss Retroblast :(
Franco B
« Reply #7 on: June 22, 2010, 01:19:37 pm »
lA JLF is 32.5mm from the plate to the bottom off the ball. IIRC the correct mounting height is to have the mounting plate 4-6mm below the top of the CP so you are looking at a exposed shaft length of 26.5 - 28.5mm.
Standard ball size is 35mm so you are looking at a total height of around 62.5mm.
I think the important question here is how much space have you got in your drawer?
Havok
  • Trade Count: (+17)
« Reply #8 on: June 22, 2010, 03:33:20 pm »
Whatever length you decide on, make sure to polish your shaft regularly...
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #9 on: June 22, 2010, 04:31:34 pm »
i ve  undermounted  a sanwa anda china longshaft stick into a wooden table with 18 mm panel . no problem at all with the gameplay and the appereance .  my ok baby sticks are very short , 2o mm panel to ball distance , but feel nice . astro has 25 mm around . naomi around 30 mm . if u get used to short stickssomeday u will hate the gaming feeling on cabs like sega naomi  .
why not use seimitsu ls 33 instead of the sanwa ?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #10 on: June 22, 2010, 04:49:40 pm »
It's not length but girth that matters. You want something big and solid that feels good in your hand.
NO MORE!!
Bender
« Reply #11 on: June 22, 2010, 07:30:30 pm »
Ahh my shaft is very short.... but VERY effective :lol
I have a JLF Bottom-mounted (without the metal plate) under a 19mm CP on a mini cab I'm building and the shaft length is 16mm above the CP I also used a 30mm balltop instead of a standard 35mm one so the total hight above the CP is 44.5mm
(the balltop has a flat-spot on the bottom where it's treaded so it is only actually 28.5mm tall)
It plays great to me, very similar to my real DK cab
Do i sense a coffee table project?
« Last Edit: June 22, 2010, 07:44:33 pm by Bender »
Kevin Mullins
    • Me on Myspace
« Reply #12 on: June 22, 2010, 09:03:36 pm »
Kinda sounds like a recommendation to test drive other shafts.  ???
Seriously, if it's to be mounted in a limited space like a drawer and you have to shorten anything at all, shorten it the least amount necessary. The options for spacing the base from underneath may be a good option to look into, if enough space is given to do so.
And be sure the hole the shaft protrudes through isn't too small or too big, that'll effect gameplay as well.  ;D
EightBySix
« Reply #13 on: June 23, 2010, 10:43:05 am »
Hey, some good suggestions.
_|_  cp
o|o spacer
[=]   joystick base
Adding spacers wont work for me though, as I want to reduce the overall height of the entire joystick.
e.g. I need to reduce the total of A + B
That looks perfect! Wish I had asked here before shelling out on the Sanwa. Would anyone be kind enough to post the "A&B" measurements of a Seimitsu ls 33 for me? I've looked around and can only find mounting plate measurements. (for sale - 2 Sanwa joysticks - never used  :P )
There is no drawer at the moment - I'll be making it to fit whatever joystick I end up with / modify. So this is the key dimension for my project really.
Aww, you remembered. Yes, you do. I've been building a proper workbench in my shed before I get stuck in, and then of course, there have been lots of overdue projects for the house that needed to be done...
So all I need to do now is measure up the shaft, so I can get wood. Erm, I'll stop now.
Trap
« Reply #14 on: June 23, 2010, 02:25:27 pm »
I was suggesting the spacers so that you could get a feel (on a test panel or something) of just  how short you could cut the shafts down, not as a final solution.
http://www.akihabarashop.jp/catalogs/Seimitsu2007.pdf
EightBySix
« Reply #15 on: June 23, 2010, 02:44:19 pm »
Ahhh, I see. Then I could see if the height saved would make for a playable setup before I buy. Thanks for the link too. You know, I saw that pic when trying to figure out the height, but didnt look past the part numbers!  :banghead:
Wow - that IS a small joystick, it must be les than 1/2 the height of mine
Kevin Mullins
    • Me on Myspace
« Reply #16 on: June 23, 2010, 04:43:29 pm »
Is there a US distributor of any sorts for something like the Seimitsu ls 33 ?
Anyone know if they are as durable as the LS-32 ?
I've looked at these before, but the only source (until now) that I had found wanted multiple orders of like 30. So this is looking like a good option once again for a "limited space" project I have as well.
Trap
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #18 on: June 23, 2010, 05:02:28 pm »
lol *ahem*   yes..
EightBySix
« Reply #19 on: June 24, 2010, 09:45:34 am »
I've redone my sums, and I think I was getting a bit excited. The difference is only 8.5mm between them.
Handle to platePlate To Base
Sanwa JLF32.036.0
Seimitsu LS 3325.535.0
Another option would be to have the joystick horizontal,
e.g. from this:
 O
XXX
to this:
X
X--O
X
Which would make the height 65mm, including the handle. I've seen some cocktail cabs like this, but are they comfy? I'm only supporting classic games, and dont anticipate gaming marathons on it...
Alpha17X
  • wheee!
« Reply #20 on: June 24, 2010, 02:34:14 pm »
Sanwa JLF32.036.0
e.g. from this:
 O
XXX
to this:
X
X--O
X
Personally, I would suggest trying to get them set up in what their factory positions/settings would be. Then adjust to your comfort level. Just play some games and if you find that you're cupping holding the ball with your hand all around, and your dragging your knucles across the cpanel, you may then want to raise the shaft if you can.
Setting things up to a specific standard makes perfect sense in the world of mass production, but if it's for your personal use, you may as well customize it to your level.
Personally I hate my hands dragging across the panel when I play so while I have the baseball bat shaped tops, they're set a bit higher than normal.
