Author Topic: First Post, Introduction, and a few burning questions  (Read 2991 times)
XCVG
  • Last login:August 13, 2010, 11:25:54 pm
« on: March 14, 2010, 05:23:15 pm »
Well, first of all, I'm XCVG. Some of you (though I doubt it) may know me from BenHeck or ModRetro. I'm portabilizing an N64, which you may think is insane, but a lot of portibilizers think that building something as big as an arcade cab is insane. The point is, I'm joining here because I plan on doing some arcade-related projects in the future, and because I have a few burning questions.
Okay, there's one really big burning question I have on my mind. I know the answer is going to be big and complicated, as I have already read up on the subject quite a bit, with no real results. What is the big difference between American, Japanese, and to a lesser degree European parts? Also, are American parts bad, or are Japanese parts just cooler?
Second, where are the rules? Is that blurb I had to read when I signed up all the rules, or is there a thread somewhere?
Ginsu Victim
  • Comanche, OK -- USA
mwong168
  • Last login:May 28, 2019, 11:38:54 am
Re: First Post, Introduction, and a few burning questions
« Reply #2 on: March 15, 2010, 10:33:04 am »
First off welcome to the board and I will try my best to give you my insight on this whole japanese and US parts.  You could say American parts are bad but they weren't always bad.  It depends on which "American" parts you buy such as HAPP or Industrias Lorenzo aka iL.  iL use to make all the parts for HAPP before they got bought out by Suzo a few years back and now all HAPP parts are made in China where as iL I believe is made in Spain.  Chances are if you grew up in the 90's playing SF2 in the arcades you played on sticks made by iL.  Now how can you tell the difference between a HAPP or iL competition?  First off deal with reputable people or vendors such as Lizardlicks that clearly sells each and doesn't try to pawn a HAPP off as a iL since iL is a bit more expensive but not by much and certainly not worth tarnishing your business reputation to make an extra dollar or two.  I am going to borrow a few images from Lizardlicks so hopefully Chad won't mind and he's great to deal with by the way.
Here is a picture of a HAPP competition stick
Here is a picture of a iL competition stick
Now the reason I chose to use pictures of a blue competition stick is because HAPP's all come with black washers regardless of the color you choose whereas iL's all come color matched to the bat top.  Now another difference is the color of the actuator, HAPP's are black and iL's are white.  Then there is sometimes a difference with the microswitches, iL's come with usually beige cherry micro switches and have a code that say something like "D33X" or something like that and the HAPP's sometimes come with white cherry's depending where you order them from.  They both are the exact same in dimension and size so you can easily interchange from one to the other.  Between the HAPP and iL my preference lies with iL and there is a difference when you see them side by side in action.  If I had to choose between a HAPP competition and a Sanwa JLF stick I would choose the HAPP  :P  You can see by all my projects I am very biased towards american style parts despite them being put down as being outdated, big, bulky and not as responsive as japanese parts.  Here are some pictures of the Sanwa JLF stick that is commonly found on the Madcatz Street Fighter IV Tournament Edition and the new "S" series stick that just came out last week in anticipation for the release of Super Street Fighter IV.
Then there is the optional octagonal gate which you can switch out, the one in the picture above if a square gate.
Now if you are having a hard time adjusting to your Sanwa JLF and miss the familiar feeling of a HAPP/iL competition this might be your instant fix.  I've tried both gates and the square does take a bit of practice getting use to but you will also have to adjust to the shorter throws on a japanese stick as well.  Also if you don't like the ball top there is a bat top add on to further pimp out your stick as well and I have tried this as well but came to the conclusion that I prefer my iL competition in the end.  I will tell you one thing, this japanese stick is very noisy and gets annoying when in use and I believe there is a mod to reduce the "clickity" clicking noises.
Now buttons everyone will say that Sanwas are more responsive and I do believe this to a degree but I don't think it is night and day difference in the timing.  One thing you will appreciate about japanese buttons like Sanwa is how effortless it is to push and get a signal.  Some people like this but personally I don't because I found myself doubting myself and I was wrong almost 100% of the time if I pressed the button properly where as with HAPP/iL buttons I get that springy kickback once I release the button and that is how I know it registered my press properly.  In the end I think it all boils down to preference and if I was to build another custom stick I would use an iL competition stick with Seimitsu buttons feel nicer then the Sanwas in my opinion.  Another really nice thing is that it comes in clear so you can integrate your artwork so it doesn't interfere much like this:
One thing I will tell you about japanese parts is that they are designed to be top mounted in thin metal control panels.  There are ways you could work around this such as for the JLF you replace the flat mounting plate with "S" like this so you can mount it from underneath in wood.
Another good resource on arcade parts if you haven't found it already is www.slagcoin.com
good luck!
Showcase Project [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=93701.0
Bartop Project [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=98410.0
Custom Wireless 360/PC HAPP Fight Sticks [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=100809.0
Visual Pinball Cabinet [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=102628.0
Epyx
  • "You're an oddity"
« Reply #3 on: March 15, 2010, 04:22:01 pm »
You can also quite easily mount Sanwa JLW/JLF sticks from the top using FrancoB's excellent tutorial.  I did this recently myself and the results were fantastic.
I was raised on Comps and other North American sticks but have grown to love these Sanwa's during testing...they truly are high quality sticks and come across as more quality when viewed side by side.
With that said it all comes down to personal choice!  :cheers:
Last Project
Epyx Tutorials:
Tutorials
XCVG
« Reply #4 on: March 15, 2010, 11:11:33 pm »
Well, being of a newer generation I've never played much arcade. By the time I was into gaming arcade was pretty much dead, there wasn't much around and everything was a ripoff. So no big nostalgia factor here. I do, however, really like the Neo-Geo, of course I can't afford an AES. Maybe I'll build a CMVS eventually, hmmm... *mumble mumble*
Anyway, does anyone know where I can get arcade parts in Canada? If anyone has had firsthand experience buying from a place outside Canada, that would be nice too.
Epyx
« Reply #5 on: March 15, 2010, 11:24:08 pm »
Happ arcade parts from www.starburstcoin.com
There are a few others if you look at the vendor links on the main page.
Last Project
Epyx Tutorials:
Tutorials
mwong168
« Reply #6 on: March 16, 2010, 12:23:47 am »
I would recommend ordering from www.lizardlick.com  I ordered my parts and got it 6 days later to Toronto without getting hit with any extra duties, taxes, brokerage or handling fees.  My other friend has ordered from them as well and shares the same positive experience.
I've also ordered from groovygamegear.com as well but they don't carry iL competition sticks only HAPP.  Excellent experience and products such as the KeyWiz, GPWiz or OptiWiz.
Epyx
« Reply #7 on: March 16, 2010, 02:52:41 pm »
And if you want even faster...www.ultimarc.com will usually get an order to you by breakfast the next day...ok...maybe not that fast..but usually two days.
However, as MWong168 indicated...www.lizardlick.com and of course www.groovygamegear.com are all great to Canada...and with today's exchange rate...why limit yourself to just the small selection within Canada?
I have ordered from all of the above and can easily recommend them all.
Last Project
Epyx Tutorials:
Tutorials
mwong168
« Reply #8 on: March 16, 2010, 04:08:21 pm »
I try my best to support the local business such as arcadepower.ca, but when you sell a Sanwa LF-TP-8YT Ball Handle Joystick for $39.99cdn or a iL 8-Way Eurojoystick for $19.99cdn where as places like Lizardlicks is selling it for $24.95usd and $9.95 respectively it makes the choice very obvious where to buy from even if there is shipping and exchange rates are involved.  I emailed them first but they refused to price match or even budge so I just said good luck and have a nice day.
XCVG
« Reply #9 on: March 16, 2010, 07:01:09 pm »
Okay, thanks. I heard Lizard Lick is good and they ship USPS, not UPS (I have had horrible experiences with UPS). What about The Playdium Store? It's in Canada and has decent prices. They seem to serve arcade vendors more than hobbyists though.
Thanks for all the help, and if anyone is interested I have a worklog of my N64p offsite here.
Ginsu Victim
« Reply #10 on: March 17, 2010, 12:27:50 pm »
Wow, those prices are way higher than most sites I've seen.
Epyx
« Reply #11 on: March 17, 2010, 01:53:47 pm »
Agreed with the current exchange rate...however when the dollar was .60 to a us 1.00...their prices were still as displayed and not that bad (obviously they haven't updated). I wouldn't buy from them now and haven't for a while...but If I were local in Ontario, Canada...it is still an option to save on shipping.
Last Project
Epyx Tutorials:
Tutorials
