Author Topic: Tron Mini/Cabaret CPO Artwork  (Read 14062 times)
shrunkenmaster
« on: March 03, 2010, 02:37:51 am »
Does anyone have this? Only link I can find is at Tronsector but it's dead.
Encryptor
  • Trade Count: (+34)
Re: Tron Mini/Cabaret CPO Artwork
« Reply #1 on: March 03, 2010, 05:30:39 am »
You can check with kjoel0123 because he has a complete mini Tron but to me it looks the cpo is the same as the full size just smaller. The controls are layed out the exact same way on both from what I can tell looking at pictures of each. I'd be curious to know as well.
Encryptor
Encryptor
« Reply #2 on: March 03, 2010, 06:00:04 am »
I just figured out the difference. The full size has separate pieces for the cpo and the front and the mini is all in one.
shrunkenmaster
« Reply #3 on: March 03, 2010, 12:50:20 pm »
Thanks Encryptor, yes, it's the front piece I need! I have the main top part.
Encryptor
« Reply #4 on: March 03, 2010, 05:13:22 pm »
Can you put the 2 pieces together if you get it? I have it in ai, jpg and pdf formats. Which would be better for you? Here is the jpg file. If you can put it together or know someone that can put it together into one file with the correct dimensions I'd greatly appreciate a copy of it.
Encryptor.
shrunkenmaster
« Reply #5 on: March 04, 2010, 03:07:37 am »
AI format ideal, I can put it together no problem. Let me know what dimensions and format you want and I'll sort it.
Encryptor
« Reply #6 on: March 04, 2010, 05:19:55 am »
Sweet!  :cheers:
I'll take some measurements and see if there is any difference in spacing for the controls between the mini and full size control panel. The AI file is in the zip. Thanks.
Encryptor
« Last Edit: March 04, 2010, 05:22:33 am by Encryptor »
SavannahLion
« Reply #7 on: March 05, 2010, 02:09:08 am »
Wow, I didn't know there was a mini version of this cab. I just knew about the tabletop and the full sized cab. You guys are talking about the cabaret like the one from habosarcade, right?
shrunkenmaster
« Reply #8 on: March 05, 2010, 02:54:18 am »
Yes Savannah - that's the site I'm using for reference too.
SavannahLion
« Reply #9 on: March 06, 2010, 11:19:07 am »
Oh sorry, I didn't realize that. Long days at the office will do that.
shrunkenmaster
« Reply #10 on: March 06, 2010, 02:13:10 pm »
[/quote]
I hear that!
Encryptor
« Reply #11 on: March 07, 2010, 03:22:19 pm »
This is the picture with the dimension I mentioned in my pm to you.
Encryptor
*Edit* After reading a little more habo got his from Arcadeshop.com. It's $35 from there.
« Last Edit: March 07, 2010, 04:05:31 pm by Encryptor »
Triangel7D
  • Last login:September 10, 2017, 01:06:09 pm
« Reply #12 on: March 07, 2010, 08:21:56 pm »
I'm working on a Tron-inspired multicade cabinet, and I'm using Lower_Control_Tron as the basis of the CPO (I like how a trackball can sit in the circle in the middle). I actually retraced all of the file with circles and 45- and 90-degree lines and made all the blends even. It's more "geometrically sound" now. I did the same thing with the spinner (in the original PSD the center is off). Hope some of you can find these AI files useful.
shrunkenmaster
« Reply #13 on: March 08, 2010, 03:10:40 am »
Encryptor
Ha ha, just saw this at arcadeshop too! I think I'll get one of these too. I'm just concerned about getting the two 'panels' spaced properly to account for the curved edge. Once I have one I can use it to make a more accurate repro for others to use. Many thanks for your dimensions though, as I thought the CPO was 19.5" wide, not 18"...
Encryptor
« Reply #14 on: March 08, 2010, 05:39:21 am »
That would be great if you get one from arcadeshop and then create the repro artwork from that one.
If you look back at the other thread where you asked for dimensions it's 18" on there.
I received an email from habo and he said the one he got from arcadeshop was very very nice. I'll be looking forward to seeing what you can do with this one. Thanks for your effort in making a repro for everyone to be able to use.
Encryptor
shrunkenmaster
« Reply #15 on: March 08, 2010, 06:02:43 am »
I have no idea where I got the 19.5" from! And it'll be nice to give something back to the community. I've placed the CPO order so hopefully I can get cracking real soon.
Encryptor
« Reply #16 on: March 08, 2010, 02:38:58 pm »
That's great. On behalf of myself and anyone who might need this in the future I say thank you!  :cheers:
shrunkenmaster
« Reply #17 on: March 29, 2010, 11:32:30 am »
I've traced a new CPO from my repro overlay - here's the AI file. The lower part was from another file, I just did the top part. The control holes seem quite off, but I've left them as they are on the repro. Also, the colours I've used are not the same as the flourescent ones on the repro - I'm not sure what colours these are. Background black CMYK is 30/30/30/100 but this can easily be changed.
If anyone needs anything re-jigging or whatever, I'm happy to do so!
shrunkenmaster
« Reply #18 on: March 29, 2010, 03:22:07 pm »
Just vectored the Tron Mini Bezel artwork from a web-sourced TIFF, attached. Precise cutout for monitor to be decided though, but all the 'hard stuff' is done.
Encryptor
« Reply #19 on: March 29, 2010, 05:53:01 pm »
Excellent! You da man! :cheers:  Thank you very much!
Encryptor
shrunkenmaster
« Reply #20 on: March 30, 2010, 02:58:16 am »
I've converted the fonts to outlines (so you won't need the font files) in this updated CPO file.
Let me know if all is good!
Ian
elfmarshland
  • Last login:January 01, 2022, 08:05:41 pm
