Author Topic: Thanks for Emulaxian!!!  (Read 1306 times)
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« on: July 24, 2003, 12:46:21 pm »
Just wanted to thank Peter for Emulaxian and all the work he does on it.  It was originally easy to set up and get up and running, and the more I customize it the more I fall in love with how much you can really do with it.  So far I really haven't come up with something it can't do for me.  I really needed something I could filter with and set up diferent lists based on screen orientation and controller type filters and this front end works like a charm, very easy to use...
Thanks!!!!!
:) Rotate or die! :)
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Re:Thanks for Emulaxian!!!
« Reply #1 on: July 24, 2003, 02:33:58 pm »
Thanks  8)
Easy to use! I agree...take a few minutes to read the quick install guide and off you go...but I am the maker...most people will probably disagree overwhelmed with all the stuff you can adjust  ;D
peter
REBIRTH
  • What is that?
« Reply #2 on: July 24, 2003, 05:21:55 pm »
Thanks  8)
peter
That is the beauty of it though.  To get it up and running takes seconds, you do not need to mess with much of the setting s at all.  But if you want to customize it, you can all you want, it's almost endless.
« Last Edit: July 24, 2003, 05:22:26 pm by REBIRTH »
