Author Topic: How to tell if I fried my IPAC  (Read 1343 times)
DennisInMN
  • Last login:June 17, 2023, 02:50:53 pm
  • gunga, gunga ga lunga
« on: January 21, 2010, 02:57:19 pm »
I just updated my MAME PC and my control panel isn't registering on my PC.  I even hooked up a keyboard to the pass-through and got nothing from that either.  I took my CP off my cab and hooked it up to my main PC and I got the same results.  A few weeks ago I had hooked my CP up to my main PC to play some games and check out some front ends, so I know my CP was working.  I opened up notepad and pressed buttons/joystick and I get nothing now.  How can I tell if my IPAC is fried?
Not sure if it is related, but it might be.  I just hooked up my trackball, 5 yrs after I created my cab.  I have a Happ trackball and an old serial Optipac.  I found that I needed to run 5V power from my PC to the Optipac, so I did that.  Like I said, not sure if this has anything to do with my IPAC issue but since my CP was working a few weeks ago and I haven't done anything to it since then I wonder if hooking up the trackball did something to it.
Thanks.
Deadly
  • Last login:April 28, 2021, 02:55:25 am
Re: How to tell if I fried my IPAC
« Reply #1 on: January 21, 2010, 03:26:28 pm »
The only thing left to try is to use the WINIPAC utilty and try flashing it. If that fails she's toast.
DennisInMN
« Reply #2 on: January 21, 2010, 04:06:24 pm »
I'll try that later tonight.  Also, I was thinking I should try another ps/2 cable to connect it to the PC.  I'll have to dig around and see if I can find one.
« Reply #3 on: January 21, 2010, 06:29:35 pm »
Does the ipac's LED light up when you have it plugged in and turn it on?  It has a self-test LED that does certain things so you can determine what's wrong.
Read more here (under the "Troubleshooting using the I-PAC Self-Test LED section"):
http://www.ultimarc.com/ipac2.html
Hope this helped.
DeLuSioNaL29
