Author Topic: Help making default marquee images when there is none? MALA  (Read 1601 times)
SlayerAlex
  • Last login:September 17, 2011, 09:19:27 pm
« on: January 15, 2010, 08:35:01 am »
OOPS I MEANT TO POST THIS IN THE MALA THREAD :(
hate to make a new thread but i couldnt find the answer anwyere and got frustrated. i think imissed soemthing up with z axis or something i dunno.
I'll probly just start all over and do this first. So how do you set it to have a cetern control panel image or marquee image be on all the games that have no marquee or cp? any help would be apreceated thanks
« Last Edit: January 15, 2010, 10:09:50 am by SlayerAlex »
Comtek
  • Last login:June 02, 2017, 07:17:42 am
Re: Help making default marquee images when there is none? MALA
« Reply #1 on: January 15, 2010, 11:19:40 am »
using Mala layout editor u can set a default image just double click the image box and it gives you an options screen in there is where you set the default image or u can edit the mll file manually
« Last Edit: January 15, 2010, 11:31:26 am by Comtek »
