Author Topic: 2 simple questions.  (Read 1460 times)
Brutal E
  • Last login:July 07, 2010, 09:11:23 pm
2 simple questions.
« on: January 11, 2010, 06:16:42 pm »
1. The connector on my Happ 3 inch track ball is a molex connector correct? (Square stock connector.)
2. What should I use to adhere my trackball mounting bracket to the under side of the control panel? (Suzo Happ has 3M tape When I took the panel apart it looks like the last user had used some kind of contact cement and it was on there pretty good.) Looking for something I can get locally and cheap.
Thank you.
