Author Topic: K7000 Pincushion Adjustment  (Read 3584 times)
MK3FAN
« on: January 06, 2010, 08:36:39 pm »
Another question guys. Is there any way to adjust the pincushion on a K7000? I know there are dedicated pots on the Wei ya's, but I am clueless on how to do it on a K7000. Any help would be appreciated.
Kevin Mullins
    • Me on Myspace
Re: K7000 Pincushion Adjustment
« Reply #1 on: January 06, 2010, 08:42:49 pm »
Adjust the yoke.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: January 07, 2010, 10:06:23 am »
pin cushion correction compensates for the inherent time lag in scaning the corners of the crt.  usually 25" and up - exceptions are the flat crts
displaying a crosshatch pattern will allow scan imperfections to be seen.
such as faults in vertical and horizontal linearity/ pin cushion, convergence ( dots are best for fine tuning convergence)
yoke alignment ( rotation and neck position)
adjust pot(s) for straight VERTICAL lines
loss of correction will give an hourglass pic  )        (
overcorrection will bow (       )
castlesteve
  • Last login:September 12, 2014, 09:10:32 am
  • uh, yea
« Reply #3 on: January 11, 2010, 02:30:44 am »
The 27" k7000 chassis has an additional pincushion correction board.  Similar but different than the add on board seen on 27" U2000/U5000 chassis.   I've never seen the schematic for it though for a k7000 and I've personally only seen ONE in person.  Good luck.  Try a different yoke.  That usually does it for me.
