Author Topic: power source  (Read 2926 times)
Huskerfan
  • Last login:October 05, 2021, 11:40:38 pm
power source
« on: January 05, 2010, 07:14:26 pm »
If I buy a touchscreen without a power source can I just substitute a power brick I have laying around?  As long as they both say "12VDC"?  Or is it more complicated?
Kevin Mullins
    • Me on Myspace
Re: power source
« Reply #1 on: January 05, 2010, 08:18:48 pm »
Sure, as long as the amperage rating is at or above what the monitor needs.
Oh, and of course as long as it has the right plug end on it.
Huskerfan
Re: power source
« Reply #2 on: January 06, 2010, 01:00:10 pm »
Thanks for the advice.  That's what I did.  I picked up a 19" elo for $143 shipped without the cord.
Huskerfan
Re: power source
« Reply #3 on: January 06, 2010, 01:51:09 pm »
http://www.elotouch.com/Products/LCDs/1939L/
This is the monitor I bought.  Can you tell what amps this pulls from elo's web site?
I have a brick that says "OUTPUT: 12.0vdc 750mA".  It was taken from a old router I had laying around.
Looks like the plug is the same but I don't know about the amps.  I found that this monitor requires 45 watts???
EDIT:  I found out that the plug I need requires 4.16 amps.  Hmmm, I guess I need to figure out how mA converts to amps?
EDIT again:  500 mA = 0.5 amps  Also, you'd take 45 watts/ 12 volts = 3.9 amps
Guess I answered my own questions but I hope this can help someone else with the same situation.
« Last Edit: January 06, 2010, 02:13:48 pm by Huskerfan »
BobA
  • What Me Worry?
Re: power source
« Reply #4 on: January 08, 2010, 10:48:15 pm »
From ELO site
Monitor only: 38 W
It is higher at 45 W for the inefficiency of the power brick is included.
That means at 12 V you need a bit over 3 amps at 38W    Probably 4 amps would be safe.
That is 4000 mA  so you are right on.
Huskerfan
Re: power source
« Reply #5 on: January 09, 2010, 07:57:32 pm »
From ELO site
Monitor only: 38 W
I went ahead and bought the actual power supply for the monitor.  The one's I had laying around were around 3.1 amps and I didn't think it would work.
