Author Topic: Black Knight pin blowing fuses  (Read 18606 times)
SirPeale
  • Green Mountain Man
« on: January 05, 2010, 01:26:39 pm »
Have a client with a Black Knight pin that's blowing fuses.
He claims that it's blowing fuse F3, which I'm guessing works certain solenoids (I haven't looked it up yet).  The other fuse he says:
The other fuse that keeps blowing is a fuse that is mounted on to the back of where all of the score displays are mounted. When I ran the diagnostic on the machine I think it is referring to the jet bumper malfunctioning up top.
Having not seen the machine in person (and it being a two hour trip, one way) I want to be as prepared as possible.  I'm betting at least one bad coil, but the other one has me scratching my head.
Re: Black Knight pin blowing fuses
« Reply #1 on: January 05, 2010, 01:46:54 pm »
F3 is lamps.
I don't know of any fuse on the backside of the display door.  My BK does have the sys6 style power supply but I don't remember a fuse back there on any other Sys7 games I have worked on.
SirPeale
« Reply #2 on: January 05, 2010, 01:54:57 pm »
F3 is lamps.
That's what I thought, but he's saying all the lamps are lighting up.  Only the flippers and pop bumpers are failing.
The machine powers up and all of the lights display. However the flippers and bumpers do not respond.
I opened up the top part of the machine with all of the boards. When I set up a new game the flippers worked for a moment then the F3 fuse blew. The other fuse that keeps blowing is a fuse that is mounted on to the back of where all of the score displays are mounted. When I ran the diagnostic on the machine I think it is referring to the jet bumper malfunctioning up top.
and this is from a tech that can not get to the machine any more:
I am fairly certain one of the coils has internally melted and shorted and just needs to be replaced. The other blown fuse in the lighting circuit I don't know the cause. You can measure the coil resistance of the new coils and match it to the old ones.
If they are within a few ohms they are probably fine. They have to be un-soldered from the power circuit first, then measure the resistance. The shorted one (or more) should stick out like a sore thumb.
The other thing to check is the output of the transformer. They have a tendency to go bad after a few years (heat damage) and output higher voltages which in turn will melt the coils (and other parts). Replacements are available, just hard to find. I have replaced two machines with newer solid state power supplies instead of the transformers for the 50vDC outputs (coils) and just left the lighting and logic circuits hooked to the transformer.
Okay...rereading this the other fuse that is blowing must be related to these solenoids.  No idea why the lighting fuse would be blowing if the lights are working.
« Reply #3 on: January 05, 2010, 02:13:59 pm »
Lamps and GI are separate circuits.  Don't trust his ability to know the difference.
Those transformers are just like any other 1980 game.  A block of steel you could throw in the ocean and pull back out a year later and it still works.  It's the power supply board that develops problems, often starting with those standalone BRs.
Black Knight doesn't have 50v flippers.
This is a tough game to drive 4 hours to fix and support.  That boardset is going to be super flakey if that 40 pin hasn't been swapped.
SirPeale
« Reply #4 on: January 06, 2010, 01:21:01 pm »
Yeah, there is that.  :)
Knowing little about this particular pin, can you expand on that?
I hate distance repairs; they're either something so simple that all my research I did beforehand doesn't apply and it's fixed in short order, or you go around and around and then find out you don't have the right parts on hand, necessitating a return trip.  I'm really trying to avoid that.  If only these machines all used the same solenoid, I'd just grab one and chance it.
« Reply #5 on: January 06, 2010, 01:33:10 pm »
Expand on which part?  If you mean the 40 pin connector, go over to Clay's guide and read up on it.  I can't explain it better than he does.  It's pretty much a 100% mandatory rehab task for reliability on any Sys3-7 game.  If you drive all the way out there, tell him you'll support his game but don't replace the 40pin interboard connector, you're going to be chasing phantom problems in that game indefinitely.
Now, given that another tech has looked at it, maybe it's already done, but 4 hours is a lot of driving if you don't know.
SirPeale
« Reply #6 on: January 06, 2010, 01:36:39 pm »
Yes, I was talking about the 40 pin connector.  I'll look it up.  You said Clay - are those docs on Marvin's site?
« Reply #7 on: January 06, 2010, 01:41:29 pm »
Yep, that's the author's name.
http://www.pinrepair.com/sys37/index1.htm#interconnect
I didn't think I could get to that site from here but today I can.  There's the url.   ;D
SirPeale
« Reply #8 on: January 06, 2010, 01:53:38 pm »
Yup, I found it.  Looks like an easy swap, assuming the solder is still good.  Waiting to hear back from the guy.
Heck, it might be easier to take the whole machine back to the shop and do the work there.
« Reply #9 on: January 06, 2010, 01:57:27 pm »
Easy swap, time consuming if you are charging by the hour and cannot point to a specific need to replace it.  And it's a specialized part, definitely not one you have on hand otherwise.  GPE is a good source.
You often also run into battery corrosion on the left side of that connector.  That's where the nvram/settings/audit circuit is and that can mess up the solder as you mentioned.
« Reply #10 on: January 06, 2010, 03:43:36 pm »
If it were a local machine that would be reasonable to try.  Odds are what is going to happen here is it works fairly well now because it's all seized in place.  He is going to have to pull the driver board to make those repairs.  That is going to have a very unpredictable effect on that interconnect.  It might be fine, it might loosen crap up that goes flaky 20 boots from now, or it might just drop a contact or two while he pulls on it.  The problem here is that he's 2 hours away from the thing.
That stupid thing was designed to be modular but they put the system bus on a connector with a rated life of like 5 cycles - and it is 30 years old.   :dizzy:
SirPeale
« Reply #11 on: January 12, 2010, 02:24:48 pm »
We're still trying to come up with some data via emails.  One thing I'd like to know: how many different types of solenoids are on this beast?
And I'm still trying to get out of him which other fuse blew.
shardian
« Reply #12 on: January 12, 2010, 02:59:24 pm »
Go look at it and check for the basic stuff. Give it 1-2 hours max if you don't find the issue, then tell the guy you'll have to take it back with you and it will cost him. Charge for 2 hours labor regardless if it is a 5 minute fix - you've already invested that much + more in pointless research without solid info. Make him aware of all this from the get-go. That is really the only solution that keeps your tenders out of the vice.
SirPeale
« Reply #13 on: January 12, 2010, 04:18:42 pm »
Offer him $150 for it as-is and tell him you're too busy to look at it otherwise.
Seriously.
Black Knight is a maintenance nightmare.  He'll break it 48 hours after you have it repaired.
Not gonna happen; apparently he's the original owner and it has great value to him.
SirPeale
« Reply #14 on: January 12, 2010, 06:07:52 pm »
That's why I'm trying to reduce that headache.
I finally got some snaps of the fuses in question.
« Reply #15 on: January 13, 2010, 10:02:01 am »
This is a pic from my resto thread - there appears to be something white in that same spot but if there is a fuse there I have never had reason to look at it.  I'll look tonight and see where that white/yellow is going but it looks like it's going to flashers.
shardian
« Reply #16 on: January 13, 2010, 10:31:27 am »
That fuse is in-line with what I assume are the flashers. Part of it terminates at a single socket next to the circuit board. Extra note: seeing electrical tape in the wiring in that area makes me cringe a bit. ;D
That fuse 2nd from left is toast - is that the F3 fuse?
« Reply #17 on: January 13, 2010, 10:52:35 am »
That's F2 - the solenoid fuse.
WOW this a nice schematic... :D
SirPeale
« Reply #18 on: January 13, 2010, 11:23:27 am »
That IS a nice schematic.  Thanks, Chad.  According to that, it is indeed the F2 fuse that's blowing, not the F3.
He's got some spare parts as well - several solenoids.  I just found this out.  Photo attached.
shardian
« Reply #19 on: January 13, 2010, 11:55:35 am »
You're welcome good sir. I've seen that black, bubbled but intact bad fuse twice on pins, once on a vid.
It appears the fix will be easy now....tell him you charge half-price if you can just guide him over the phone.  ;D
« Reply #20 on: January 13, 2010, 12:12:06 pm »
And tell him to stop drinking weird colored melted butter.   :dizzy:
SirPeale
« Reply #21 on: February 07, 2010, 09:21:20 pm »
Finally drove up and got to check this beast out.
I'd brought a "lamp fuse" with me to help me troubleshoot.  As soon as I plugged it in it started glowing, indicating a short.  None of the solenoids showed any sign of a problem.
Disconnected J11, light went off.  So I started unsoldering wires from the solenoids one by one from that connector until the light went off.  Then started tacking them on again.  But suddenly, the light went back on!  I was thinking I had two bad solenoids (pretty rare) but thought better of it and checked out the board.
Battery damage!  Not a lot, but enough to screw with the board.  I brought them both back with me, and I'll replace the 40 pin and repair the damage.
Anyone in the 413 have a pin of this vintage I can test repaired boards in?  I don't want to drive three hours to find out I missed something.
« Reply #22 on: February 08, 2010, 08:49:43 am »
Three hours in which direction?  If it's this way you can drop them in my BK.
SirPeale
« Reply #23 on: February 08, 2010, 09:20:21 am »
Northern VT, up near Sugarbush.
« Reply #24 on: February 08, 2010, 09:39:10 am »
Eh crap.  Well let me know if you're in this area any time soon for other reasons before you give them back, I guess.
SirPeale
« Reply #25 on: February 13, 2010, 12:48:24 pm »
It's green!
GPE
  • Last login:November 15, 2011, 07:25:25 pm
« Reply #26 on: February 24, 2010, 03:41:12 pm »
It's green!
Common occurance when it gets wet at one time or another... board washed or even high humidity.
Ed
SirPeale
« Reply #27 on: February 27, 2010, 05:51:33 am »
It's green!
Ed
Humidity would not surprise me, it was stored in a basement for a number of years.
lilshawn
  • Last login:December 04, 2025, 08:10:20 pm
« Reply #28 on: February 27, 2010, 01:07:33 pm »
that would definitely do it! you probably have a hundred ohms of resistance there boy!
SirPeale
« Reply #29 on: February 27, 2010, 05:26:17 pm »
Yes, but this relay isn't what's blowing the solenoid fuses.  It's either a flipper replay (separate circuit) or lights.
lilshawn
« Reply #30 on: February 27, 2010, 10:49:41 pm »
your "green" relay is the main power for the solenoids. if the contacts are corroded, there will be a great increase of resistance... the load on the fuse will be huge... enough to blow it.
flippers have it's own separate system... your not having issues with the flippers so there is nothing there to worry about.
GI has it's own fuse on a block (just below)...unless it's blowing there is no problems there either.
check VR1 next to f2 (should read very low ohms) if it's toast it will read a short (designed that way).....The varistor is a one-time surge suppressor. When a power surge or voltage spike is sensed, the varistor's resistance rapidly decreases, creating an instant short path for the over-voltage. Because the varistor creates a short circuit, the varistor and the line fuse are damaged in the process.
also you might as well check c13 too as well since it's the filter cap for the coils
so unless you have a fried coil someplace (something that reads less than 2.5 ohms is suspect)
assuming the above are all fine...the only thing left is the relay
SirPeale
« Reply #31 on: February 28, 2010, 02:21:45 pm »
I must have misread - I thought there were two relays, one for lights and one for flippers.  I admit I only breezed thru what I was reading and haven't returned back to it.
SirPeale
« Reply #32 on: March 03, 2010, 12:45:03 pm »
Where can I find the driver transistors for the driver board?  Mouser doesn't carry them, nor GPE.  8977 or 8052 or 8039, which?
lilshawn
« Reply #33 on: March 03, 2010, 07:39:44 pm »
Give www.nteinc.com a try, they have a cross reference there on the site. It's a common parts replacement that is stocked at most local shops...you may be able to find a sustitute locally.
 I would do it for you, but their site doesn't work very well with my mobile phone
SirPeale
« Reply #34 on: March 03, 2010, 08:40:19 pm »
I was trying to stick with OEM.  NTE stuff is usually pretty highly priced.  But I did find it - NTE261.  Even states "Williams" right in their database.
lilshawn
« Reply #35 on: March 03, 2010, 10:31:54 pm »
sometimes you just gotta go with what you can find... on the first version main power board, the original style SDS201/SDS202 transistors at Q1/Q3 are no longer available in any flavor or form from anybody anywhere. These two transistors must be replaced with the newer MJE15030/MJE15031 transistors. BUT the MJE transistors had a different pinout than the original SDS transistors, so they must be installed differently on the board!! this was changed on later boards to fit the standard BCE pinout
SDS trans: E B C
MJE trans: B C E
B=base
C=collector
E=emitter
the fix looks stupid, but you gotta do what you gotta do...
ALSO
If any of these coils has a bad diode, this can almost instantly kill its associated driver transistor! The coil diode prevents a coil's collapsing voltage from "backwashing" to the driver board, damaging the driver transistor.
Since you spent the time to test/replace the bad driver board transistors, (you did didn't you??) it only makes sense to also check for bad coil diodes. Since these 1N4004 diodes are mounted right to the coils under the playfield, vibration can crack or damage them.
« Last Edit: March 03, 2010, 10:38:32 pm by lilshawn »
SirPeale
« Reply #36 on: March 03, 2010, 10:43:01 pm »
I tested them on location, but was in a hurry to get out of there that day so have lost track of which ones are bad.  Shouldn't be hard to track down.
The coil diodes are fine, and yes, I know enough to test them.  :)
SirPeale
« Reply #37 on: March 10, 2010, 11:27:33 am »
Gah...help me out here.  I'm trying to ID the drivers on the driver board.
8977 is easy...crosses to an NTE266, which also crosses to a TIP120.
What about a 9410?
SirPeale
« Reply #38 on: March 10, 2010, 01:02:24 pm »
According to the schematic, they're ALL TIP120 transistors.
lilshawn
« Reply #39 on: March 11, 2010, 02:55:34 pm »
 :dizzy:
yeah, them guys can never make up their minds....
The most commonly used transistor on the driver board is the TIP120 (along with its 2N4401 pre-driver transistor). It is responsible for driving all the solenoids. Also used is the TIP42, for the Lamp matrix column drives. The 2N6122 (TIP41) transistor is used for the Lamp matrix row drives, and the small 2N6427 transistor is used for overcurrent protection in the lamp matrix. There are some 2N5060 Silicon Controlled Rectifiers (SCRs) used too.
