Author Topic: Zinc cannot open controller plugin  (Read 3793 times)
dezblack
  • Last login:June 04, 2012, 01:37:01 am
« on: January 04, 2010, 03:30:23 pm »
I have followed both of these threads to a T, starting from scratch each time.
http://forum.arcadecontrols.com/index.php?topic=73330.0
http://forum.arcadecontrols.com/index.php?topic=85315.0
 I have also tried launching from zincfe by itself, but It always starts, then closes on its own. The error is always the same,  error: cannot open controller plugin.
I am using an IPAC. Is there anyhting special I need to do? Anyone have any ideas how to fix this?
Space Fractal
  • Space Fractal
    • Space Fractal
Re: Zinc cannot open controller plugin
« Reply #1 on: January 05, 2010, 02:05:46 am »
You propenty use a wrong controller plugin or such and hence it wont work.
You can also try my own config application:
http://forum.arcadecontrols.com/index.php?topic=86588.0
Can you start the game from here after fellowed the readme, then you can also run the wrapper (same exe) from a frontend too.
dezblack
« Reply #2 on: January 05, 2010, 05:27:41 pm »
Actually, I have tried both 1.5 and 1.6 flavors of the Winterblast Plugin..
Shun
  • Last login:August 28, 2024, 07:08:49 pm
« Reply #3 on: June 01, 2010, 05:11:37 pm »
Hi dezblack,
I had this same issue and it was driving me crazy. I looked at the logs and it wasn't able to initiate my joysticks even though I didn't have one. It turns out that the problem was because player 2's controls had been set to use a joystick. I changed this to keyboard inputs and it is working perfectly now  ;D.
Just thought I would share if anybody else has this issue.
Complete: Pac-Man Cabaret scratch build:
Project thread
Work in progress:
Two Phase Bartop With Flush Mounted Dreamcast. 75% Complete
