Author Topic: Anybody used Led Blinky with Mamewah?  (Read 1249 times)
reko19
  • Last login:July 16, 2025, 10:06:10 am
« on: January 04, 2010, 01:45:41 pm »
Or any other app for that matter? Looking to turn off buttons that are not in use for any particular Mame game or for an emulator. Thanks.
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: Anybody used Led Blinky with Mamewah?
« Reply #1 on: January 05, 2010, 08:41:14 am »
LEDBlinky does work with mamewah - although there's no native integration. If you only wish to light (and/or speak) the buttons in use with mame games then the setup is relatively simple - just start blinky before you start the FE and it will detect the mame start/stop events. For other emulators or more advanced features you'll need to use mamawah's pre/post command configuration to send blinky the correct parameters. I believe others have done this. Do you have a specific question?
Robots will kill you.
Arcade Addiction
reko19
« Reply #2 on: January 05, 2010, 09:03:49 am »
Thank you for the reply. No specific question for now, trying to figure out if this would work with my setup. Primary objective is to make it less confusing for kids. Even though I have CPV2 running which displays buttons in use, kids keep pushing all available buttons.  CPV2 is actually pretty neat when using with MAME it also displays button functions (i.e. jump, punch, etc). For emulators it is just a static image that shows where A, B, etc buttons are mapped. What I am planning to do is get an LED controller and run it with LED Blinky to illuminate ONLY buttons that are in use. This would be game specific for MAME, emulator specific for emulators. Just trying to see if this is doable before I spend $. Thanks.
