Author Topic: Ms Pacman Cabinet Resto Pics  (Read 3973 times)
VR-92
  • Last login:January 02, 2010, 04:07:33 pm
« on: December 30, 2009, 06:05:34 pm »
Hello all. Help me save a classic.
I saved this guy from a garbage pile. My buddy was throwing it away. Doesn't work and I get no nothing. I think it is a power supply problem. When it was working (years ago) it took forever to warm up then you could finally play.
Can I get a new power supply for this thing?  I did attempt to use the search engine also. I found a few things but nothing on power supplies.
I am a mega noob so any advice would be helpful.  :applaud:
Pics:
« Last Edit: December 30, 2009, 06:15:18 pm by VR-92 »
VR-92
Re: Ms Pacman Cabinet Resto Pics
« Reply #1 on: December 30, 2009, 06:07:15 pm »
This green wire was crammed into the main power switch terminals. Is is a ground?
VR-92
« Reply #2 on: December 30, 2009, 06:09:50 pm »
Wire heading off to nowhere...another ground?
Connector?
IG-88
« Reply #3 on: December 30, 2009, 07:49:19 pm »
Have you checked your fuses? I circled one that looks kinda rough. Although even if that is bad I doubt thats the reason it took a long time to "warm up"
-HarumaN
SuperGunGuru
  • Last login:December 10, 2021, 08:14:53 pm
  • Filling up that basement
« Reply #4 on: December 30, 2009, 08:04:55 pm »
Yes that's a ground. See the little metal tab held in by that screw? A ground should attach to that so that's probably where that wire was. I wouldn't worry about the power supply until you know where the problem lies. This game's pcb takes AC input from one of those 2 transformers in the cabinet and converts it to DC on the board. Transformers are usually pretty robust so it's very possible the problem isn't there. I would start by checking the fuses (with a multimeter and not just eyeballing them) as already suggested. Can you coin the game up get any game sound from it? There are also common issues with Pacman and Ms Pacman machines such as bad fuse holders and bad edge connectors that can cause issues. By the way that's a very nice score! The game looks pretty clean and you can't beat free.  :cheers:
VR-92
« Reply #5 on: December 30, 2009, 08:24:11 pm »
Yeah tomorrow I'll head down to the electronics store and pic up new ones for all of them. Thanks!
VR-92
« Reply #6 on: December 30, 2009, 08:29:28 pm »
Thanks.  :cheers: Free is a good price!
Ok I'll connect the ground up. Time to fire up the soldering iron.
Right now no sound no nothing when I'm plugging it in and hitting the switch. I've got the door safety switch pulled out so it's no that.
VR-92
« Reply #7 on: January 02, 2010, 03:47:46 pm »
Success!  :applaud:
Replaced a few fuses and nothing.....then I whooped out the multimeter and found the power cable was not carrying a current. Replaced and bam power and game play!  :applaud: :applaud: :applaud:
Now to figure out whats up with the vid?  ???
IG-88
« Reply #8 on: January 02, 2010, 04:03:54 pm »
Nice  :cheers:   No help on the video part but you're getting closer!
-HarumaN
polaris
  • veni vidi congai
« Reply #9 on: January 02, 2010, 06:04:20 pm »
you should ask a mod to move this to the restoration section, itll get more attention from the right people there.  :cheers:
