Author Topic: Wiring opinions  (Read 2301 times)
TheGameAh
  • Last login:June 09, 2004, 10:52:01 am
  • You are not FreakZilla.
    • Arcade Cab
Wiring opinions
« on: July 22, 2003, 01:24:43 pm »
Hey guys.  I'm getting ready to wire up my control panel and I had a few options I was exploring that I wanted to get your opinions on.
1.  I could just hardware the whole thing.  Not really an option.  I was to be able to either swap out or make multiple CPs with 1 IPac.
2.  I could use cat 5 wire (or any cable) and DB 25 connections.  Not a bad idea really.  Although I have slightly more inputs than 25, so I'd need two sets.  I could always use one DB 25 for the player one side, and the second for player two.  Not too bad.
3.  I could buy either 2 DB 25 cables, or 1 DB 37 cable, and cut it, and use those preexisting color coded wires.
Which option sounds the best, or am I missing a better one?
Is cat 5 easy to wire up?  If it is, can I use quick disconnects with cat 5 wire?
When using DB plugs, do I need any special tools to make the wire stick in the plug?
That about sums it up  :)  Thanks.
Chris
    • Chris's MAME Cabinet
Re:Wiring opinions
« Reply #1 on: July 22, 2003, 01:40:17 pm »
You could try three 12-position Molex connectors for 36 connections... this is what a real arcade machine would use, and it's easier to wire than a DB25....
If you're going to use DB25, get a used DB25 extension cable from a computer surplus store and cut it in half, giving you prewired, color-coded male and female DB25 connectors.
--Chris
« Last Edit: July 22, 2003, 01:40:37 pm by Chris »
--Chris
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
Re:Wiring opinions
« Reply #2 on: July 22, 2003, 03:37:14 pm »
Depending how many buttons etc. each player is supposed to have, I'd reccommend 15-pin molex's.  That gives you joystick (4), 6 buttons (10), coinslot (11), player start (12), ground (13), and two extra (15).
Or you could put coin slots on a different connector, and then 12 would be enough.  Maybe 12-pin molex for each player set, and a separate molex to handle coin slots, pause key, tab key, etc.?
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
TheGameAh
    • Arcade Cab
Re:Wiring opinions
« Reply #3 on: July 22, 2003, 03:40:37 pm »
Where could I get 15 pin molex, and what is it generally used for?  I didn't stumbled across that in my searches.
Chris
Re:Wiring opinions
« Reply #4 on: July 22, 2003, 03:42:27 pm »
--Chris
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Wiring opinions
« Reply #5 on: July 23, 2003, 03:52:32 am »
Any good electronics store should have them.  Radio Shack is a maybe.
Robin
Knowledge is Power
Aceldamor
Re:Wiring opinions
« Reply #6 on: July 23, 2003, 11:09:13 am »
I don't know where you live, but Fry's Electronics here in AZ has an entire section of different Molex Connectors. I buy my stuff there when it's cheaper than it is to pay for the part and shipping online at Mouser.com
Fuzzy Wuzzy was a woman!
Hoagie_one
  • Um....whats a cabinet
Re:Wiring opinions
« Reply #7 on: July 23, 2003, 11:30:21 am »
how hard is it to reuse an old molex connector that is already wired up?  Can you easily remove wires and rewire them?
grafixmonkey
Re:Wiring opinions
« Reply #8 on: July 23, 2003, 11:35:02 am »
Yes, they make Molex pin removal tools - but I can usually get them out with just a small flathead screwdriver.
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
Re:Wiring opinions
« Reply #9 on: July 23, 2003, 12:58:06 pm »
Are those higher density Molex connectors as much of a ---smurfette--- to disconnect as 4-pin PC power connectors are? I damn near bloody myself every time I have to swap/replace/install a CD or hard drive (which is all the time for some reason). That's one reason why I stayed away from Molex when I did my CP. Maybe it's me.
Chris
Re:Wiring opinions
« Reply #10 on: July 23, 2003, 01:03:55 pm »
They're meant to be snug, but you can shave down the bumps that lock them into each other you like them more loose...
--Chris
grafixmonkey
Re:Wiring opinions
« Reply #11 on: July 25, 2003, 12:18:34 pm »
I'll have to go home and play with my new 15-pin molex plugs and see how it goes.
