Author Topic: pentranic 32 cga chassis problem  (Read 1591 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: December 22, 2009, 05:23:14 pm »
I'm not sure about this so here goes. i have a 32" pentranic monitor chassis in my Mame machine and i checked the voltage going to the PCB and it says 12v on my dvm but i get no pic on screen. I'm not great with monitors but i thought they had to have more volts am i wrong or what does this sound like to be a problem?
grantspain
Re: pentranic 32 cga chassis problem
« Reply #1 on: December 22, 2009, 05:37:56 pm »
do you get static on the crt?
do you get a flash from the screen when you switch off?
can you see an orange glow from the neck of the crt?
does the voltage to the monitor power read correctly?(either 110 or 220-depending on where you reside)
GMZombie
« Reply #2 on: December 22, 2009, 05:52:54 pm »
no static no orange glow no flash when on turned off or other way. my voltage after the iso trans is 12v that is going to the monitor power plug
grantspain
« Reply #3 on: December 22, 2009, 05:57:47 pm »
multimeter set to ac volts with a range of 200?
GMZombie
« Reply #4 on: December 22, 2009, 06:04:50 pm »
whoops yea its 120volts but still no pic..fuses good.
grantspain
« Reply #5 on: December 22, 2009, 06:09:18 pm »
looks like a monitor fault then,renowned for problems these large pentranics-are you getting any sort of noise like a ticking or a fizz when you turn on the cab
GMZombie
« Reply #6 on: December 22, 2009, 06:14:44 pm »
nothing not a sound flicker fizz or anything
grantspain
« Reply #7 on: December 22, 2009, 06:17:07 pm »
unless you are pretty clued up with monitor repairs i think this may be beyond you,you could try contacting rick nieman at nieman displays to see if he can repair it or supply a replacement chassis-are you in the U.S or U.K?
GMZombie
« Reply #8 on: December 22, 2009, 06:18:14 pm »
US yea monitors arent my slice of pie thats for sure. i can do cap kits and thats aobut it.
grantspain
« Reply #9 on: December 22, 2009, 06:26:16 pm »
I would suggest contacting Rick then,imo it could be the HOT but I have heard terrible stories about these 33" pentranics flashing over and basically destroying vast sections of the electronics on the chassis
could be cheaper to buy a cheap replacement chassis from china
