Author Topic: Closing ePSXe  (Read 5905 times)
alastair
  • Last login:June 20, 2010, 09:18:39 am
Closing ePSXe
« on: December 20, 2009, 09:16:40 pm »
Anyone know if you're able to close it with anything other than the escape key? Or if you can change the key?
« Last Edit: December 21, 2009, 12:39:19 am by alastair »
jmr15
  • Last login:February 16, 2011, 08:17:24 pm
Re: Closing ePSXe
« Reply #1 on: December 21, 2009, 02:16:18 am »
in mala?
yes is possible
you can choose any key for close epxse
only choose the key  :applaud:
in mala
options- go to epxse options-use hot keys - add -source: (herechoose the key)type:close-ok
alastair
Re: Closing ePSXe
« Reply #2 on: December 22, 2009, 08:03:56 pm »
"Use hotkeys" doesn't work with ePSXe, the only way to properly close ePSXe is with ESC - and I'm wondering if you can change that key.
jmr15
Re: Closing ePSXe
« Reply #3 on: December 23, 2009, 01:17:20 am »
ok i understand
not think it is possible
would have to change the source code and hack the emu
but you should use closemul.exe to close epsxe whit another key
but im not sure i dont know how to use closemul
