Author Topic: Green Beret on Mame: the game runs with 60/30 FPS.  (Read 2200 times)
mark_navigator
  • Last login:August 03, 2010, 04:20:11 pm
« on: December 15, 2009, 12:58:36 pm »
Hi,
I'm not able to get Green Beret playing with normal speed: the game runs with 200% of FPS (60/30FPS) and I'm not able to decrease it up to 100% FPS (30/30 FPS).
Can someone help me to solve this annoying trouble?
Thank you.
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
Re: Green Beret on Mame: the game runs with 60/30 FPS.
« Reply #1 on: December 16, 2009, 10:49:23 am »
Check your mame ini for a setting called throtle
Best of the Best of the Best. Sir!
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
« Reply #2 on: December 16, 2009, 11:15:29 am »
You are using an older version of MAME which has the FPS display instead of speed % .. placing your MAME at 0.113 or earlier.
Anyway, your correction is quite simple,  you only need shut off your (-syncrefresh).  The game is syncing the gameplay to the refresh rate of the monitor (presumably, 60 fps) - so your gameplay speed is scaled up to 200% to match.
mark_navigator
« Reply #3 on: December 17, 2009, 05:54:47 pm »
Thank you so much!
The problem was really the sync option activated!!
