Author Topic: supa dupa ghetto looking keyboard encoder  (Read 1333 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: July 22, 2003, 02:08:49 am »
so tell me .. Am I wrong or does this thing look like a ps2 cable with a terminal bloack tossed on the end???
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3234677237&category=13718
disscuss that!! ;)
not my auction
Generic Eric
Re:supa dupa ghetto looking keyboard encoder
« Reply #1 on: July 22, 2003, 02:12:59 am »
eww
paigeoliver
  • Awesome face!
« Reply #2 on: July 22, 2003, 02:29:50 am »
This auction has better pictures.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=13718&item=3218393320#ebayphotohosting
Looks to be a keyboard chipset on a breadboard? PCB. Only has 12 inputs on it. So it probably isn't very usefull, unless you are doing a one player control panel. (joystick4, +buttons6, + coin 1, + start1 = 12 inputs).
Hoagie_one
  • Um....whats a cabinet
« Reply #3 on: July 22, 2003, 09:27:30 am »
and if your gonna do a 1 player Cp, why not just hack a pad
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #4 on: July 22, 2003, 09:55:07 am »
I actually bought one of those monsters, because it was cheap--I like cheap!   ;D
Yes, basically, it is a ps2 cable with a terminal block on the end. The encoder chip is burried under the terminal block in a chunk of epoxy. And yes it idoes just have 12 inputs (wasn't aware of that when I bought it).  >:(
I'm using it in conjunction with a pad hack in a 2 player CP.
It works...but bang for the dollar...look elsewhere! You've been warned!
All Your Base Are Belong To Us!
Lilwolf
« Reply #5 on: July 22, 2003, 02:06:13 pm »
Looks like it would be PERFECT for a 1 player cab..   Especially a bartop where space really matters.
But for 15 bucks for 12 inputs... You cant go wrong....... unless... you need... well.... 13inputs.... they you went way wrong.....
to bad nobody has come out with something similar for usb.
Hoagie_one
« Reply #6 on: July 22, 2003, 02:38:17 pm »
i happen to be building a 1 player mini cab right now and was gonna hack a sidewinder.  I bid on one and ill let everyone know how i like it.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #7 on: July 22, 2003, 06:11:59 pm »
Whoa! Frankenstein is prettier!
Not for everyone but not a bad solution for some. Hmmm, someday I'd like to do a classic vertical cab. This would probably work actually.
If you build a frankenpanel, chances are I don't care for you as a person.
