Author Topic: WG-U2000 Not displaying blue  (Read 2301 times)
DJMOJO
  • Last login:November 17, 2011, 12:59:28 pm
« on: December 13, 2009, 10:35:20 pm »
I read this http://forum.arcadecontrols.com/index.php?topic=85640.msg898346#msg898346
and basically had the same issue only it was blue that was not displaying instead of red.
long story short i re-flowed all the solder on the neck board and plug it all back in but nothing seemed to change. then i took it out one more time to further inspection when i came to find this...
Looks like one of the pins from the tube has broken off in the neck board... is this thing fubar? i was gonna do a cap kit but now im kind of discouraged...
let me just say im new to monitor repair, im an amature at best to electronics repair but i do have lots of experience soldering modchips on ps2s and such so i know my way around a soldering iron i supose. anyway. should i just replace this POS or is there some way to repair it? again im new to monitors and from what i hear new WG monitors arent so hot so what would be a good replacement for the 25" U2000 (its in a KI cabinet)
here is a video of my walkaround when i first picked up the arcade
here is the photobucket album link
http://smg.photobucket.com/albums/v638/DJMOJO/Killer%20Insticnt%20Arcade/
DJMOJO
Re: WG-U2000 Not displaying blue
« Reply #1 on: December 13, 2009, 10:37:17 pm »
sorry mods could you move this to the Monitor/Video Forum i thought i was posting under that forum.
BobA
  • What Me Worry?
« Reply #2 on: December 14, 2009, 01:11:08 pm »
If you could get a bit of solder on the bit of pin showing in the socket you might be able to get it to make contact again but I doubt that you can remove the pin and solder it back where it belongs without wrecking you tube.
DJMOJO
« Reply #3 on: December 14, 2009, 09:35:47 pm »
OK... so i got that piece out of there, i just ended up desoldering that one plastic piece and pulling it out the back... (maybe it was over kill to desolder the thing but i didnt want to mess up the plastic piece). here are a few pics...
The PCB
after i removed it.
Heres the culprit is it supposed to be all like... burned its a bunch of colors like blue and orange and yellow
DJMOJO
« Reply #4 on: December 14, 2009, 09:36:34 pm »
ugh... i think i broke that pin out... unless its supposed to look like that...
the top one is the one that is missing... that bottom one just stayed with that plastic piece... : ( i think its actually fubar now...
Kevin Mullins
    • Me on Myspace
« Reply #5 on: December 14, 2009, 10:43:14 pm »
Um.... yup..... not looking so pretty now.
You took all the right steps, it's just the way those things go some times.
Since you have an otherwise working chassis you could always shoot for a tube swap if you can find a compatible sized tube. (right overall size, right neck pinout, etc)
DJMOJO
« Reply #6 on: December 15, 2009, 08:25:21 am »
yeah thats what i figured... should i start looking at 25 inch tvs or where could i find a compatible tube?
Oni2382
  • Last login:December 07, 2015, 11:00:36 pm
« Reply #7 on: December 15, 2009, 02:57:27 pm »
If you end up replacing the entire monitor I would be willing to buy the chassis from you. My U2000 Chassis took a dive and I have been unable to fix it...Let me know...
XBL:Mykungfooizgood
PSN: Mykungfooizgud
