Author Topic: I need some help setting up my touchscreen...  (Read 5282 times)
TxGlenn
  • Last login:June 03, 2015, 03:34:13 pm
« on: December 12, 2009, 12:06:24 pm »
I bought one of the ELO 1545L 15" touchscreens off eBay from my message here: http://forum.arcadecontrols.com/index.php?topic=98189.0
I am now trying to determine why I can't get a display.  I plugged in the power cord, VGA cable, and USB cable and installed the drivers on my PC using a different monitor.  When I turn on the power to the touchscreen, I just get a blue message stating "No Video Input. Please check cable".  I'm wondering if I got a defective unit, or if I'm doing something wrong.  I am using the same VGA cable that I normally use and it;s working fine. Thanks
TxGlenn
Re: I need some help setting up my touchscreen...
« Reply #1 on: December 12, 2009, 01:13:13 pm »
Also, per the specs I had this set at 1024 x 768 resolution at 60 Hz.
BobA
  • What Me Worry?
« Reply #2 on: December 12, 2009, 03:19:13 pm »
afaik most touchscreen operate fine as a normal monitor if their touchscreen usb or serial is not plugged in.
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
« Reply #3 on: December 12, 2009, 04:02:43 pm »
I agree with Boba
The LCD monitor part should work regardless of the touchscreen funtionality.
Try doing a complete shutdown of the computer, restart and see if the computer bios finds LCD screen. If so, then let XP boot up, then plug in the usb cable for the touchscreen. Then make sure you calibrate the touchscreen. Very easy to do.
Fordman
Kevin Mullins
    • Me on Myspace
« Reply #4 on: December 12, 2009, 06:45:18 pm »
Make sure the power to the monitor is ON before you reboot the PC.
Kevin Mullins
    • Me on Myspace
« Reply #5 on: December 12, 2009, 06:47:03 pm »
Yes, all touchscreens are just an added overlay.... underneath is nothing more than a plain monitor. They will work without the touchscreen (usb or serial) plugged in.
abispac
  • Last login:February 09, 2026, 12:30:42 am
« Reply #6 on: December 12, 2009, 08:13:29 pm »
Try this, restart the pc, then pres f8 and select start in vga mode, hope that helps.
TxGlenn
« Reply #7 on: December 13, 2009, 01:05:07 pm »
Thanks for the tips guys.  I tried them all with no luck.  The monitor is being recognized by the PC...the alignment program runs and then tells me "no touchscreen detected" when I unplug the USB cable.  So I'm convinced I just got one with a defective vga plug.  Hopefully the ebay guy will make sending a replacement easy.
Fordman
  • MADE in the USA
« Reply #8 on: December 13, 2009, 10:26:55 pm »
I'm a bit confused, does the LCD screen itself work or not?  ???
In one statement you say it doesnt and in your last statement you say it does. Having the LCD working is only half the battle. So, does the LCD part of the screen work or not? Do you see windows boot up? If the LCD works, then we will work on the touchscreen overlay part of it. The VGA is only for the LCD part of it. The USB is for the touchscreen overlay.
Fordman
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #9 on: December 14, 2009, 04:07:33 am »
Sounds like the touchscreen works but not the display itself.
TxGlenn
« Reply #10 on: December 14, 2009, 01:54:19 pm »
Fordman
Yea that was confusing.  The LCD does not work...I get nothing but the "no video input" message.  I can therefore not check the touchscreen aspect using that monitor.  Hooking my regular monitor up with the USB still attached to the touchsreen allows me to see that the PC sees the touchscreen (i.e. I can run the alignment program where it asks to touch the targets on the 4 corners of the screen and when I unplug the USB it says "no touchscreen detected".)
jmike
« Reply #11 on: December 15, 2009, 07:05:46 am »
Not sure if I understand your probably but I bought the same touchscreen and found out I had downloaded the wrong drivers. Screen works fine now.
