Author Topic: Arctic thunder FUSE question...?  (Read 1958 times)
reversesrever
  • Last login:September 30, 2011, 11:44:46 pm
« on: December 10, 2009, 02:04:28 pm »
Hi, Quick, do I need a 5amp or 3amp 250 volt replacement?   Also, this is the 2nd time in a week the slow blow fuse has burnt out and shut down power to this game. I beleive that fat people are riding my snowmobile and the motor in seat is working to hard and blows fuse :')  other than posting a weight limit, or unplugging it, any other advice.
thanks guys!
SirPeale
  • Green Mountain Man
Re: Arctic thunder FUSE question...?
« Reply #1 on: December 10, 2009, 02:53:29 pm »
The motor in the seat is just a rumbler.  Unless These people are actually CRUSHING the seat, I don't think it's an issue.
Not sure of the rating, but if it is continually blowing you may want to unplug it until you can source why it is doing so.
Check the connectors, they may have built up resistance over time.  It'll be noticeable if they're discoloured from heat.
grantspain
« Reply #2 on: December 10, 2009, 05:05:14 pm »
minimum would be 7 amp
