Author Topic: Wireless with batteries  (Read 1280 times)
ketil
  • Newbie
  • Last login:December 08, 2009, 07:48:20 pm
« on: December 08, 2009, 06:17:38 pm »
I had a thought... Wireless controllers need batteries, and every time they run out it's equally irritating. How difficult would it be to incorporate Seiko Kinetic style charging into a wireless controller? It's not like the controllers aren't thrown around during gameplay. ;) But is it enough?
Re: Wireless with batteries
« Reply #1 on: December 08, 2009, 06:55:08 pm »
Interesting idea, but I'm guessing it wouldn't be enough. Watches suck +very+ little power, so it doesn't take much to charge them. but a wireless controller likely would be orders of magnitude more power required.
However, something like this might be a good fit.
http://www.powermat.com/us/home/
What'd I'd probably investigate is one of their phone or nintendo backpanels. You could likely tear it apart and relocate the guts into a wireless controller of your own.
but that's a guess.
What'd be cool is someone making a "component" backpanel, ie, all the pieces with power out that you could wire up however you need, sort of like the Aimtrack.
SirPeale
  • Green Mountain Man
« Reply #2 on: December 08, 2009, 07:44:03 pm »
It would definitely not be enough.  Here's an example - you know those flashlights that you have to shake to use?  You have to shake the heck out of them to use them - then you get like 15 minutes of usable light out of them before you have to shake them again.  And that's powering a tiny little LED.  Try doing that for something that has a rumble motor and transmitting wireless.
Even if you removed the rumble motor, the drain would be tremendous.
Watches AFAIK use the same principle but they use /very/ little power, plus your arm is moving ALL the time, so it gets constantly charged.
