Author Topic: MAME - Change joystick, copyright verification?  (Read 2181 times)
Christolito
  • Last login:June 07, 2011, 02:16:22 am
« on: December 08, 2009, 05:01:36 pm »
Hi,
first poster here.  :) Loving the forum.
I have a HotRod (X-Arcade-ish) together with MAME. When running a new ROM its shows the copyright dialog. To OK this, i need to type OK, or move joystick left and right. I was wondering i can map this verification (Left - Right) to my HotRod joystick, instead of having to pick up my keyboard or plug in a joystick? Good thing is it only happens once a ROM, but still... Ideas?
Cheers
Christo, Sweden
Look! A three headed monkey!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: MAME - Change joystick, copyright verification?
« Reply #1 on: December 10, 2009, 02:14:25 pm »
Yes, in a couple waysways.
- If you downloaded the commandline vesion of mame, it should come with a hotrodse.cfg file in the ctrlr folder.  In mame's mame.ini file, set "ctrlr hotrodse", and you're done.  This also does other remaps, like being able to use P1B1 like the keyboard's enter (great IMO), but also makes it too easy to accidentally exit the game (press P2 coin & P2 start at the same time, very bad IMO).
If you have the mameUI version, you can DL the CL version and copy the hotrodse.cfg file into mameUI's ctrlr folder, and set the default controller to hotrodse.
- If you don't like the resulting maps, or don't want to bother with ctrlr files, you can also remap your own.  Start any (working) game in mame, tab, "Input (general)", "User Interface", scroll to "UI Left", enter, press hotrod's stick left, wait for mame to accept it, (repeat or other left's you want), (repeat for "UI Right").
- You can also hand edit the hotrodse.cfg file I talked about before with any text editor.  IMO very easy to understand, but if you don't understand it, I'll gladly help.
Robin
Knowledge is Power
Christolito
« Reply #2 on: December 11, 2009, 04:47:09 am »
Thanks rebelscum! I will try it out! Should be able to edit the cfg file.
