Author Topic: Lubricating U360s?  (Read 2832 times)
Gamester
Lubricating U360s?
« on: November 29, 2009, 10:20:25 pm »
Anyone know what type of lubricant I should use for U360s?  My joys only have about a week of use on them, and already my player 1 joy is acting up and won't consistently return to center (sometimes it's off center by as much as 30%.  It's getting very frustrating for everyone that uses it.  Nothing worse than being deep into a game and having the joystick go the opposite direction unexpectedly when you think it's at center, or trying to select a game in my FE, only to have it keep scrolling because the joystick won't go to its dead zone.
At first I thought I might have a bent support, but if that was the case, I don't think it would ever return to center.  After playing around with it, I think it might be a lubrication issue (or lack thereof) which is causing it to stick slightly at times.
I thought I might try lubricating it before griping to Andy, but I'm not sure what type of lubricant would be safe for it?  I think it's a metal ball in a plastic socket, so I doubt any type of petroleum based lubricant would be a good idea...
I obviously don't want to do anything to make the situation worse.
Advice is appreciated.
Franco B
Re: Lubricating U360s?
« Reply #1 on: November 29, 2009, 11:12:14 pm »
[Sanwa G-40M-100] is the official lube but unless you want to spend £20+ I suggest you buy some other silicon grease from elsewhere.
I would be surprised if the lack of lube is causing your problems though. I have had some my JLWs (essentially U360's) apart quite a few times and I know there is no grease on them but I have never had any problems. Are you sure they are assembled correctly?
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #2 on: December 01, 2009, 12:28:45 am »
shinetsu is only knockoff molykote44 medium.
http://www.dowcorning.com/applications/search/default.aspx?R=391EN
 molykote is cheaper, less thick and more slippery -for me better, joystick is quicker. believe me, Dow Corning is better firm.
