Author Topic: Anyone know anything about Scancard?  (Read 1550 times)
Bobulus
  • Last login:July 11, 2014, 10:42:28 am
« on: November 29, 2009, 12:15:26 am »
Managed to snag something fairly nice through the Buy/Sell forum...a ScancardII enabled television that directly accepts VGA input.
Good news: It has a turn-on-when-plugged-in setting.
Bad news: If you do it this way, it defaults to tv mode and vga mode.
So my options are either leave it powered in vga mode (and have to turn it on manually) or have it auto-turn-on in tv mode (and have to manually switch it over), neither of which is optimal.
Except...the ScancardII also has a serial port, and the documentation say that:
The ScanCard II assembly is equipped with a RS 232 (Serial) Input. When a computer’ s Serial Port is hooked to the ScanCard II through the RS 232 input, the computer can control the various functions of the television. (Refer to SmarkLink specifications available under DNA.)
I'm hoping I can use this serial connection (as hard as that is to pull off under windows xp) to either turn on the tv or tune it to vga mode when the computer boots. Has anyone else used a tv like this? I'm having trouble finding the specs for this Smartlink.
« Last Edit: November 29, 2009, 12:31:52 am by Bobulus »
Ummon
  • Trade Count: (+13)
Re: Anyone know anything about Scancard?
« Reply #1 on: December 01, 2009, 02:34:19 am »
Try the attached app.
Yo. Chocolate.
Stephen Hawking
Bobulus
« Reply #2 on: December 01, 2009, 02:50:47 am »
Erm, I'm confused. This seems to be a program that sends a signal to the printer port?
Ummon
« Reply #3 on: December 03, 2009, 02:05:05 am »
Ah. So it is, I remember now. That might just be a simple change in the code, relative to what port you want the signal sent.
Yo. Chocolate.
Stephen Hawking
